Question about Acer Aspire 5610-4648 Notebook
Memory card slot broken with damage to pins Acer Aspire 2920
Memory card reader developed a fault so I sent the laptop back to Acer for a warranty repair.
On inspection they observed some of the internal pins of the card reader had become bent, so they refused to repair it under waranty. They recon a new mother board would be needed - a cost to me of £185
It's only 6 months old.I am adamant that I have never misused the card slot. Has anyone else had a similar prolem with a laptop card reader, and crucually can you advise if itwasor should be covered by warranty
  • 2 more comments
  • Anonymous Jan 08, 2009
    This is a copy of the response the acer repair centre gave me...
    "Thepins itself was bent this is only caused by excessive force this is nota manufacturing defect this is classed as accidental damage andtherefore is not covered by your warranty if you would like to pay forthe repair please contact our support team on the number provided belowor alternatively if you do not wish to pay you may request the unit tobe sent back unrepaired."
  • pete2222 Jan 08, 2009
    Thanks for your support. I'm not giving in yet and have written them another letter today. We shall see what they have to say....
  • pete2222 Jan 12, 2009
    I live in Kent. Thanks for your offer. I will persue this with Acer first as I really do feel they should fix it for me.
  • pete2222 Jan 13, 2009
    received a "final non-negotiable decision" from Acer today. They refuse to repair it free. I therefore asked for it to be sent back to me unrepaired.
    I am really unhappy with this as i am 100% certain the memory card reader has only been used normally and it's only 6 months old. I will buy an external card reader now, but does anyone know what the correct proceedure is if i wanted to follow this up further. Is there a consumer watchdog or someone worth compaining to in the UK?
  • Acer Master
  • 4,806 Answers
Hi there
I'm a PC technician and i have come across this problem before with built in card readers and i can usually fix the problem myself.
It sounds like Acer are just trying to swindle more money from you.
Warranty is supposed to cover hardware up to a year and should be their responsibility to repair.
Can you tell me just what they said to you?
Posted on Jan 08, 2009
  • 1 more comment
  • Lee Hodgson
    Lee Hodgson Jan 08, 2009
    That is the most stupid get-out clause i've ever heard, Acer had made a bit of a booboo there because its a bad design flaw, the brass pins should not be exposed to this kind of damage.
    With all the laptops i have worked with only Acer seem to leave the pins exposed and obviously will get damaged at some point.
    The best thing you could do is argue with them and get them to give in, if not a PC repair shop should be able to straighten the pins as i have done this type of repair many times
  • Lee Hodgson
    I live in the UK, if you live close to me and Acer still refuses i can fix it for you without having to replace the motherboard
  • Lee Hodgson
    Lee Hodgson Jan 13, 2009
    Hi there
    Its a shame Acer will not do anything about it because its not good customer relations for them.
    You can get in touch with trading standards which is now part of OFCOM, whether they will do anything for you is anyones guess but they will take the complaint seriously.
    Good luck with them
    Kind regards
I want to upgrade the hard drive. What type do I need ide, ata, sata
the upgrading can be done only if the motherboard support if your laptop had sata provision you can use them if you dont have you cant use sata check the motherboard
Dec 15, 2010 | Acer Aspire 5100-5480 Notebook
How do you put a memory card into the acer laptop ,to add pictures directly off of the card onto the computer ?
Installed the Card Reader Driver first,Put your SD momory Card in the adapter and insert in the card reader slot. Browse now as if you brwose when you insert pen drive.
Otherwise,Get a USB Memory Card Reader Pen Drive.No need to installed driver or adapter.
Dec 26, 2009 | Acer Aspire 3618AWLMi Notebook
Do you need an adapter 4 a memory stick pro duo in a 5 in 1 read
No, just insert the Memory Card in the 5-in-1 Card Reader slot. The Memory Card will appear on the "My Computer" or "Computer" window. Click on that to open the contents of the Memory Card.
Good Luck!!!!!!
Nov 30, 2009 | Acer Aspire 5610-4648 Notebook
Acer 5100 laptop dvd/cd player is broken,how do I remove it?
Remove the access cover on the bottom of the case that houses the heatsink, wireless card and RAM memory. No components have to be removed to remove the cd drive. Now look at the cd bezel and then back toward where the RAM memory is installed in thier slots. There is a screw marked by a circle with what looks like a wedge taken out. This is the holding screw for the cd player. Once you remove this screw, there is agap next to the screw hole that you can stick the screwdriver in and push the cd player part way out of the case. Once you do that, grip the front of the drive and pull it free of the case. Refer to page 60 of the service manual I have included the link for below. Make sure you have a PDF file reader like Adobe or Fox-It Reader.
http://tim.id.au/laptops/acer/aspire%205110%205100%203100.pdf
Oct 28, 2009 | Acer Aspire 5100 Notebook
I have an Acer 9300WSMI laptop. Does it have a card reader and if so where is it? Thanks Fitzy
SD card slot is on the right hand side of the laptop (with it facing towards you) at the front.
SD card slot is #2
Regards.
Jul 28, 2009 | Acer Computers & Internet
The m2 adapter i have does not fit my acer aspire laptop yet my laptop card reader says it reads m2 memory cards. is there a certain way of putting the card in to the memory card reader.
I think that with smaller memory cards like m2 and t-flash(micro SD) you would have to use their adapter(a card with a slot that normally converts it to SD) before you can slot it in.
Nov 06, 2008 | Computers & Internet
Compatability of Memory Upgrade
One or both of your RAMs have developed a fault. Change both RAM. After changing RAM pl format again and than try. Do not insert those faulty RAM again. Get your RAM tested by a software which is available on Microsoft site for free.
Thanks
Bhaskar
Jun 04, 2008 | Acer Aspire™ T180 PC Desktop
How to eject a memory card from the 5-in-1 memory card reader on an acer laptop?
Most of them you just push the card in then a spring will pop it out.
Nov 20, 2007 | Acer Aspire 5630 Notebook
Acer aspire 7004 flash card slot
Your computer doesn't support compact flash cards. Your SD slot is a 5-in-1 card reader, supporting Secure Digital (SD), MultiMediaCard (MMC), Memory Stick® (MS), Memory Stick PRO? (MS PRO), xD-Picture Card? (xD). The big slot is for PCMCIA devices.
Jul 12, 2007 | Acer Aspire 3000 Notebook
Acer Aspire 5610-4648 Notebook Logo
559 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
