Question about Sony Playstation 3 (PS3) Console
Opening the ps3
What happens if i take of the lead of the ps3??
would i still be able 2 close it??
  • brighta010 Jan 10, 2009
    thank you very much
    Problem Solver:
  • 7 Answers
According the warranty information, you are allowed to open the playstation 3 up by any means except my removing the hard drive yourself. There is a sticker on it that if torn, voids your warranty.
if you want to remove your hard drive, then i suggest you take your playstation 3 to a sony service place or mail it to them.
Posted on Jan 09, 2009
  • 124 Answers
If you take off the lid you can close it again just dont lose any screws what are you opening it for if its to replace harddrive it is located on side with a panel that reads hdd take off panel remove blue screw pull right and slide out
After cutting off ps3 an then to switch back to tv there is no sound coming out .
it can happen if you have the ps3 on HDMI lead. some times the ps3 can still be sending a signal and the HDMI side of the tv is still open on sound. up date the ps3 firmware. should sort it out. if it has been updated change the HDMI lead. should sort it out.
Sep 21, 2013 | Televison & Video
Keeps turning off by its self
With nearly all computers and consoles turning off by themselves without warning is usualy a symptom of overheating, this untreated on a ps3 will lead to the YLOD effect.
step 1. the easy method Take a vacuum cleaner hose to the vents and try to extract as much dust as possible that may be clogging up the vent points, also ensure the console while in use is in a cool area (not stacked between tvboxes, bvcrs dvds and your tv in a closed cupboard (sit on a windowledge if possible)....see how that goes
step 2. open up the console and check the fan areas for dust or non spinning.
if all else fails look on youtube for YLOD fixes. buy the basic tools and heat paste and rework surface of processor.
hope this helps
Apr 06, 2011 | Sony Playstation 3 (PS3) Console
Well yesterday I tried an HDMI cable instead of the regular cable with the three colors it came with. Now I go back to the Three colored cable and Ot does not display anything nor does it make a sound. It...
When you're switching to a new or another TV other than the one that you're using or have swapped leads as you have described then you will need to reset the video settings on the PS3.
To do this turn the PS3 off so the red light is on. Hold down the power button on the PS3 until you hear a beep. Release the power button and press it again.
That should have reset the video settings so you will be able to set the video settings again on the other TV and access the PS3 menu to set it up again.
Regards.
Aug 16, 2010 | Sony Playstation 3 (PS3) Console
Ps3 wont go online
Make sure that you use a patch lead not a cross-over lead.
The Patch lead is pin for pin 1-1 2-2 3-3 4-4 5-5 6-6 7-7 8-8
Crossover lead has these pins crossed 1-3 2-6 3-1 6-2
Jun 06, 2010 | Sony PlayStation® 3 (80GB) Console
I turn my PS3 on and the screen is always blank. I tried holding the power button for 5 seconds as per the manual and this doesn't help, nothing happens. I also tried entering a safe mode but I can't as I...
I recommend you try to access Safe Mode again.
The way I understand it, your ps3 is supposed to turn off after the third beep as you keep holding the Power button. Then you start the sequence again, and this time you will get the double beep.
Of course, Safe mode is only available for PS3's with system software of 2.60 and higher, perhaps yours is older than that?
I hope that helps.
____________________________________
Sony PS3 Safe Mode
Apr 21, 2010 | Sony Playstation 3 (PS3) Console
My ps3 has been fine for the last 2 years. now i
I have just repaired one that had close to the same prob. The screen would go blue but i could hear it start. I replaced the PS3 power supply and has been running ever since. Hope this helps. Good Luck
Nov 22, 2009 | Sony Playstation 3 (PS3) Console
My ps3 turns black and nothing happens
Try checking your HDMI or VGA lead and reset the Ps3 Settings
Oct 03, 2009 | Sony Playstation 3 (PS3) Console
No signal
look for the av button on the remote thats the default ps3-any other console channel if that doesnt work look threw all the channels it could be av/or a little 0 with a arrow threw it just look
Aug 16, 2009 | Sony Playstation 3 (PS3) Console
High definition lead into ps3
try resetting the consoles setting to default,you can acquire this by just putting your finger still on the power button for lets just say 5 secs.until you hear it beeps.then remove your finger.let me know what happens
Jan 05, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3 overheating Fan problem?
I have done the research!!! And I wrote this guide taking more safety precautions against breaking my system than the originators so this is a reproduced guide wearing safety belts.
This means there are 2 possible problems with your PS3. Either 1) your fan is dying and needs to be replaced or 2) the heat transfer from your 2 processors to the fan is deteriorating. Number 2 is the most popular for overheating because Sony didn't use the greatest of thermal compounds on their processors, and the heat sink solutions Sony used in its launch systems weren't as well engineered as the later systems. 60gig are the most prone.
This has happened to me and I have fixed my PS3. It works perfectly as if I had just bought a new one (fan is super quiet, showing that the heat transfer is working perfectly) and 5 months later I had to repeat the process and it fixed the problem again. So, this solution may have to be an ongoing task through the years, I suggest doing it 3 times a year like I plan on doing. All you need is a couple screwdrivers, thermal paste (preferably something with silver or more expensive, Arctic Silver is good), and a heat gun (usually made for stripping paint) that gets to at least 650F. The processors in this MB are soldered in...
Okay, assuming you are good with handling hardware and get the PS3 bare down to its motherboard, you should see the huge *** fans mounted to the 2 processors, 1 says GPX and the other CELL I think.
1- You need to take off the fan carefully 2- Clean all the dust you can possible see, CAREFULLY 3- Use acetone or some other 99% alcohol compound to clean the old thermal paste off the back of the processors and the mounts of the fan. --------------------------------- This part is important --------------------------------- 4- Look for the 2 black chips that are almost touching each processor above (or below depending on the direction the board is) and pay attention to their location to the chips for when the board is upside down.
5- Place your motherboard on a flat, heat resistant surface and set up to where nothing will touch it for 30 minutes.
6- Using the heat gun, heat the processors for 25 seconds a piece (less time the hotter the gun) using a circular pattern as not to have the heat focused in 1 spot. Then do the same for the 4 black chips.
7- Let the motherboard cool for 30 minutes. You will hear popping noises, this is the solder hardening back up after being set further in its socket. DO NOT TOUCH MOTHERBOARD. It is hot and any outside pressure or contact could snap it. Just let it sit there.
Whats happening is your are resetting any connection damage that might have occurred from the processors getting hot and not cooling properly. This also corrects any minor misalignment of the processor and its seat.
8- Flip the motherboard over and repeat steps 6 and 7.
9- Now apply a thin layer of the thermal paste on the back of each processor. Just enough so you that appears like you can see through it. Not literally but to the point that you think you can make out a letter on the processor.
10- Mount the fan back on carefully and clean up all excess thermal compound that may have been squeezed out the sides.
That should do it. Put the PS3 back together, leave the final screws unscrewed, hold your breath, pray to your deity and turn it on.
Like I said earlier, this happened to me I. I did this fix, failed because I didn't heat the processors long enough. Increased my heating time by 15 seconds each processor, and then my PS3 ran faster, smoother, and quiter for about 5 months before I had to do this fix again because my girlfriend doesn't like to turn my PS3 off (have to shorten auto shutoff to 1 hour now *sigh*). But fixed for a second time with same results.
Good luck gents. This solution does work, but you must also know that it may void the chance of Sony fixing this for you for 150. I paid $7 (US) for the thermal compound and $25 for the heat gun. And the PS3 are $300
Nov 30, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
77 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
