Question about Mercury Electronics CyberPix S-550V Digital Camera
Flash light problem
The flash light of my camera doesn't cover all the selected view to be pictured.it implies a green shadow on some or most and sometimes all of the taken picture.
  • LAITH KALIAN Jun 04, 2007
    attached is a picture taken by my camera showing the exact case.one more thing to add here is that when i take a picture with the fladh on,i hear the click of the flash one second earlier than click of the shutter.(note that he attatched picture is resized to be less than 150 kib)
My flashlight does not flash at all and is cyberpix s-551v
Posted on Jul 12, 2008
  • 883 Answers
Try different aperature settings, either faster opening or slower opening
Posted on Jun 02, 2007
By using the flash, I get a shadow around the right side of peoples faces, doesn't happen when not using flash, but color is not as good.
Are you new to photography? The flash emits an intense light and depending on where it is found on the camera in relation to the lens, it will cast a shadow on one side or the other. DSLR cameras solve the problem by mounting an external flash directly over the lens and high up so the shadow is less noticeable. If you take a lot of people's faces, you might want to explore "fill lighting".
Jun 24, 2011 | Cameras
Tip
Tips for camera
Using the camera:
Your phone has a flash to help you to take pictures in different lighting environments. The flash is on by default, but you can turn it off or use the automatic setting. To set the desired mode when using the camera, select Options > Flash and Flash off, Flash on or Automatic.
Fast viewing with memory card To view your images and video clips quicker, use your memory card as the main memory for storing them.
In the camera application, select Options > Settings > Image / video storage > Memory card.
Capture and send You can send the picture immediately after you have taken it when you are previewing it. To display a picture immediately after you take it, select Options > Settings > Image preview time and the preview time. During the preview time, select Back to take another picture, or Send to send the picture as a multimedia message.
Print your images Your phone supports Nokia XpressPrint to print images that are in .jpg format. To print your pictures, connect your phone to a compatible printer using a data cable or send the image by Bluetooth to a printer supporting Bluetooth technology. Select the image you want to print from the Gallery, and when viewing the picture, select Options > Print.
on Jun 13, 2010 | Nokia 6500 Slide Cellular Phone
Don't know what buttons on back of camera are for.
Besides the auto-flash mode, you can select fill flash, flash off, self-timer, and nighttime-view with or without flash.
Press the MODE-SELECTOR BUTTON until the desired indicator appears on the LCD PANEL.
c3015.gif Fill flash and flash off modes remain selected after you take the picture. To cancel the selection, press the mode-selection button or close and reopen the lens cover/flash to return to the auto-flash mode.
Fill flash
c3014.gif When bright light indoors or outdoors comes from behind the subject (backlighting), dark shadows (especially on faces) may occur. Use fill flash to lighten these shadows.
  1. Open the LENS COVER/FLASH to raise the flash and to turn the camera ON.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the FILL-FLASH INDICATOR appears on the LCD PANEL.
  3. Frame your subject within the VIEWFINDER EYEPIECE.
  4. Partially depress the SHUTTER BUTTON. When the FLASH/CAMERA-READY LAMP turns off and the fill-flash indicator on the LCD panel stops blinking, fully depress the shutter button to take the picture.
Flash off
c3013.gif When you do not want to use the flash, especially indoors where flash is prohibited, such as in theaters and museums, or when you want to take twilight scenes or distant subjects that are beyond the flash range, or capture the ambiance of existing light, use the flash-off feature. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed in these situations will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the FLASH-OFF INDICATOR appears on the LCD PANEL.
  4. Press the SHUTTER BUTTON to take the picture.
Self-timer with auto flash
c3016.gif Use this feature to include yourself in pictures.
  1. Use the TRIPOD SOCKET to attach the camera to a tripod or place it on another firm support.
  2. Open the LENS COVER/FLASH to raise the flash and to turn the camera ON.
  3. Press the MODE-SELECTOR BUTTON repeatedly until the SELF-TIMER INDICATOR appears on the LCD PANEL.
  4. Frame your subject within the VIEWFINDER EYEPIECE.
  5. Press the SHUTTER BUTTON. The SELF-TIMER LAMP will glow and then blink during the last three seconds of countdown.
    • To cancel the self-timer selection before the shutter releases, close the flash.
    • The self-timer automatically turns off after the shutter releases.
