Question about GE Nautilus 24" Built-in Dishwasher
My dishwasher does not completely drain after a wash. what do i do?
  • wkbrass Jan 12, 2009
    I have the same problem.  I recently purchased a 4 year old foreclosure.  I quickly discovered that after a wash cycle, the bottom of my dishwasher was still filled with dirty water from the wash. Luckily, my dishwasher (Quiet Series II) does have a "cancel / drain"  button.
    So in my attempt to solve the problem,  I upgraded the the gargage disposal (it needed it anyhow, but not nessessarily needed).  During the process, I ensured that the knock out plug WAS removed, and I inspected all the hoses.  With the hoses disconnected, I pulled the dishwasher out (only had to remove two screws) and ran the cycle with the hose directly draining into the sink.  EVERYTHING worked perfectly with no water remaining in the bottom.
    Now I did note one possible problem that the builders (CENTEX Homes) failed to install the drain hose through the top of the cabinet wall (this prevents water siphoning backwards).  The hose was routed through the bottom of the cabinet wall and they used an air gap instead.  I easily drilled a new access hose at the top of the cabinet wall and reattached the hoses as they were before.  Then I ran the cycle again and the problem resurfaced!!
    This is still an ongoing trouble shooting process and my next step is to check the filter on the dishwasher for blockage (didn't before because everything worked fine during the previous test), and I plan to bypass the air gap all together by connecting the drain hose directly to the garbage disposal (as every other connection I seen in the past).  I really think this is the problem area.  I'll try to note if this works or what my next step will be.  Hope it helps you solve your problem, but circumstances are often unique.
    Master:
  • 623 Answers
  1. Check for hose kinks or food plugging drain hose. Start at the drain port exit
  2. Check the check valve and drain hose for debris.
  3. Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
  4. Check timer for not letting the dishwasher pause. ( not all dishwashers )
  5. Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
  6. If you have recently installed a new garbage disposal, check knock out plug at connection.
  7. Check pump impeller for damage.
  8. Check that the water inlet valve isn't seeping fresh water into the dishwasher when off
Posted on Jan 08, 2009
  • liamalexande
    liamalexande Jul 12, 2012
    how do i check the drain pump]
Sears kenmore elite dishwasher does not drain completely
Look at the control panel and you will see a button that says "Cancel" and "Drain" Press the button after the wash cycle has completed and the machine will drain completely.
Dec 28, 2016 | Kenmore Dishwashers
I have a Fisher Paykel DD24 dishwasher and when using top drawer after wash cycle is complete there is always water in drawer. Top drawer is unable to drain water after wash cycle is complete...what can I...
If the cycle is complete and dishes are clean, then you need to worry. Try to pull the drain hose up a bit under the sink. Also buy a Finish dishwasher cleaning kit and run dishwasher as per instructions on the kit. That should clean any obsrtuctions in the drain side.
Nov 20, 2013 | Fisher and Paykel DD24DCX6 Dishwasher
Water does not completely drain after a wash cycle. Everything else seems to work just fine.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Jun 16, 2011 | Frigidaire FDB1100RHM Builtin Dishwasher
Frigidaire Dishwasher model FGBD2431KW will not completely drain after wash cycle. What might cause this?
Hi
Daniel
Jun 15, 2011 | Frigidaire Dishwashers
Water is not drain completely after wash.
Thank you for contacting fixya.com.
There are various factors when a dishwasher wont drain water completely.Such as clogged drain hose,worn belt,pump assembly,bad motor,defective timer,drain valve etc.Please check the bellow links to read the article thoroughly to troubleshoot your problem:-
http://www.partselect.com/dishwasher+water-wont-drain+repair.htm
http://www.repairclinic.com/Dishwasher-Troubleshooting?red=Dishwasher-Repair-Help#thewaterdoesntdrainfromthemachine
Please get back to us if you have further query else please accept the suggestion.
Jun 01, 2011 | Miele 24 in. G870 Built-in Dishwasher
After wash complete unit will not drain complete, water remains in filter trap. this water will smell after a short time.
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 06, 2010 | Bosch Dishwashers
Food particles are on dishes after washing
Try adding bicarb of soda/baking soda and vinegar in the detergent dispenser. Bicarb fizzes off hardened particles and vinegar strips off grease and aids rinsing.
Jan 26, 2009 | Maytag 24 in. PDB1420 Built-in Dishwasher
Dishwasher not completing the programed wash, Now won't restart.
There is not a reset button, but you can try by holding both drain and one of the wash cycle.. hold it for a few seconds.. keeping trying drain and another, and another.... you will hear drain motor draining water out... if there is standing water at the bottom... if the cycle stopped after wash cycle, its usually your control... hope this help...
Jan 11, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Kitchenaid dishwasher - water standing at end of cycle
less than 2 cups of water in left after cycle complete
Dec 02, 2007 | Siemens 24 in. SE25A266 ExtraKlasse...
GE Nautilus 24" Built-in Dishwasher Logo
396 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
