Question about Epson Stylus RX425 Multifunction All-In-One InkJet Printer
All in one printer, scanner and photocopier wont work?
Why wont my all in one printer, scanner and photocopier wont work?
    President:
  • 8,637 Answers
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 24, 2009
How do l unlock scanner the printer is no longer photocopying
There is usually a manual sliding switch to rear of machine that is used to lock scanner head for transportation.see if it has been switched to the padlock symbol.
Jan 24, 2015 | Office Equipment & Supplies
I have 3 in 1 printer with photocopy and printer and scanner but the scanner doesnt work
reinsall scanner drivers again or scanner drivers didnt match with your operating system
Mar 22, 2011 | Office Equipment & Supplies
Scanner function does not appear to work. All
i would say possibly you are missing out on something..because if the other functions particularly photocopying are working then this should work..as in if the photocopying function works then the scanner is ok cause basically in photocopying the machine scans then prints... perhaps check whether you are correctly following procedure to scan..most hp all in ones have a button on them that you press and it automatically initiates scanning and simultaneously the software on the pc is initiated..try this,if not then try reinstalling the hp software..hope this helps..regards
Jun 04, 2010 | HP Photosmart 2575 All-In-One Printer,...
It works very well as printer or photocopying but not as scanner
Might be scanner drivers corrupted, Reinstall the Scanner drivers again. Most probably this will work greatly You can try this no (877-690-9305) for the solution. Support For Hp Printer
Dec 24, 2017 | HP DeskJet F380 All-In-One Printer
My printer works as does the photocopier but the scanner wont scan to the PC
My copier and my fax function work but the scanning function does not work. My computer previously crashed and I downloaded what I think was the correct driver. I have a multifunction MP530 unit.
Nov 06, 2009 | Canon Office Equipment & Supplies
Printer/scanner/photocopier. scanner not working. Any ideas?
Are you scanning to your computer? If you are getting an error during the transfer to your computer, check your firewall. I had a scanner (mine is a Panasonic) problem with the transfer to my computer. I corrected it by printing the properties of the scanner and found out the port number that the scanner used and opened the port in the firewall. Hope it helps.
May 04, 2009 | Office Equipment & Supplies
Lines rule across my print out paper at photocopying mode
Make sure you don't have a scratch on the glass of the scanner. If you have a mark, or scratch that matches the line ruled on your print, then there is your problem.
It;s also possible the scanner is jerking as it goes across the bed, which is causing the line. Is the line solid, dashed, bold, thin or just kinda there?
Mar 14, 2009 | HP DeskJet F380 All-In-One Printer
Cannot scan to pc
my MP 160 cannot scan to pc, but can print and photocopy well. it says it cannot communicate with scanner..cable might be disconnected or scanner might be off..tried uninstalling and reinstalling..still doesn't work
May 21, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Hp 1317 psc
you didn't describe your problem briefly. 1. Check if you photocopy anything, it is coming out correctly you are doing. it means your scanner is perfectly allright. 2. if you are not able to photocopy with this printer, it means your scanner is not working properly. But if it photocopying properly and in windows it is not scanning it means software is not working properly, try to arrange new software from anywhere and try.
Sep 24, 2007 | HP PSC 1315 All-In-One InkJet Printer
Epson Stylus RX425 Multifunction All-In-One InkJet Printer Logo
81 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
