Question about Microsoft Windows Vista Ultimate Edition
NEED WIZ"S HELP- CANT BOOT XP OR VISTA CD FROM DVD DRIVE
Well what I wanted to do was reformat my computer because i have vista ultimate edition and I want xp. Im scared that if I reformat my computer that I wont be able to install xp because my computer can't boot from the dvd drive. The problem was that it wouldn't boot my xp cd or even my vista cd. I have 2 hardrives and one of them, drive c, has vista installed. So what I did was i disconnected my hardrive that has the vista installed from my motherboard. My other hardrive is blank so when i rebooted it says error loading operating system and when i try using my xp or even my vista cd to boot it doesn't boot. So i reconnect that harddrive that has vista installed and everything gos fine just that i cant boot XP or VISTA.Really weird need help. I think it might have to do with my BIOS but it is set to default. When writing a solution for me PLZ write alot of information and solutions just in case your first solution is no help. THX!
I had someone from this website give me a solution stating that- "first you must check your XP/Vista cd if it is bootable then open the bios setting change the first boot to CD ROM save and exit the bios insert CD wait for a second if the CD is BOOTABLE if so then follow the instructions of formating drive. But before you do that you must be sure that you have all the driver need to you PC for security you must use the black drive then install the XP OS." Well what is a black drive anyways? Really need to get this to work.....
  • 27 Answers
I'll give a whack at this problem. I think the previous person meant blank drive NOT black drive (that doesn't make sense to me).
I would follow the previous persons in going to BIOS and making sure the first boot device is CDROM. My question to you is whether you've already done this or whether you need assistance with this process. If so, please tell me what computer model you have.
Dman
Posted on Jan 08, 2009
Downgrading from vista to xp ( I have disk ) on h p dv6500 dv6504au A M D turion64 x2 Can you help please.
You download GPARTED live cd, boot it usually by pressing the boot key at startup, select cd drive, delete the paritions on the hard drive, or if you want to keep you're vista, resize it, then once thats done, boot from the XP disc, and select the empty partition format it, then install to it. Done.
Sep 02, 2011 | Microsoft Windows Vista Ultimate Edition
Can i boot win vista cd? can i use vista cd to reformat my computer?
Yes you can format computer with vista disk and instal new windows.
Inser that vista disk into cd/dvd rom then when you power up the computer press F1 or F2 del or ALT+F2 key to enter in bios.
Then go to boot menu and set first boot device as cd /dvd rom then save settings and exit from bios.
Then it boot with windows disk.Then follow the procedure and choose installing new windows xp then select 1 partition and format it then it install windows vista on it.It will take 30 to 45 minutes to complete the installation.
Let me know if you need further assistance.
Thanks for using FixYa.
Jul 13, 2010 | Microsoft Windows Vista Ultimate Edition
How do i uninstall windows vista and making a clean dard drive
You would need a operating sytem cd/dvd (windows xp\windows 7) and a windows COA key. Select your bios to boot from cd\dvd player. Insert the new cd of a different operating system into the drive and restart the computer. It should say press any key to start from cd. Press any key and proceed. You will get to an option to format and install. Format the drive Probably marked C:. This will wipe out the drive and install a fresh copy of whatever OS cd you booted from. Good Luck.
Nov 24, 2009 | Microsoft Windows Vista Ultimate Edition
NEED WIZ HELP- UNABLE TO BOOT FROM XP OR VISTA
dont mind it...
if you want to install xp to your computer while you are using utimate vista you can install it...
but you must have a large space of memory to install xp, tnx anyway hope that i can help...
Jan 08, 2009 | Microsoft Windows Vista Ultimate Edition
NEED WIZ HELP- UNABLE TO BOOT FROM XP OR VISTA FROM DVD DRIVE
Jan 07, 2009 | ASUS A8N-VM CSM (00610839133826)...
Getting ERROR FOR OPERATING SYSTEM
This is because you have to change the boot sequence in the BIOS or setup of the motherboard. When you first turn on the computer you can see something like press DEL to enter Setup or F12 or F10 or F2 depending onyour motherboard. once you get into setup you will see either boot sequence or boot order. Set the CDROM as the first boot device. Then when you startup the computer again you will see PRESS ANY KEY TO BOOT FROM CD. proceed with pressing anything on the keyboard.
Unable boot vista ultimate (installed earlier) after installing new xps2
You have to reinstall vista bootloader.
Just insert vista dvd in the drive and boot from it.
Select startup repair and it will fix everything back to normal.
Jul 05, 2008 | Microsoft Windows Vista Ultimate Edition
XP to Vista
Hello Paulraven,
You can use an external USB DVD ROM drive, put the Vista disk in it and you will be able to install it via USB (once XP is fully Booted).
If you want to Boot to the Vista disk using a USB port, then you should check your Boot Order in your BIOS and make sure that you set it to check CD/DVD drives before the hard drive, then you'll be able to touch any key on reboot to Boot to CD for a few seconds when that option appears on your screen (at the top left of the screen) after a Boot/re Boot with the Vista disk in the USB DVD drive.
I hope this helps, and Good Luck.
Mar 04, 2008 | Microsoft Windows Vista Ultimate Edition
Demo problem
If you have installed vista as a multiboot sytem, then you can do the below: Otherwise you have to do as tom19511 said:
Uninstall Windows Vista on a multiboot system
Applies to all editions of Windows Vista.
You cannot uninstall Windows Vista. However, you can change the code that starts the operating system (often called the master boot code), and then remove Windows Vista from your multiboot system and return to Windows XP or Windows 2000. You will need your Windows Vista installation disc for this procedure.
Before you begin, back up your programs, files, and settings. Removing Windows Vista is an advanced procedure that could result in losing information stored on your computer. For information about backing up data, search Help and Support for "back up."
1) Insert the Windows Vista installation disc.
2) Click the Start button getopencontent.aspx?assetid=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33&documentset=en-us&renderkey=xml, click All Programs, click Accessories, right-click Command Prompt, and then click Run as administrator. getopencontent.aspx?assetid=18abb370-ac1e-4b6b-b663-e028a75bf05b&documentset=en-us&renderkey=xml If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
3) Type [DVD drive letter]:\boot\bootsect.exe /nt52 ALL /force and then press ENTER.
For example, if the DVD drive letter is F, type f:\boot\ bootsect.exe /nt52 ALL /force.
4) Eject the Windows Vista installation disc.
5) Restart your computer.
Your computer will start in the previous version of Windows that you have installed.
6) Delete Windows Vista files and folders, such as the Program Files, Users, and Windows folders, manually.
Note: You can also remove Windows Vista by reformatting the partition where it is installed, but do this only if that partition is not the boot partition. Reformatting the boot partition might make your computer unable to start.
Nov 14, 2007 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows Vista Ultimate Edition Logo
120 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
