Question about Motorola Mobility H300 Wireless Headset
Need to setup H300 bluetooth to my LG VU phone! How do I do this?
I need help to setup my H300 bluetooth to my LG VU phone and I lost my instructions can anyone help?
The quick answer is that you can put it into pairing mode, and your phone should recognize it. To put into pairing mode, push and hold the large power/answer button for at least 6 seconds. The light will start flashing, indicating that it is in pairing mode. Go into the Bluetooth menu on your phone and make sure Bluetooth is turned on, that your phone is visible, and that you can search for new headset devices. Make sure the headset is still flashing. When you discover the headset in the phone, it may prompt you for the code. I believe the pairing code is "0000". Add the device to the phone. You should now be able to use it with your phone.
If this doesn't get you there, do a search for H350 Manual to get a pdf of the user manual and quickStart guide.
Posted on Jan 12, 2009
LG Vu CU920
you can buy a "Puck" for $99.99 from AT&T that you connect via Bluetooth that will provide GPS for the LG Vu
i hope this will work for u
Jun 26, 2009 | LG Vu CU920 Cellular Phone
Can I sync my LG VU with Microsoft Outlook? If
Hi, you're right you'll need usb cable however bluetooth can be used as well.The usb cable is supplied with the phone. Vista use the new Windows Contact and Windows Calendar,but you can use MS Outlook if installed and you'll need MS IE v6.
Rate me if helped.Thanks.
Jun 18, 2009 | LG Vu CU920 Cellular Phone
Won't connect to trueblue bluetooth
my friend found her book with the instructions. You have to turn the phone on. Make sure the bluetooth is enabled. Then hold the power button on the bluetooth down until the red and blue lights flash back and forth. then try to discover it on the phone. it works!!!!!!!
May 11, 2009 | LG Vu CU920 Cellular Phone
LG VU does not recognize my blue tooth while trying to pair two
Help my pair my bluetooth with my LG shine phone. I have a jawbone bluetooth.
Mar 23, 2009 | LG Shine KE970 Cellular Phone
I have a LG scoope that I'm trying to hook my motorola H350 up to it. I lost the instructions and I don't really know if it will go with it. I need help!!!!!!
Jan 12, 2009 | Motorola Mobility H300 Wireless Headset
I have somewhat of a solution. when you go to www.att.com/BluetoothWizard, it will prompt you to put in the handset Make & Model and then proceed with the Make/Model of your Bluetooth. It is possible that your Bluetooth headset may not be compatible with the LG Vu.
Dec 09, 2008 | LG Vu CU920 Cellular Phone
LG VU CU920 Sync Software
You don't need software to transfer files. Here is what you need to do.
Go into your phone settings.
Click on Connection
Select USB Connection Mode
Select Mass Storage (You MUST have a 1g memory card or larger in the phone)
Connect the USB to your phone and your PC
Viola! your pc should recognize it as a mass storage device. Put files where you want them etc.
Good luck.
Aug 26, 2008 | LG Vu CU920 Cellular Phone
Pairing bluetooth with new phone
You have to hold the on button until it is a solid blue light not flashing 5 or 6 seconds then it is ready to be paired.
Jun 21, 2008 | Motorola Mobility H300 Wireless Headset
Motorola Mobility H300 Wireless Headset Logo
315 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
