Question about Seagate (ST9100801U2-RK) (9W3638556) 100 GB Hard Drive
Seagate 9w3638-556 100 gig usb drive working fine then blop front led is just blinking
Yes.. It is just sitting here blinking at me. Workstation will not reconnect to drive or show up in file manager on my XP SP2 workstation. Have no idea what might have happend. Is there any way to get the workstation to re-connect to it again? Am wondering if the important files I have on it are toast? Thanks in advance for any help any one can provide. Thanks
  • JAMES JACKSON Mar 06, 2008
    WANTS TO INSTALL A DRIVER AND IN DEVICE MGR DEVICE SHOWS UP AS JUST "24"
    Genius:
  • 2,985 Answers
Check the drive end to make sure it has poer and connectors are sound - you have he to take the case apart for this Change the USB connector for another asl anothercable is possible Go to Start/control panel/admintools/computer management/storage/removable storage See if the drive shows up
Posted on Jun 02, 2007
Suddenly, my 500GB Seagate external hard drive couldn't mount on my iMac. It was working fine till yesterday. I connected them to the Mac USD port, and the light in the seagate is blinking... Any
I can only comment generically:
I would try to uninstall the drive on the OS. Then re-start the computer. After the re-start, connect the drive and see if the drive re-installs itself.
If the error persists, then the drive is indicating failure. To absolutely verify if it has failed, take the drive to a store where there are MAC computers and try the drive on one of their computers to see if it works.
A continuous flashing LED on most devices where the LED does not normally continuously flash is an indication of a failure of the device. Some devices will flash an error code when designed to do so, and if possible.
Jerry G.
Aug 14, 2012 | Apple iMac 17" Desktop
My seagate freeagent 1tb is blinking whit lights and my computer does not recognize it. Help me
***Please NOTE***
Touch the drive and put your ear to it, to test if the drive is spinning and working. Do this while it is powered on. Also, try disconnecting the USB cable, reboot the computer, re-connect USB cable to another USB port on computer. If you still have the same issue, try the below solutions.
  • Make sure the computer and external hard drive are powered on.
  • Disconnect the external drive's USB or the eSATA cable, which ever one you're using.
  • Disconnect the power supply plug from the external drive.
  • Power off the computer.
  • Disconnect the computer's power supply cord for 60 seconds.
  • Reconnect the computer.
  • Power on the computer.
  • Connect the power supply to the external drive.
  • Connect the drive's USB or the eSATA cable and check for detection.
If the still no detection and still blinking lights on the drive, check the power supply to the drive.
Check to see what the led light on the power supply is doing.
If it's blinking, power down the drive, unplug data cable and then reconnect the power supply to another electrical outlet. If it still blinks repeatedly, then you power supply is bad.
If the led is solid (lit and not blinking) follow the same steps from above to connect it to another outlet.
Next, plug the power supply to the external drive and power it up.
If the power supply starts to blink repeatedly, then your controller board inside the enclosure is bad.
Thank you for the opportunity to help you.
Jun 04, 2011 | Seagate FreeAgent Pro 1TB External USB...
My seagate 320 gb freeagent go led is blinking and is not detected by my computer when i connect it to the usb port
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
May 31, 2011 | Seagate FreeAgent Go 320 GB USB 20 Hard...
Hi, I'm facing following problem, can any one help me please? Seagte external hard disk GoFlex Desk 1TB (STAC1000300) with USB 3 adapter STAE 106 is not working. When the USB 3 cable is connected to...
just install seagate free agent using this link
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=goflex-software&vgnextoid=11c1fab114b48210VgnVCM1000001a48090aRCRD
then try again if problem not solved, mail me to tsnp@ymail.com
Apr 19, 2011 | Seagate FreeAgent GoFlex Desk Desktop...
Hard drive doesnt work
i think you have to connect the slave HDD on a separated cables (data & Power) and also check your power supply abilities for handling all you devices (HDD's and others)
Mar 23, 2017 | Seagate U Series X 20 GB Hard Drive
Seagate 500 gig external hard drive problem
Your computer must have a firewire connection.
Jan 11, 2009 | Computers & Internet
External Harddrive Ignorance...
I've seen this happen with hubs being connected to external hard drives before.
Do you have a free usb port on the back of your computer you can plug it into?
That should fix the problem.
Jun 11, 2008 | Belkin (F5U233-APL) 4-Port USB Hub
Seagate 80GB external drive - drive lost. Lite on front of drive continuously blinking
If you plug it in to a hub try plugging it in to a USB port directly instead, one on the front or rear of the PC.
Mar 31, 2008 | Seagate FreeAgent Go 80 GB USB 2.0 Hard...
Maxtor one touch mini doesn't appear to work.
The blinking light indicates something is happening to know open :
http://seagate.custhelp.com/cgi-bin/seagate.cfg/php/enduser/std_adp.php?p_faqid=1600
And check the power cord and try with the known good power cord.
You can check this :
http://seagate.custhelp.com/cgi-bin/seagate.cfg/php/enduser/std_adp.php?p_faqid=4996&p_created=1194886713&p_sid=SzkLKr3j&p_accessibility=0&p_redirect=&p_lva=1600&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTg0LDE4NCZwX3Byb2RzPTQxMCw0MjEsNDYxLDQ2NSw1MDgmcF9jYXRzPSZwX3B2PTUuNTA4JnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTE*&p_li=&p_topview=1
Good Luck.
Live, Love, Laugh.
Feb 16, 2008 | Maxtor One-touch III Mini 40 GB USB 2.0...
Seagate (ST9100801U2-RK) (9W3638556) 100 GB Hard Drive Logo
762 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
