Question about MSI (MS-P8148-050) (MSP8148050) CD-ROM Drive
Averatec (AV3715EH1) The computer cant locate the cd rom drive. went to put in the restore disk, but the cd drive will not open. went into the bios...it is not showing a cd rom drive, just the hard drive only. using windows xp, thanks Keith
  • Thomas F. Schneider May 11, 2010
    New problem, has see the cd drive before? Open the computer and see if CD rom drive cable is firmly attached to the board. If it is attached to the board on the same cable as the hard drive their is a jumper on the back of the cd drive that you must set to SLAVE.
    The hard drive also has a jumper that should be set to MASTER.
    Problem Solver:
  • 6 Answers
If the CD drive is not open then check the power cable for CD drive make sure the CD drive getting power from power supply.
Posted on Jan 08, 2009
Where is cd rom access
Try opening "my computer" window...right click on cd drive then click on eject...the drive will open.
once you've found your drive you'll see a small button on the front of it...press once to open
Oct 13, 2012 | Medion Computers & Internet
I have an Acer Aspire 5332 and the CD-Rom/DVD Drive (Optiarc DVD RW AD-7580S ATA Device) is not working properly...every time I put a disk of any kind (i.e CD/DVD/Game) it doesnt recognize it and load
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
Mar 22, 2012 | Acer Computers & Internet
I have an advent modena, and it seems the drivers for the cd rom has been disabled because i cant locate it in device manager and drive slkmvyre FVFC "DS8C4S" shows its disabled. the CD ROM cant...
just matter of interest , check the bios setting, goto device manager and delete the CD Drive, reboot, still the same problem then it a hardware issue,
the drive could be jammed.
Aug 20, 2011 | Advent Modena M101
Can't get into any folder because c:Windows/System 32/rundll32 .exe keep popin up
To resolve this issue, follow these steps:
1.
Put the Windows XP CD ROM disk in the CD ROM drive.
2.
Click Start , and then click Run .
3.
Type expand X :\i386\rundll32.ex_ c:\windows\system32\rundll32.exe in the Open box, where X is the letter of your CD ROM Drive.
4.
Restart the computer
2.
3.
4.
1) Put the Windows XP CD ROM disk in the CD ROM drive.
2) Click Start , and then click Run .
3) Type expand X :\i386\rundll32.ex_ c:\windows\system32\rundll32.exe in the Open box, where X is the letter of your CD ROM Drive.
4) Restart the computer.
Oct 27, 2010 | Computers & Internet
How do you Reboot a computer back to factory setting
Instructions Things You'll Need:
  • Factory Settings CD
    How To Use the Restore Factory Setting CD
  1. Step 1 Make sure to transfer all of the files you want to keep to a USB memory stick or burn to a CD.
  2. Step 2 Put the "Restore Factory Setting CD" into the CD drive. This CD was packaged with your computer.
  3. Step 3 Confirm you want to restore the factory settings. The computer will begin restoring all settings. Don't disturb your computer, as this process can take several hours. .
  4. Step 4 Reboot the computer to complete the process.
  5. How to Reboot Using the Computer Start-Up
  6. Step 1 Turn on your computer. Right away there will be a black screen. You can restore factory settings without a CD, too. This will reset your BIOS.
  7. Step 2 Press "F1" when the black screen appears to enter the setup configuration mode. You will be presented with a menu.
  8. Step 3 Select "Restore Factory Defaults." That's it. Your computer will do all the work for you. Like the CD, this process may take several hours.
Jan 27, 2010 | Computers & Internet
How i can restore my OS, it seems like is gone
Hi
You would have to use a restore disc that came with the computer or a windows installation disk.
I have posted a how to install windows XP guide:
http://www.fixya.com/support/r3575559-step_by_step_howto_install_windows_xp
How to install windows 7 / vista guide:
http://www.fixya.com/support/r3575598-step_by_step_howto_install_windows_7
Dec 15, 2009 | IBM ThinkPad T41 Notebook
Averatec 5100 series. the disc drive makes some clicking and other noises, but will not play disks. They are spinning some when I open it up. I am trying to play the recovery disks and can't
It is NOT NORMAL for a CD-ROM to experience any of the below symptoms.
  • No noise
  • Clicking during accessing the CD-ROM.
  • Noises when the CD-ROM is not being accessed.
If you are exhibiting any of the above issues it is likely that the CD-ROM drive is defective and it is recommended that it be replaced.
BEST REGARDS MICHAEL
Nov 11, 2009 | Averatec 5110HX Notebook
Averatec 3200, cant find DVD Rom driver in "My Computer" or "Device Manager" When I put in a CD I can hear the disk spinning but it never loads. I deleated the upper and lower filters and restarted the...
Make sure the BIOS is 'seeing' the drive. Reboot your pc, press F2 as soon as it starts to boot (Or watch your screen and the POST will display which function key to press to enter setup.) If the BIOS is NOT seeing the drive, you may need to a) replace the drivers for the dvd or b) replace the dvd rom itself. (I recommend the drivers first.) Please repost your results and we will continue to monitor your progress.
Good Luck
C2Solutions
Sep 04, 2009 | Averatec 3200 Notebook
Cd rom
Go into the computers bios at startup .
is the cd rom drive enabled and detected .
if not then open the case and check the cables to cd
Jan 09, 2008 | Compaq (120192-B21) CD-ROM Drive
Cd-rom/dvd-rom door won't open
Hi!This is not a big problem...All you have do is take a pin, needle or something and just insert it into the small hole near your cd-rom drive..try this repeatedly while pressing the eject button..If it doesn't work you will have to unscrew the two screws on the right of your keyboard..doing this will give you the access to the cd tray and you can remove the cd and put it back together..
Nov 13, 2007 | Averatec 3200 Notebook
MSI (MS-P8148-050) (MSP8148050) CD-ROM Drive Logo
123 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
