Question about Sunbeam 738-400 Heater
Sunbeam convection heater stopped working
It has worked fine for 1 and a half months. I don't have the model # with me at the present time: however the model has a timer, several temperature settings (65, 70, 75, 80, 85), and it has an economy setting if we leave it on for extended periods. It is basically brand new. When it quit working, I plugged it in about 30 minutes later and it came on for about 30 seconds and then stopped working agaiin. It cost us about 50 dollars from Lowes and we don't have the receipt anymore (we kept it for about a month, then my wife threw it away). It is perfect for how we use it, but I am reluctant to buy another Sunbeam product. Can you give some advice? Signed, Tom
  • dh52go Feb 16, 2009
    I have the exact same problem, same time period, with Sunbeam model: SLP3310-UM.
2 Suggested Answers
  • 111 Answers
SOURCE: it has just quit working completely weve had this
did this heater get knock over, sometimes the safety switch gets hung up inside, cheap bi-metal switchs that cycle the heating element burn, power supply, bad plug or recepticle, heck put a high amp relay in and a wall thermostat,it'll probably say made in china on the back
Posted on Jan 31, 2010
  • 4736 Answers
SOURCE: I have have my sunbeam
Have you tested the receptacle that the heater is/was plugged into, to make sure it's working and a circuit breaker hasn't been tripped?
If not, plug a lamp into the receptacle to see if it works. If it doesn't, check your home's circuit breaker panel for a tripped breaker. If you find one, make sure there's nothing still plugged into the offending receptacle and reset the breaker. Then, plug the heater in and turn it on. Does it trip the breaker again? If it does, there's some type of short in the electrical system of the heater. If it doesn't trip the breaker, but still doesn't work, return it to the place of purchase for a replacement. However, you must have your Proof of Purchase Receipt to do this.
Hope this helps solve your problem.
Posted on Feb 17, 2011
Half oven is working microwave oven is not working
You can buy it from Sears for $52.00 or you can call 1-800-330-9707 and they will mail you one free.
Dec 31, 2013 | Apollo Half Time Convection - Microwave...
My sunbeam mixmaster is about 40 years old and suddenly stopped working
The running capacitor finally died. I used to be their factory service tech. You can change it easily by removing the back knob and the handle. The screws are under the silver buttons. The capacitor looks like a 3/4 x 1 1/4' tube with a small nib sticking out each end.
Dec 26, 2012 | Sunbeam 2366 MixMaster Series Hand/Stand...
My sunbeam large room ceramic heater just stopped working, I havent even had it for 2 months what can I do
Can't you exchange it at the store where you bought it and get a different one? It certainly shouldn't stop working after only two months of use.
Nov 26, 2012 | Heating & Cooling
I have have my sunbeam electric heater model number sfh090 for a month now and it just stopped working and wont turn on or anything! i tried leaving it unplugged for a while then plugging it back in but...
Feb 17, 2011 | Sunbeam Heating & Cooling
Greetings, I purchased a full size heated mattress pad with a single off-hi-lo-off control switch several decades ago and the fabric covering the heater elements has deteriorated thus exposing the...
I don;t think there is any repair that is possible and you will need to replace your mattress pad. I would recommend you contact sunbeam directly at sunbeam.com and see if this model has a lifetime guarentee.I tried but they wanted to know how old it was and other info that I could not provide.
If you have had this good of service from their product then I would let them know and maybe they will work with you.
I have had good results contacting companies and praising their products and it don't cost much to try. Thank you
Jan 16, 2011 | Sunbeam Heating & Cooling
I have a 13 month old apartment size Magic Chef refrige. It stopped geting cold about 1 month age. I uplugged and it work fine for until now. Same thing. Left it unplugged for a while and now it works...
The fault is very much with the auto defrosting of your fridge. When the firdge stops cooling you are unplugging the fridge to allow it to defrost. As there is so much frost in the cooling coils there will not be any convection of the cool air from the coil as it gets blocked. So after defrost the coils get cleared and works fine till the next time frost appears. So first of all remove the freezer compartment rear covers to access the cooling coils, check for break in wires to thermostat, to the deffrosting heater or open coils in the heaters.Now trace the wires to the defrosting timer which is a 8 hours timer for defrosting the coils by the heaters. You can see if the timer is working. Now one of these could be the culprit but you will have to make sure by testing each one and confirming before replacing. Please do this step by step. Hope you get it right. If not familiar get help. Good day
Aug 03, 2010 | Magic Chef CTB1821AR Top Freezer...
Sunbeam water cooler SA12587 - no hot water
I have a Sunbeam water coooler YLR2-5 87H
My water cooler is not cooling at all. What should I do?
Nate 901-754-0028 or nstclair1@aol.com
May 11, 2008 | Refrigerators
The fan and the heater do now work !
check for a tripped overload. reset or replace it.
Nov 22, 2007 | Clairion Convection Heater - HC-1500
Heating & Cooling Logo
361 people viewed this question
Top Sunbeam Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Are you a Sunbeam Heating and Cooling Expert? Answer questions, earn points and help others
