Question about Quantum (45650101) Quantum Juice Dispenser SLJ1400 three valve push button illuminated self contained refrig...
Ice dispenser paddle hard to push
We have a stainless Frigidaire side by side, 3 years old. The paddle that releases ice from the door is suddenly very hard to push. Something has changed. I can push it and get ice--my kids have to struggle a bit. I'm mainly concerned about that paddle breaking before the problem gets fixed. Any ideas??
    New Friend:
I know it's been a whle, but I recently had hensame problem. Unable to find an answer I decided to pull it apart. After removing the water/ice dispenser panel I noticed there was a spring loaded rod which held the ice flap in position. The rod had worked itself loose from one end and was causing the problem. I realigned the rod with the hole in the bracket and gently tapped it back into place. After re installing the panel everything was back to normal. You can find some decent tear down videos on Youtube explaining the panel removal. Hope this helps if anyone else runs into this problem. http://m.youtube.com/#/watch?v=0Tmpt63T79M&desktop_uri=%2Fwatch%3Fv%3D0Tmpt63T79M
Posted on Jan 07, 2013
Frigidaire GLRSF266J side by side makes ice, but dispenser won't work, what can I do?
The part that holds the switch in the dispenser door may have allowed the paddle to no longer contact the switch correctly. Look for a discolored wire connector under the hinge cover on the freezer door. If it looks all in order the water solenoid located where the water line attaches to the fridge may be bad.
Jun 28, 2015 | Frigidaire Refrigerators
I have a Frigidaire model number PLHS67EESB9 side by side refrigerator. About 4 months, I has the water dispenser paddle replaced by a trained technician. Recently, the when the freezer door was opened...
Start by looking at the circuit boards for any sign of cracks or a trace coming off the board. Also, check all the ribbon wires for any signs of a break, corrosion, and so on. As soon as my database comes back online I will look to see if I have a service manual for that unit and any test procedures that you may do. Also, look at the door switch for any shorts or wire breakage. Post back any results to me.
Regards,
Richard
Oct 03, 2011 | Frigidaire FSC23F7D Side by Side...
The ice maker makes ice and dispense water, but won't dispense ice. Cleaned out ice tray, not ice blocking any discharge area. When you try you can hear the ice dispenser door open, but the motor to...
i have the same fridge... same problem, except not only does it not dispense ice, it also dosent dispense the water too. i recently had a power outage, and when the fridge was turned back on the digital warmer and colder setting have been flashing 0 non stop making it unable to set temps... any suggestions?
Aug 22, 2011 | General Electric GSH25JSXSS Stainless...
I have a stainless steel Frigidaire side-by-side refrigerator with an ice/water dispenser in the door. The paddle on the water dispenser broke, and I need advise on how to disassemble the dispenser in...
the front cover will come off. if you dont see any screws then it WILL unsnap. look for a slot on the top or bottom of the cover. good luck some of them can be nasty
Oct 28, 2009 | Refrigerators
Ice maker dispenses ice without anyone pushing button.
Possible fault with the electrical connector at the bottom of the door as these can corrode or the microswitch behind the paddle has got jammed , try pulling the paddle forward a little . You should hear the switch click when you push the paddle back .
Mar 05, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool Gs5shaxnb02 Ice maker
is there water in the ice trays?if not try pushing the test button normally underneath the unit. possibly it will initiate a reset and start working. sometimes a limit is not activated when it should be.
Aug 07, 2008 | Whirlpool GS6NBEXR Side by Side...
In door ice and water dispensing
sounds like the paddle is hanging up or the micro switch that the paddle actuates is sticking if you can see the micro switch spray some wd 40 on it open the door and work the paddle a few times
Feb 15, 2008 | Frigidaire FSC23F7D Side by Side...
Quantum (45650101) Quantum Juice Dispenser SLJ1400 three valve push button illuminated self contained refrig... Logo
134 people viewed this question
Top Quantum Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Quantum Kitchen Appliances - Other Expert? Answer questions, earn points and help others
