Question about HP OfficeJet 6110 All-In-One InkJet Printer
My scanner is not working...The printer is working properly. When I click on the Scan button it asks me for a source but i have no sources as an option.
  • 827 Answers
The all in one solution software you used in XP doesn't work fully with Vista.
But you can still scan and copy by using Windows Photo Gallery.
1. Click on files tab at the top in Window Photo Gallery.
2. Click on import from camera or scanner.
3. Highlight your scanner icon (ie HP OfficeJet 6110) then click import.
4. New scan window will popup, now you can preview or scan using this basic looking Vista utility.
Hope that helps.
Chris (ziraffa)
Posted on Jan 08, 2009
Film scaning options are missed in Select Source
I had the same problem. My solution is: "Just go to settings on Canoscan Toolbox. Then go to copy button, drop down and select scan2. This comes "Copy" as default setting. Change it to scan2. Click ok. On Canoscan toolbox main interface click scan2 and bingo, you'll see film option on select source . Hope this works
Jan 30, 2011 | Canon CanoScan 4200F Flatbed Scanner
How can I save a scan to my computer? I just got a printer/scanner and there are no Save, or Save As options in the HP scan software?? Help!!!
I would like to know the following, please get back to me
* HP Printer model
* Operating System
* Is the HP Software installed..
as a work around you can perform the steps below to save a scan in the computer.
Try to scan using one of the two methods below:
1. Scanning from Microsoft Paint:
Click Start, click All Programs, click Accessories, and then click Paint.
Click File and then click From Scanner or Camera.
If this option is not available, Please let me know.
If more than one image source is connected, select the
HP all-in-one product and click Next. The scanning software will appear.
Preview the image by selecting Preview, or click "Scan" to scan the image directly into Paint.
The image will open in paint for editing and/or saving.
2. Using Windows Image Acquisition (WIA)
Verify that the all-in-one product power is turned on and the printer cable is properly connected.
Click Start.
Click Control panel.
Click Scanner and Camera Wizard.
Follow the Scanner and Camera Wizard instructions to scan images to the computer.
May 20, 2010 | HP Office Equipment & Supplies
CanoScan LiDE 30 Flatbed Scanner: When I click the scan button it says, "Cannot find...
Make sure the USB cable is properly connected at both ends. Close the Canoscan software and then reopen it and try again.
May 18, 2010 | Canon CanoScan LiDE 30 Flatbed Scanner
I have installed scanner and disc but cannot find how to use it.I found the test box and that works but now how do I scan?thanks
Canon and other Scanners have both hardware and software buttons to scan documents and photographs.
Scanning with a computer is done with a destination in mind. So the buttons and the software are associated with destinations.
Typical destinations are File, email, Application, and print.
In a simple scan process for copy or print, the item is placed face down on the scanner, then the print button is pressed on the front of the scanner.
The software for the scanner pops up on the screen and the scanner moves the imaging light across the scanner under the glass, reading the item on the scanner. The software sends the image to the default printer and it prints a copy.
You will need to setup your preferences in the software so that a photograph is scanned properly and a newspaper article is scanned to come out clear black and white.
Documents are best saved as PDF files and photographs as TIFF files.
The software will have an expert mode where you can change all the settings and a beginner mode where you let the software decide.
Canon has a great document for your scanner. If it is not on the disk, here is the link. It is called CanoScan 4200F Scanning Guide. I think it will help you to use the scanner for any task.
Apr 24, 2010 | Canon CanoScan 4200F Flatbed Scanner
In clicking "copy", I am now being asked to "select source" when I never was asked before. Same with "scan" which now wants "specify program" that was never asked before. Why?
Source is the Scanner... you must select it from a list....the program, is like Word, Adobe,etc, it wants to know what "Format" to save it in.
Feb 27, 2010 | Canon CanoScan LiDE 500F Flatbed Scanner
My printer v305 wont scan I get a message that says cannot retrieve program When asked to scan to computer
Looks like scanning software is not installed.
Please click on the link,
Choose your O/S
Download the software and install.
Try scan from the mrnu
Make sure the scanning source is the scanner.
Hope this will work for you.
Good Luck
luciana44
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=555&l=en&s=biz&ServiceTag=&SystemID=PRN_INKJET_V305&os=WLH&osl=en&catid=&impid=
Dec 21, 2009 | Dell V305w All-In-One R840635AU InkJet...
Dell 810 all in one printer/scanner not scanning
scanning is a bit of a trick. You have to have hardware to scan with, and SOFTWARE to receive images. Make sure the scanners imaging software suite has been installed, OR, you can use the scanner manager in windows to scan with. Just select the dell 810 as the "scanner source" and click "scan". that should do it.
Oct 26, 2009 | Dell 810 All-In-One InkJet Printer
I dont know how to scan of my Lexmark x7350
Assuming the Lexxy software drivers are properly installed you simply load up whatever software you want to scan into (paint shop, word etc...) and import from the scanner. Depending on the software you will use either the "import from..." or "acquire" menus items (look through the menus of the particular software you are using). You will get a submenu asking for the source. From this you select "scanner" or "twain". This will invoke your scanner software and from there you follow the prompts.
Sep 14, 2009 | Lexmark X7350 InkJet Printer
In Canon MP160 i dont want to use its printer so is it possible to use only its scanner even it has dry or dammy cartaige?
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
ptttq15
Jun 16, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Epson Stylus DX4450 scan macintosh problem
Trash and re-install the drivers.
To uninstall the drivers:
- trash epson scan and epson scanner monitor from applications.
- go to library, then application support, then trash epson scanner module.
- go to library, then image capture, then trash twain data sources.
- go to the harddrive. Then to users, then click on the name of your computer. Then click on library, then preferences, then epson, then trash epson scan.
Then log on to epson.com and get the compatible driver for 10.5.6. Install it on your computer.
Jan 26, 2009 | Epson Stylus Multifunction Inkjet Printer/...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
