Question about Toshiba 37HL67 37 in. LCD HDTV
Closed Captioning won't shut off
Closed Captioning on the 37HL67 won't turn off, even when it is in off mode. What do I do?
  • 1 more comment
  • Anonymous Feb 12, 2008
    same problem here, but i have to Regza 42HL167
  • SDASDFASDFAS Feb 26, 2008
    We just sit there angrily watching the show and the damn closed captions...................maybe some day we'll find the instruction manual to the television and solve the problem,....but looking here won't help at all.
  • mjsnola May 04, 2008
    I have the same problem on a Toshiba 19HLV87. I have searched the manual and online... no help yet
    President:
  • 1,284 Answers
Does the closed captioning show up on DVD's,Cable, Satellite? etc?
Posted on Jun 08, 2007
I don't know. I have the same fucking problem and looking here is a waste of time. Every link leads to a sales pitch,.....starting to understand what the main goal of this site might be ?????
Posted on Feb 26, 2008
SOURCE:
CLOSE CAPTIONING WON'T TURN OFF
Go back into the menu of the TV and go through the choices. One of them is to turn on/off closed captions!
Jan 02, 2013 | RCA Televison & Video
Philips 24PT6341 closed captioning won't turn off and there is no option in menu
There must be a button marked "CC" on your TVs remote control. Press it once. It will make the closed caption windwow off.
Jun 21, 2012 | Philips 27PT6441 27" TV
Can't turn off the deaf aid
Enter "setup-mode" on the Shaw PVR, and disable "closed captioning".
Or, enter "setup-mode" on your TV, and disable "closed captioning".
Apr 28, 2012 | shaw.ca
How do you turn on the Closed Caption mode
U have the tv original remote wright?Yes?Look at the tv remote look for a button that said CC,press that CC buton a couple of times for it to have like CC1,2,3..if the tv program u are watching offer Closed Captioning u will have it.Or tries the tv manual button on the tv bazel frame itself that said Menu.Press the Menu buton go into the tv funsctions look for Closed Captioning funsctions in there look for it and turn it on all like CC1,2,3... all on will also getting Closed Captioning for the tv programmng shows that offer it too.
Aug 23, 2011 | Durabrand DWT1905 TV
I can't turn the closed captioning off. I have went to device tv tried turning cc off. It won't turn off
If you are able to turn the closed captioning off with the original TV remote, then I suggest doing it that way. If you want that functionality on your Harmony One, you can use the original remote to teach the Harmony the closed captioning command. To learn commands, do the following:
1. Log in to the Harmony software. 2. On the "Devices" tab, click "Learn IR" next to the icon for your TV. 3. At the bottom of the screen where it says "MyNewCommand," enter the name that you want the command to have, and click "Learn." 4. Follow the on-screen instructions to learn the button. 5. Update your remote.
Jul 26, 2011 | Logitech Harmony One Advanced Universal...
How do I get closed captioning on a Samsung TV model TXJ2754?
Hello
Your TV displays the closed captions that are broadcast with some
television shows. These captions are usually subtitles for the hearing
impaired or language translations. All VCRs record the closed caption
signal and most pre-recorded commercial video tapes provide closed
captions. Check for the closed caption symbol in your television
schedule and on the tape's packaging: .
1 Press MENU repeatedly until you see the Setup menu. Press CH
to select "Caption."
2 Press VOL+ to open the Closed Caption menu.
3 Press VOL + to turn closed captioning on.
Misspellings and odd characters can occur in captioning. Also, there may be a
captioning delay after changing channels. Neither situation is a TV malfunction.
4 Press CH to highlight "Mode." Press - VOL or VOL + to choose
"Capt." (captions) or "Text." In caption mode, captions appear and
cover a small portion of the picture. In text mode, information unrelated
to the program, such as news reports, are displayed and
often cover a large portion of the screen.
5 If you wish, use CH , CH , or VOL + to change the captioning
channel or field. Then, press DISPLAY to return to normal viewing.
 Different channels and fields display different information, such as additional
languages or supplemental information
Nov 23, 2010 | Samsung TXJ2754 27" TV
Closed captioning
If you have correctly turned it off on the set and are using some kind of Cable or Satellite box for signal---many of them have closed captioning as well as SAP separate from the TV.
If problem is not the set and you are using a box then look there for your problem.
SD TECH
May 12, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Jvc 48in projection tv
Somehow you have turned on closed captioning in TEXT mode. Navigate the setup menus to find the closed captioning options and turn it off.
That should resolve the problem.
Dan
Mar 20, 2009 | JVC AV-48WP30 48" Rear Projection...
Recording with closed caption
Carl,
Better late than.. I think that the Polo can record the encoded closed captioning onto the HDD, but you have to have a CC equipped television to display the captioning.
The newer Magnavox and Philips recorders sold at Walmart record the captioning, and have the capability to display it even on sets without the built in CC decoder depending upon your recording settings. If you get a digital converter box and connect that as the source to your Polo, you can record CC displayed on the screen if you want.
tom
Nov 20, 2008 | Polaroid DRM-2001G DVD Recorder/HDD...
Closed captioning
I experienced the same problem for about an hour before recognizing that the "continuous on" closed captioning had been activated on my cable box, not the TV. The signal feeds through despite the CC settings on the TV. If you haven't already, try checking the CC settings on whatever device is supplying your video.
Apr 22, 2008 | Hitachi P42H401 42 in. Plasma HDTV
Toshiba 37HL67 37 in. LCD HDTV Logo
341 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
