Question about SanDisk Sansa e250 MP3 Player
Two problems with my mp3 player
When I tried to format my player it said "the device was unable to complete the format" Also, when I tried to put a song on my mp3 player that was already in mp3 format with windows media player, it says "Windows Media Player encountered an unknown error. This can occur when another program or operating system component encounters a problem but does not communicate the nature of the problem to the Player." What should I do??
  • 1 more comment
  • Anonymous Mar 16, 2008
    i pressed format and it deleted all music
  • paris lamar
    paris lamar May 16, 2008
    every time i turn on my sansa e250r it says not enough space for music db please free up to 4mb
  • Anonymous Feb 02, 2009
    Thank you so much, Syd! I thought I had an indestructible virus or something. You're smart AND pretty! Thanks again.
    Scholar:
  • 47 Answers
Hi Mina. An internal memory corruption might have occurred on your player, and would need to format your player through "Disk Management" (I'm assuming you have Windows XP or Vista). Here's how: (1) First, set your player to MSC mode by navigating your menu as follows: Menu >> Settings >> USB Mode Choose "MSC" (2) Open "Computer Management" by right-clicking on the "My Computer" icon, then selecting "Manage" (3) Your "Computer Management" window should be divided into 2 panes. On the left pane, click on "Disk Management" (4) On the upper right pane of "Disk Management", you should find the drive letter corresponding to your Sansa E250. The lower section also contains the drive # pertaining to your E250. Right-click on either drive letters pertaining to the E250 and select "Format". Follow the on-screen prompts. Make sure that the "Quick Format" checkbox remains un-checked. In general, Disk Management is more the effective tool for formatting your E250 and assuming the format processing completed without any errors, you may now use your player as you would. You may want to set the mode of your MP3 player back to "MTP" (if you're going to download subscription songs -- otherwise, just leave it in MSC mode) by navigating your menu as follows: Menu >> Settings >> USB Mode Choose "MTP" In case you get the error "Unable to Complete Format" or the format process is unable to complete, you may want to call the SanDisk Tech Support guys for more advanced troubleshooting (I call `em when I'm at my wit's end lol) I hope it works :)
Posted on Jun 02, 2007
It works! Thank you, Syd!!!
Posted on Mar 16, 2008
SOURCE:
Error windows was unable to complete the format
I experienced the same problem (my USB device ). try these steps:
1. Start, Control Panel,
2. Performance and Maintenance,
3. Administrative Tools,
4. Computer Management,
5. Disk Management,
6. Find the USB drive (usually the last storage device before the optical drive),
7. Click on the USB drive,
8. Right click on it and you will see the options (New Partition or Format)
9. Follow the instruction (I chose FAT32), but please do NOT chose Quick Format.
Feb 26, 2014 | SanDisk Sansa Fuze MP3 Player
When I switch on & tune my MP3 player , it shows message " File System Error". The device is not working properly and unable play the stored MP3 songs.
the mp3 file has become currupt, simply plug back into computer, then format the player, you need to tell it to format in default!!
once formatted, remove the battery, put back in then put back in computer, then just put your desired songs on, this should sort out the problem!!
Apr 30, 2011 | Nextar MA933A MP3 Player
My mp3 wont format.
You are limited on how you can format the device without using command line parameters, but I assure you that needing to format the device is highly unlikely. The device needs a certain amount of available space to profile and create the database (stores the metadata about the media you have on the device to display it on the device). Try removing some media so that you have at least 50MB of free space (to be sure you have enough space available).
If this problem persists, then there is likely a file on the device that is corrupting the player or the flash itself has gotten corrupt, but based on the message you are being displayed, this too is unlikely.
Nov 30, 2009 | RCA M4204 MP3 Player
It is unable to format and it shows "device was unable to complete the format"
Go to my computer scroll to sansa or your MP3 player and open the music folder and open each sub folder and delete Songs manually then delete the folders them selfs then format a couple of times hope this works
May 24, 2009 | SanDisk Sansa e260 MP3 Player
Formatting problem
Hello Dear
#1
Insert your ( memory card , flash disk , cellphone , .... ) into your computer.
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Jan 16, 2009 | Creative Labs Zen Nano Plus MP3 Player
Sandisk sansa problem
It isnt a fat or fat 32 player..It is a mp3 and or a wma player. And you could be missing the proper device driver depending on your computers os..Pre 2000? file compression file format
Jun 29, 2008 | Mach Speed TRIO Onyx MP3 Player
Trying to format
Are you formatting thru My Computer? If so try using Computer Management. Right click on My Computer and select Manage. On this window select Disk Management on the left. On the right side at the top, your drive should be listed. Right click on the device and select format. If your device does not show up, change the devices mode and try again. Device>Settings>Mode or USB Mode. Best of Luck.
Sep 20, 2007 | SanDisk Sansa E280 MP3 Player
Internal memory and fomatting problems
Here you go http://www.mympio.com/index.php?topic=15.0
Apr 18, 2007 | Mpio FY500 MP3 Player
Problem With Format
Hi, you may want to try using the manufactures preferred method or better still update the firmware. It is available at http://www.sandisk.com/Retail/Default.aspx?CatID=1376. Please let me know if this woprks out ok with your Sansa e260. Regards
Apr 09, 2007 | SanDisk Sansa e260 MP3 Player
Unable to format
Try this http://www.mympio.com/index.php?topic=15.0
Jan 22, 2007 | Mpio FY500 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
251 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
