Hp officejet d135 won't scan or print (except from computer)
Message always shows: Scanner failure. Turn power off then on again.
I've tried turning the power on and off, unplugging, re-setting, nothing works.
    Guru:
  • 389 Answers
You it is necessary to make sure in correct joining the printer and computer. If you use the long cable USB change him(it) on short and advisable he must be thic. Change the driver of the scanner, this separate program and is fixed after driver of the printer. Advisable использывать checked cord of the join with the other printing device. Take the driver for your OS with site of the producer HP.If you is not got, apply to service. Good luck!
Posted on Sep 20, 2009
Hey. I have a HP Officejet d135 All i One, and running Win7 on my computor. The scan function on the device does not work. The display on the printer/scanner reads "Scanner Failure. The scan function...
Go into Device Manager and double click on USB Print Support. In Driver tab, click uninstall. After uninstall, power reset the computer. Once computer turns back on, it should automatically start the re-installation process of the printer. Then you select let windows do automatic search for the proper driver.
Mar 01, 2011 | HP OfficeJet D135 All-In-One InkJet...
Displays " Scanner Failure"
I've seen a similar issue on other HP All-In-Ones. I had to contact support, but all they do is make sure you try connecting the printer to the wall outlet instead of a surge supressor, then a different wall outlet, then reset to factory defaults. After that didn't work, they submitted an replacement order.
Hope this helps
May 28, 2009 | HP OfficeJet 7410 All-In-One InkJet...
SCANNING FAILURE ON HP OFFICEJET D135
Bad SCANNER UNIT. Uneconomical to repair. Sorry
Jan 30, 2009 | HP OfficeJet D135 All-In-One InkJet...
Hp officejet 6110 all-in-one
maybe you could try to reinstall the driver?
Oct 30, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Scanner failure
After turning on the printer, I am getting a message stating "scanner failure" turn off printer. Can't do anything else.
Aug 14, 2008 | HP OfficeJet D135 All-In-One InkJet...
Scanner won't work, printer and fax work
reinstall the print management software. May need to remove the printer, and re add under control panel. Got backup?
Feb 10, 2008 | HP OfficeJet D135 All-In-One InkJet...
Scanner Failure
Test your power supply for proper output.
Nov 13, 2007 | HP OfficeJet D135 All-In-One InkJet...
"Scanner Failure" displayed on led panel EVERY time
The solution is at the HP website. see here
Solution five: Reset the product
Step one: Perform a partial reset
  1. Disconnect the power cord from the product.
  2. Press and hold # and 3 while reconnecting the power cord to the product, and then release both buttons.
  3. Try making a color copy by pressing the Start Copy Color button on the product control panel.
    • If the partial reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next step to try a semi-full reset.
Step two: Perform a semi-full reset CAUTION: Performing a semi-full reset deletes any saved phone numbers on the product.
  2. Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
    • If the semi-full reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next solution.
Oct 28, 2007 | HP OfficeJet D135 All-In-One InkJet...
71 people viewed this question
k24674
