SOURCE: electric dryer only blows cold air......no heat
Your problem is associated with the heater element and or thermostats, you need to access these in order to determine the prob.
You have to lift the top cover and remove the front panel to do this.
Depending on your model of dryer, there are at least 2 ways to get into the dryer
It would take too long to fully explain the different ways to get into the dryer,so try this site which should give you all the info you need.
partselect.com
then click on free repair help then click on dryers, and then on my dryer will not heat up.
I would be grateful if you could let me know if you find the info you wanted from this site.
plz rate my solution.
Thanks.
SOURCE: Dryer heats but after 10 minutes is cold
you can replace te coils mounted atop the valve itself, somtimes after the heat up they nologer allow the gas valve to come on..paret number 279834 comes as akit with both coils!
