Question about Indesit W 123 Front Load Washer
Indesit WM12x washing machine won't spin or empty properly
We had a frozen waste pipe and the washer was on at the time. We've now cleared the frozen pipe, but we appear to have a problem with the washer. The spin does not work correctly - following a couple of spins the dial turns around clock-wise. Likewise a full wash will start, but doesn't drain or spin properly. We've switched off at the mains (and back on again), and also emptied the filter.
Any suggestions to fix and/or a link to a user manual would be greatly appreciated .
SOURCE: Washing Machine not draining
same thing happened to me but the obstruction was in the hose at the back of the filter and coudnt be seen in the filter. i paid 150euro to engineer to fix this. i watched him fix it and can do it myself now. they rob you for something that is so simple to fix.
Posted on Sep 26, 2007
  • 1294 Answers
SOURCE: Filter on indesit washing machine
Push panel right or left side. Unscrew or turn anti-clock wise, according to your model. Be prepared for some water. Pull this out and clean, refit carefully. Of course it is meant to be removed and cleaned periodically, according to usage. Rate me pl.
Posted on Dec 01, 2007
jason0110
  • 66 Answers
SOURCE: indesit w123
not really worth replacing timer as many problems can cause this
Posted on Jun 15, 2008
  • 1294 Answers
SOURCE: hi i have a wm12x
You have to check the pump for anything clogging it.
Posted on Jun 16, 2008
barkencoa
  • 3463 Answers
SOURCE: indesit wil 133
The filter is located behind a removable plastic panel on the bottom front of the m/c.
Posted on Dec 02, 2008
MY WHIRLPOOL WTW5300SQO WASHING MACHINE WONT DRAIN WATER THE OTHER DAY IT WOULD NOT SPIN TO WRING THE CLOTHING THERE WAS A SMALL GARMENT LODGED IN THE SPIN BASSIN(?) WE TOOK IT OUT NOW THE WASHER WILL NOT...
Could be filter is blocked. Or drain pipe is blocked.
Fact it wouldn't spin, could point to blockage, as spin won't start if too much water in drum. Bad news is, it could be the water pump needs renewed.
Make sure drain pipe is properly connected to the waste pipe, and clear of obstruction.
Jan 16, 2013 | Washing Machines
Washing machine problem
What do you mean by not spin properly ?
Jul 22, 2007 | Hotpoint BWM20 Front Load Washer
Indesit iwe8123 not spinning
Its an old belief that the motor is at fault when a machine doesnt spin on full speed.
Most of the time its because its not emptying properly. Firstly check the filter for any blockages and if thats clear unplug the machine and tilt it over so you can see the pump. If your not sure which is the pump then follow the drain pipe in from the back and what that connects to is the pump. You will have to remove the pipes from that and make sure they are clear and also the pump if possible. If thats all good then it may be a carbon brush problem in your motor thats at fault. That is an easy job even for a novice. If you get no joy with the pump then let me know and i'll talk you through that too.
Nov 11, 2011 | Indesit W 123 Front Load Washer
HELLO MY WASHING MACHINE WM12X INTEGRATED INDESIT MACHINE WAS SPINNING AND WE HEARD LOUD BANG ... THE WASH FINISHED OK BUT NOW THE DRUM WHEN EMPTY SEEMS TO BE "CATCHING" WHEN SPINNING BY HAND. ...
open the back door try to remove the belt and then try to rotate the drum by hand if it stuck again you need to check if there is something between the drum and the chamber
Jun 10, 2011 | Indesit W 123 Front Load Washer
I have a indesit wm12x washing machine and i was told it is a dryer but i can not get it to work please help
I have been looking at your machine on internet and found out that the indesit model you have is not the washer dryer version it is a washing machine so has no dryer function. hope this helped.
Sep 19, 2010 | Indesit W 123 Front Load Washer
Manual for intergrated indesit wm12x washing machine
To obtain the instructions for washer, go to,
WWW.INDESITSERVICE.CO.UK
In the menu on the left click on Indesit user manuals, then enter the model number in the search box, and down load the instructions to your printer or hard drive.
Please rate my solution.
Thankyou.
Jan 13, 2010 | Indesit W 123 Front Load Washer
Indesit washing machine not spinning - fault code timer and dor lock light flashing
my indesit washer/dryer wd12x programme dial goes all the way when it reaches spinning
May 30, 2009 | Indesit W 123 Front Load Washer
Indesit wil 133
Apr 16, 2008 | Indesit WA 125 Front Load Washer
INDESIT WM12X
brushes in your motor almost certainly, put your meter across the motor you will find a open circuit failinf that your control module could be damaged
Apr 21, 2007 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
613 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
