Question about Bosch Exxcel WFO 2465 Front Load Washer
BOSCH WFF 200L
It stays on the main wash forever..it just keeps on and on washing with small amount of water. if i turn to diferent cycle manually,everything works fine,like rinsing, pumping and spinning.there is no blockage on water supply,and i cleaned everything possible e.g waste pipe. The machine is about 7 years old. please help ! thanks.
  • peter lee Jun 03, 2007
    is the element costly? where does it locate?
    can i relace it myself? do ijust need to take
    the back cover off or and the front as well?
    please give more advice.thank you!
    Sergeant:
  • 236 Answers
Heater element may have gone, when you manually advance the settings you are skipping the heat cycle.
Posted on Jun 02, 2007
SOURCE:
What are WFL 2060 fault codes
Bosch WFF washing machine error codes:
E1
- The door is not closed and cannot therefore lock.
E2 - Washer will not fill with water.
E3 - Washing machine not heating.
E4 - Washing machine won't empty.
E5 - Fault in the motor drive circuit.
E6 - Unexpected heating.
E7 - NTC thermistor open or short circuit.
Please note that the codes for the WFF range of Bosch machines differs from other ranges.
Sep 04, 2014 | Bosch Axxis WFL 2060 Front Load Washer
We have a bosch WFF 2001 washing machine, the pump will not turn off and the spin light remians on
bosch WFF 2001 washing machine This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jan 16, 2011 | Washing Machines
Fills with water then does not rotate, also does not spin
Check for large items of clothes being tangled if the Bosch washing machine doesn't spin. The weight could not be evenly distributed in the drum and the spin cycle will have been disabled to prevent damage to the clothes..
Load the drum with large and small clothes together and run the entire washing cycle and spin cycle again.
Add more powder and run the entire washing and spin cycle again if you haven't found tangled large items, but the spin cycle still failed. This indicates the amount of cloths was too small.
Add 1 tablespoon of fabric softener to 1 pint of water and pour it into the main detergent dispenser if there's no tangling and the load was a normal size. The cause would have been excessive suds because of too much, or the wrong kind, of detergent. Use HE (High Efficiency) detergent in Bosch washing machines.
Nov 01, 2010 | Bosch Washing Machines
Bosch wff 1401 not emptying water therfor not able to spin the pump goes round but water does not empty if i drain the water the machine will spin
If you have not already done so, then check and clean filter located at bottom front right of washer behind drop down cover.
If it still does not empty, then it is either blocked between the pump and tge waste outlet, or the pump itself could be faulty.
Jan 25, 2010 | Bosch Washing Machines
Instructions on how to use bosch wff 2001 washing machine
hi if you look on the main bosch web site you can find a list of manuels for bosch washing macine witch are free to down load in pdf format hope this helps tim automan.
May 23, 2009 | Bosch Washing Machines
Bosch continues to fill when rinsing even when the machine is off
The inlet valve is stuck open most commonly , you can check this by taking the wires off the valve and then turn everything back on , if the water is still flowing replace the inlet valve.
Phil
Apr 14, 2009 | Washing Machines
Washing machine: water level is high
PRESSURE MAY HAVE KINK OR DEFECTIVE
Nov 22, 2008 | Washing Machines
My Bosch WFF 2000 washing machine goes through its cycle and then leaves the on/off button lit, the door button lit and the pre-wash button flashing; also the door will not open until you turn all the...
The problem turned out to be foreign objects in the pump that stopped the machine from draining; the solution is simply to open up the pump and remove the objects!
Sep 09, 2008 | Bosch Washing Machines
Washing machine - Bosch WFF 1401 - spinning problem
Bosch WFF 1401 This washing machine tutorial will show you what to do if the washing machine does not drain or empty the water out this repair was done on a Bosch, Neff and Siemens type appliance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 29, 2007 | Washing Machines
Front load washing machine would not spin now won't wash either.
Sounds like you have a broken belt or a bad motor. The easiest way to tell if the belt is bad is to reach inside the drum and turn it. If it turns very easily, you probably have a bad belt or something has caused the belt to jump off, such a s a loose pulley or bad bearing. If it feels like there is a good amount of resistance, or a kind of "winding up" noise, then the belt is still on and you likely have a bad motor. Also, you could just scoot the macine out, unplug it, and remove the back cover a look inside to see if the belt is still on the pulleys. Good Luck!
Oct 17, 2006 | Bosch Exxcel WFO 2465 Front Load Washer
Bosch Exxcel WFO 2465 Front Load Washer Logo
344 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
