Question about Canon imageCLASS D760 All-In-One Laser Printer
DOCUMENT FEEDER THE DOCUMENT FEEDER/GRABBER TRIES TO GRAB THE DOCUMENT, BUT ISN'T SUCCESSFUL. IT JUST SAYS 'CHECK DOCUMENT' AN Y SUGGESTIONS?
  • Anonymous Jan 13, 2009
    Exactly the same thing. It just stalls trying to pull the document through.
  • CRAIG BRAY Jan 23, 2009
    Thanks,Yooperbud,I tried your idea, but to no avail. The grabber tries to pull the page, but stops after an inch.
    I appreciate your idea.
    President:
  • 8,637 Answers
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 23, 2009
Press the additional functions button and press the + button to scroll to number 4-adjust/clean, press set and then use + button to scroll to 2-clean ADF roller. Raise lid and press set button to rotate ADF roller. Where the paper feeds through there is a black rubber roller that grabs the sheets. I used a damp paper towel to hold against the roller and pressed set several times to rotate roller. I then used the dry end against roller and pressed set several more times to dry. Press the stop button to exit back to regular copy function and try. Mine works like a champ now. Hope this works for you.
km
Posted on Mar 08, 2009
My Automatic Document Feeder for my HP Photosmart 7520 won't work
Does it grab paper at all? Does the paper jam in the doc feeder? does it scan when place on the glass?
Oct 16, 2014 | HP Photosmart 7520 All-in-One Color Inkjet...
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
Auto doc feed does not activate
two possible problems :
- check the connection of the document feeder
- check the sensor on the document feeder that triggers the pickup
- check the clutch of pickup roller
Jul 27, 2012 | Canon PC-795 Copier
My printer X3350 has trouble grabbing the paper from the paper tray. What can is the problem. I tried cleaning the grabber wheel. But it still won't grab the paper.
Leading cause of paper jams is debris/foreign objects that accidentally fell into the paper feed area. Please follow steps below to fix the problem:
1. Remove the sheets of paper from the feeder.
2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris in the cartridge carrier's path or the paper path.
6. If cartridge area is clear, close the cover.
7. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print a document again to verify that the problem is fixed.
Sep 21, 2011 | Lexmark X3350 All-In-One InkJet Printer
Sharp AR-507 "Close the document feeder" error even it is already close...any suggestions and solutions please...
The document feeder has some kind of plastic nose that goes in to the sensor hole. Locate it and check for damadges.
Jul 05, 2010 | Sharp AR-507 Copier
The document feeder of our won't grab the paper
Check first the rollers and stripper pad if they are very sticky, just replace those roller. If not you can dismantle the covers on the feeders.find a solenoid and check the spring that attach on it. If the spring is broken replace it or just make a loop from the spring and reintall it from the solenoid. Then try to feed paper.
Nov 11, 2009 | Riso RZ220 Duplicator
Feeder wont grab sheets
open the cover of the document feeder you there will find two rollers (blue and grey) clean these rollers with a cloth dampened with nail polish remover
Oct 06, 2009 | HP Laserjet M2727nf Multifunction Printer
Document does not feed
Pull up to open the document feeder. Clean rollers and pad with alcohol.
Jun 09, 2009 | Brother IntelliFAX 2800 Laser Fax
Lexmark x7550 document feeder not taking pages of document for fax
Try cleaning the Feeder wheels that feed the paper in. Use a Dry cloth to wipe away paper fibers. They can cause the printer not to be able to grab the paper.
Rj
Nov 03, 2008 | Lexmark Office Equipment & Supplies
Document feed doesn't
drive gear is wore down on bearing surface good luck finding one
Apr 11, 2007 | Brother IntelliFAX 2800 Laser Fax
Canon imageCLASS D760 All-In-One Laser Printer Logo
244 people viewed this question
old marine
old marine