Night-view with flash
c3012.gif In this mode, the camera balances the flash and existing light exposure so you can take beautiful pictures of people at sunset or at night. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed at night will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the NIGHTTIME-VIEW INDICATOR with flash appears on the LCD PANEL.
  3. Frame your picture in the VIEWFINDER EYEPIECE.
  4. Press and hold the SHUTTER BUTTON for 12 seconds without lifting your finger. Note: If you remove your finger from the shutter button before 12 seconds, the shutter will time out immediately.
  5. After 12 seconds, release the shutter button to take the picture.
Night-view without flas
c3011.gif In this mode, you can capture the natural existing light of city-night scenes or fireworks at night. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed at night will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the NIGHTTIME-VIEW INDICATOR without flash appears on the LCD PANEL.
Jun 17, 2010 | Kodak Advantix C400AF APS Point and Shoot...
Screen black in all lighting. Icons and Menu show but screen otherwise black in all modes. Can view photos on card. Can take a picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Hello, I went and researched a few points in the manual and hope this helps to some extent. If this doesn't help, try resetting your camera by removing the batteries for 30 seconds, then reinstalling them and turning on the camera again.
Monitor is blank:
• Camera is off.
• Batteries are not correctly inserted or battery-chamber
cover is not properly latched.
• Batteries are exhausted.
• EH-62B AC adapter (available separately) is not properly
connected.
• Camera is in sleep mode. Press shutter-release button
halfway.
• Monitor is off.
• USB cable is connected.
• AV/Video cable is connected
No picture is taken when shutter release button is pressed:
• Camera is in playback mode.
• Red (!) lamp flickers: flash is charging.
• Green (AF) lamp flickers: camera unable to focus.
• Message "CARD IS NOT FORMATTED" appears in
monitor: memory card is not formatted for use in your
camera.
• Message "OUT OF MEMORY" appears in monitor:
insufficient memory to record picture at current Image Mode selection.
Dec 02, 2008 | Nikon Coolpix 4600 Digital Camera
Canon 40D
Hey D1ppy,
There are two ways to get rid of shadows behind a subject, but both require you to use a hotshoe mounted flash. The first way is to bounce the light off a ceiling or some other white surface by turning the flash head towards that surface instead of your subject. The second way would be to connect the flash to the camera using a off camera flash cord and hold the flash above your head when your taking the picture, and by doing this you are able to aim where the shadows show up in the image. Bounced flash is what is called soft light and generally is more pleasing light. I of course am assuming the shadows are caused by the built in flash on the camera. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
May 30, 2008 | Canon EOS 40D Digital Camera
Polaroid Problems
If your having problems with your camera, for about 20.00 you can buy the same camera on Ebay.
Mar 05, 2008 | Polaroid OneStep AutoFocus Instant Camera
Shadows
Sounds like your lense cover is not fully retracting when you turn your camera on, thus when the flash goes off these are creating shadows on your picture.
Nov 23, 2007 | Panasonic Lumix DMC-TZ3 Digital Camera
Reduce shadow
All solid objects cast a shadow; it cannot be avoided. Certain techniques will help control or reduce the shadow by eliminating or reducing the harshness of the flash. Some of these techniques are: Elevate, eliminate or soften the flash: Make sure the flash is above the lens when you camera is turned to vertical (portrait) orientation. If the on-camera flash is higher than the subject, the lens should not "see" the shadow in most situations. Make sure the camera is higher than the subject, but not so high that you make a shadow in the other direction (under your subject's eyebrows, nose or chin, for example). If there is enough natural light, you might be able to turn the flash off, or you can add "natural" light to the scene by opening curtains, turning on room lights, and so on. In low light you can still photograph without the flash by making sure the camera does not move during the exposure. Consider using a tripod or monopod. The auto color balance feature should automatically adjust the color for the light source. Sometimes it is helpful (at least minimally) to include a white or near neutral grey item within the camera's field of view to assist the camera's color balance assessment. Mixed lighting gives mixed results. Illuminate, eliminate, or move away from the object that has the shadow cast upon it (a wall, for example). Or, use it to your advantage by angling for a better position that may bounce and diffuse the light from the on-camera flash by reflecting light off the wall. Some photographers might lay a white sheet in front of the subject to soften the light by bouncing the light off the ceiling.
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
Mercury Electronics CyberPix S-550V Digital Camera Logo
41 people viewed this question
Top Mercury Electronics Cameras Experts
Marvin
Marvin
Are you a Mercury Electronics Camera Expert? Answer questions, earn points and help others
