Question about Lanzar OPTI1222D Car Subwoofer
Soundstorm amp vw12d could this be the model number for the subs
  • 15,935 Answers
SPECS
  • Black P.P. Cone
  • Specially Treated Foam Edge Suspension
  • 2.5' High Temperature Dual Voice Coil
  • Magnet Weight: 95 OZ
  • 1600 Watts Max Power Handling
  • Impedance: 4 Ohm
  • Chromed Back Plate Cover
  • Rubber Magnet Boot Cover
  • Posted on Jan 08, 2009
    • blueextc3221
      blueextc3221 Jan 08, 2009
      You will need (2) of these dual 4 ohm voicecoil subs to get a 4 ohm load on that amplifier.
      The lanzar site does not have the manual, but you will get them in the box when you purchase. It will state the proper ported enclosure size.
    My amps and subs are working, but my subs aren't hitting.
    Try bypassing the remote wire staight to power instead of the stereo
    Oct 26, 2009 | Lanzar VW12D Car Subwoofer
    4000.1 soundstorm amp
    Hello GregV24CHOPP,
    The Soundstorm products are in about the same category as Boss, Visonik, Pyle, and Lanzar to name a few. Somewhere between overrated and definitely overpriced for the quality you get.
    Look into the Alpine MRP-M1000. RMS = 1kW into 2ohms (600 into 4ohms), YES 4 OHMS(!), real power. No, it WON'T do one ohm. But most of those claiming to are not CEA2006 compliant anyway and can claim any power at any load and advertise for whatever buyers they can attract for their bottom-of-the-barrel products.
    The MRP-M1000 is currently on sale at Crutchfield for only $347. Awesome power, and very good sound quality, too. I'm currently running 2 4ohm MTX Thunders off of "little brother", the MRP-M500, and they really shake the pavement.
    You have to spend good money to get good power, there is no way around that.
    The only wiring configurations for 2 2ohm DVC subs result in 0.5ohm, 2ohms, and 8ohms impedance. Check the Rockford-Fosgate "wiring wizard" for the different diagrams.
    Hope this helps.
    May 13, 2009 | Soundstorm CR4000.1 Car Amp
    I NEED DIRECTIONS ON HOW TO CONNECT MY AMP TO MY CAR
    We'll start with powering the system up. YOu will need to run your power wire from the battery. It must have a fuse just after the battery. Run the negative to the chassis of the vehicle. On the back of the radio, there will be a blue wire labeled remote/antenna. This wire needs to be connected to the amp. This is what turns it on and off when you power up the radio. Next you will need to run the RCA cables from the back of the radio to the amp. Now you are ready to hook up the sub woofers to the output side of the amp.
    Mar 27, 2009 | Soundstorm 500.2SL Car Audio Amplifier
    KAC-9102d no sound, Amp powers on but no sound to the subs.
    If the sub isn't working, you won't get a pop. All you need is a small speaker. Don't need a sub, you just want to test the sound. I recently blew 2 subs, no smoke, no smell, no sign of being blown. Absolutely nothing from the subs.... In the past my sub locked up. You can take your sub out of the box and hook the + and - to the battery to see if you can get the sub to pop there. I believe a small box will push a sub into a deep excursion to the center of the cone. I have 2 lanzar VW12D's that just quit. I hooked a 6 x 9 up to my amp and low and behold I had sound! Try that and see what you get...
    Feb 07, 2009 | Kenwood KAC-9102D Car Audio Amplifier
    Can u help me
    The amp probably has shorted outputs. Do you want to try to troubleshoot it and repair it yourself?
    Nov 22, 2008 | Soundstorm D500.4 Car Audio Amplifier
    Aux input on Soundstorm amp
    If the amplifiers have RCA jacks, you can use an adapter cable to go from the headphone jack to the RCA inputs on the amp. If you're in the U.S., Radio Shack will likely have what you need.
    Jun 30, 2008 | Soundstorm 2F400 Car Audio Amplifier
    Amp has Red LED light on.
    Disconnect all speaker wires and signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
    Nov 05, 2007 | Soundstorm F2600 Car Audio Amplifier
    Lanzar OPTI1222D Car Subwoofer Logo
    54 people viewed this question
    Top Lanzar Car Audio & Video Experts
    Chris Ward
    xxxxxx xxx
    Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
