Question about GE DBSR453EBWW Electric Dryer
DRUM BELT BROKE
DRYER HEATS UP BUT DRUM WONT TURN, WHEN I OPENED UP THE TOP OF THE DRYER THE BELT WAS LAYING ACROSS IT BROKE
  • 979 Answers
To replace it won't be hard. Just make sure it is back on securely.
Posted on Jan 25, 2009
Dryer heats but doesn't turn.
Most likely the belt broke on the drum. Less likely the motor died. When turn the dryer on do you hear the motor running? If so you probably broke the belt. You will have to unlock the top and pull the front off. The belt rides around the drum towards the back of the dryer.
Jul 21, 2015 | Dryers
I have a GE Profile Prodigy eletric dryer that wont start. When I turn the switch it hums and stops when I let go of the switch, but won't start. Is that a switch problem or motor? How do I tell?
That sounds like to me the drum belt is broken..GE dryer use a belt switch that if the belt is broke will perform exactly as you describe ..as long as holding the start switch the motor will run and as soon as you release the start switch the motor will stop.
To check for a broken belt remove the top by removing the 2 phillips headed screws inside of the door at the top of it and pull off the top to see if the belt is in place and attached to the drum..if no belt seen when top off its broken and laying down in the base frame
GENE
Aug 28, 2011 | Dryers
My creda simplicity t622cw condenser dryer wont turn
Broken or belt has come off. If can open back and fix or replace. You may need to remove the top. Careful of the heat element, lift out drum and place new belt on motor holding it while you put the drum back keep hold of belt and place around drum replace top and should be ok. Hope this Helps
May 25, 2010 | Dryers
Dryer heats but drum does not turn when the start button is pushe
You need to check the drum belt. With dryer empty, reach in and give it a spin. If the belt is good, it will stop in 1/2 turn or less when released. If the belt broke, it will spin almost a full turn.
Oct 25, 2009 | Kenmore 62602 Electric Dryer
Wont turn.
the belt goes on over the drum and around the pulley under the drum you either have to take the top of the dryer off or the back panel to get at it
Sep 03, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Dryer drum stopped when too wet of clothes were put in. Smells like burnt smell. Dryer turns on and heats. Looked for belt but can't locate in Whirlpool dryer I have front off
you have to raise up the top and the drum will just pull off the belt is only about a 1/2 inch wide like a piece of leather possibly laying on bottom under drum
Jul 03, 2009 | Dryers
Dryer heats up, drum won't turn. any suggestions?
1. unplug dryer
2. popoff the top off
3. take front off (unscrew)
now you can get access to the belt look in bottom of dryer there is a giude wheel for the belt
4. place belt around drum and pulley make sure you add tenstion
5. replace front and top
Thank you for useing Fixya
Feb 12, 2009 | Bosch Axxis WTA 4107 Electric Dryer
DRYER HEATS ,BUT DOESN'T TURN
FIRST UNPLUG UNIT!!
Remove 2 screws by filter area on main top.
Grab back of dryer and pull top forward while holding dryer in place with knees. Do this to pop up top on front left then front right. Remove 2 screws holding front panel 2 side panels. They are at top front of side panels, inside.
Pull front panel out at top and pull up to remove front panel. Put belt around drum with grooved side toward drum.
Nov 11, 2007 | Whirlpool LGR3624JQ Gas Dryer
GE DBSR453EBWW Electric Dryer Logo
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
