Question about Sylvania 6419TE 19" TV
Sylvania 31" console
Hi I have a sylvania model #RRK810-AK04 Chassis #31R1-01CC, with a very strange problem, I must admit all of the years of working on and repairing televisions, I have never seen this, when you disconnect power from the set, unplugging it, then plugging it back in it will not turn on, if you let it sit for a few minutes after plugging it back in, then hit the power button, the set will turn on and work fine, just when you lose or unplug the set and plug it back in it won't turn on for several minutes, very very strange! any ideas, I'm thinking possibly the E Prom?
CompuGuy44
  • 432 Answers
SOURCE: TV Turns off on its own
Just keep smack'in it around, it works for me. It is the 'protection overload circuit' taking over and shutting the TV set off. This is because it detected a short or near-short circuit somewhere. Most common is high voltage, deflection amplifiers and main power supply. It's pretty much a common fix for an experienced tv repairman. It might set me back in the ballpark of $200 - $300.
Posted on Jul 03, 2007
  • 4102 Answers
SOURCE: Sylvania 6520fdf
Hi this problem your having is the most common problem with tellys of this type youll find that its going to be either a transistor located near the transformer (fly back) or it could be the transformer but most of the time it is both that need replacing.
Most repair shops will replace both anyway as it is best to do this its not the kind of job a novice could do as it requires alot of soldering.
It is worth repairing and shouldnt cost to much as it is such a common fault so go ahead get it fixed let me know if you need further assistance ok
Posted on Feb 08, 2008
jingjao
  • 252 Answers
SOURCE: NO POWER
try to check the fuse first.
Posted on Oct 10, 2008
babygenius55
  • 96 Answers
SOURCE: Sylvania SRT2232S Powers On, No Picture, High Frequency squeal
Hello there. I'm sorry to say that it sounds as if the element that actually energizes your screen is bad. It is most likely overheating. or quite poosible the power converter lost a resistor or 2.
Posted on Nov 27, 2008
  • 10865 Answers
SOURCE: My problem is with my
Check the outlet to be sure you have power to it. Then check both ends of the tv power cord to insure that they are actually plugged in. good luck.
Posted on Jan 23, 2009
Need user manual for rk6070 ak04
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers, for spare parts and service, and Installation Instructions as required.
This is the best way of ensuring up to date drivers for your system and they are free of charge!
I hope this helps.
Jan 10, 2011 | Televison & Video
I have a Vodavi Starplus STS DHS 30 button setup. Trying to change Time/Date on the phone but every resource I see starts with the Feature [FEAT] button. My phones, admittedly a little older (5 years),...
Programming
1.
time is done at the attendant console (more than likely 100).
Dial [692] on the dial pad. A confirmation tone will sound.
2. Enter date and time as follows: YYMMDDHHMM 3. YY = Year (00-99) 4. MM = Month (01-12) 5. DD = Day (01-31) 6. HH = Hour (00-23) 7. MM = Minute (00-59) 8. When the correct number of digits are entered, a confirmation tone will sound. 9. Press the ON/OFF button to OFF to update the display.
Oct 13, 2010 | Vodavi Starplus DHS SP7312-08 - - Phone
Schematic for Zenith SF 120 console/Chassis 3B31 and 9B22
This model is old enough to not be available electronically. Your best bet is to locate a Sams Photofact copy of the manual. Check your local library as many carried these. Otherwise, check the web for Sams. These are usually available for purchase for less than $15.
Dan
May 05, 2009 | Audio Players & Recorders
Sylvania console tv model cld246pe04
I have its owners manual. Contact me.
May 15, 2017 | Televison & Video
Error code C:31:40
After looking up the error code C:31:22, I saw all of the solutions for slapping the side of the camera. Slapped it 4 times, then the error code switched to C:31:23. Same solution... Whacked it 4 times, then the error code switched to C:31:40. Again, whacked it 4 times. Opened it up, turned it upside down and a rubber roller dropped out of the camera. I could see where it went, snapped it down on its metal peg and it works fine. Looks like its the rubber rollers that guide the tape that gets stuck. Before whacking it, make sure the RUBBER roller moves freely. Good luck!!!
Apr 14, 2008 | Sony Handycam DCR-TRV240E Digital...
Strange ogject in PS3 game console
removing the strange object would be the first thing.
secondly, would be to put it up out of your sons reach.
Finally would be to find out your warranty, you,ll be needing it.
Mike @ compurepair.
Feb 25, 2008 | Sony Playstation 3 (PS3) Console
Remove the base
There are 4 philips head screws down near the base, 2 on each side. Remove those and the base will slide out.
Good Luck!
Dec 24, 2007 | Sylvania LC370SL8 37 in. LCD Television
Sylvania 6419TE 19" TV Logo
44 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
