Question about Coffee Makers & Espresso Machines
I have a Faema S87-2 and need to know what the amperage is for it. It's listed as a 220v. Anyone have the specs for the amperage?
    President:
  • 1,618 Answers
They are usually 30 amps. However if you have the wattage for the element Faema usually is 2600-4000, divide wattage by voltage ( at receptacle could be anywhere from 200-240), then multipy by 1.25 for draw, that should give you your amerage needed.
Posted on Feb 26, 2009
Bose soundock 10
You want to plug the SoundDock into a 220 receptacle, is that correct, and the Soundock works off of 120v., correct. I tried to find the specs for the Bose SoundDock, i.e. its wattage rating but it seems that Bose does not publish these specs. At any rate a 220v to 120 v converter should work
The 300 watt converter listed above should work fine. Wahtever converter you use, make sure it operates at 60/50 hz.
May 19, 2014 | BOSE(R) SoundDock 10 Bluetooth dock...
Sanyo sound system built-in transformer amp usage
If no one has the specs on this transformer but you know the power rating, apply this formula: Power/Voltage= Amperage. It might not be a big help but it sure will put you in the right range. The other solution would be to obtain a schematic or parts list for the unit. Hope this helps!
Nov 30, 2013 | Sanyo Audio Players & Recorders
What are the electrical specs for model RBD305 Double Oven
All the information for that is usually located on the tag where the model and serial number are at. Electrical specs are 220v a/c 60hz. I can't recall the amperage. If you don't have the owners manual you can go to www.apdepot.com and get one
Apr 27, 2012 | Whirlpool RBD305PD Electric Double Oven
I got an used Pentax CAM 100 water pump but need some help: Does anyone has manual where I can read the specs and installation guide? Seems it works with split-phase 220V 60Hz. It is possible to run...
Look on the pump itself for wiring instructions. Usually if a pump can be wired to multiple voltages there is a diagram either on the side of the pump or under the wiring cover. I tried to locate a manual online with no success. If it can be wired 110 volts, you will get the same performance but your amperage will be double the 220 volt amperage.
Dec 07, 2010 | Plumbing
Bought a used Faema Eurostar Combi. Don't have a
If it's the same as the used one I just picked up, there is a dial position for coffee, with a little cup on it. The dial position for steam is the one that cares about the positoin of the steam/hot water button.
The coffee position will never use steam and you don't need worry about the position of the steam button if you're not frothing milk.
Jun 29, 2010 | Faema FA60081
Hi need to know the program system for a faema smart 2 group
Press the stop button and the button you are programing together, then keep them held down until you get your level then release.
Feb 20, 2010 | Faema Coffee Makers & Espresso Machines
I have a Faema special. model no.537212 I need the schematics
I have no clue about this product, but at the terminal board how many
wires come from machine to the board,or just wires coming from machine. A 220v, should have 2 hot, neutral,gr, so 4 wires. Depending
on what it looks like, the wires come from machine to a board or just wires.then the colors of those wires.
You should send them an email asking for help or schematic.
I posted there website below. Sorry could not help further.
http://www.faema.net/site/index.html
Apr 07, 2009 | Faema FA60081
I would like to know a place where i could get the technical and part manuel of the following machine: ''FAEMA E91 A Diplomat'' And please if you can get it in french version it would be appriate thanks...
FAEMA COMPANY LTD. M6G 1Z6 Ontario and Western Canada ADDRESS _t.gif 672 Dupont Street, Suite 201, Toronto TELEPHONE _t.gif 001 416 535 1555 FAX _t.gif 001 416 535 3843 EMAIL _t.gif espresso@faema.net _t.gif iko_piu.gif _t.gif FAEMA DISTRIBUTEUR, INC. QC H2R 2W5 Montreal, Quebec ADDRESS _t.gif 14 Jean-Talon West TELEPHONE _t.gif 001 514 276 2671 FAX _t.gif 001 514 276 5991 EMAIL _t.gif sales@faemacanada.com
Mar 16, 2009 | Faema FA60081
Lid switch
there's usually a 3 (large) pins switch at the lid. unscrew it and take it off and look for the highest amperage on the switch(e.g.:220V/16A-30A rather than 220V/6A), then look for the pins combination; mine has 2-3 for the highest amperage and 1-2 for stand-by. you have to take off the switch's plug and connect the highest amperage pins (2-3). screw back the switch(without the plug).
Oct 15, 2007 | Washing Machines
Coffee Makers & Espresso Machines Logo
162 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
