Question about Sony VAIO VGN-SZ330P/B Notebook
Malfunction of the left button of the touch pad
I'm an owner of a VAIO VGN-SZ79GN since July 2008.
I've noticed a problem with the left button of the touch pad.
When I press the button I feel the "click" but nothing happens.
To make the button work properly I have to press it hard enough.
I think that this is a problem but I don't know if the origin of this is the software or the hardware. Could you give me any solution?
Thanks in advance.
Andreas
  • Anonymous Mar 28, 2009
    it's exactly the same problem with mine. not sure why this happens, and i use external mouse most of the times. Another problem is my mouse pointer goes reverse direction at times.
  • pelagikos Apr 22, 2009
    One of my laptops suffers from the same problem.
    VGN-NR220E
    I have not yet had a chance to take the ****** apart, but as far as I see from the part’s photographs on the web, mouse buttons are NOT a part of the touchpad assembly, only plastic pushers are. Chances are, that there is nothing wrong with the pushers, so do not order the new touchpad before you actually see that the problem is.
  • 4 Answers
I had the same problem . The micro switch needs to be replaced . All push button micro switches have a certain amount of "clicks" before they loose ability to make a good contact . Your left click switch has exceeded its life and can no longer make a clean contact without more pressure . Eventually the spring in the switch will fail thus stick permanantly.You will have to take it to an authorized Sony Service center or maybe an office machine service department might have the replacment . I fixed my own with an old mouse microswitch .Hey it's a Cheap laptop and uses cheap parts.
Posted on Sep 30, 2011
    Sergeant:
  • 324 Answers
Good day!
From what you have told us, it sounds like a hardware problem. It's possible that something may have come loose and could be corrected by removing it from the laptop and checking it out. Also, some foreign material (spilled liquid, food crumbs, paper clip,part of a tooth pick,etc.) may have gotten down in the area and is causing the button to stick. The probable resolution is to simply replace the touch pad with a good,new or used, touch pad assembly.
Hope this information helps to get yu going.
Have an excellentday!
Ron
Posted on Jan 08, 2009
I would like to disable the touch pad and use an external mouse. Sony Vaio VGN A190
Please follow the steps to disable the Touchpad under XP environment:
First, click the Start button, then click VAIO Support Central .
In the VAIO Support Central window, in the left pane , click System Maintenance .
In the right pane , click VAIO Central .
In the VAIO Central window, click the System Information tab.
On the System Information tab, click the Plus symbol next to Keyboard and Mouse .
Under Keyboard and Mouse , double-click Built-in Pointing Device .
In the Built-in Pointing Device window, click to clear the Enable box.
Click the OK button.
In the Built-in Pointing Device dialog box, click the Yes button.
Thanks!!!!
Dec 24, 2010 | Sony VGN-A190 Notebook
I have bought a sony vgn-n38e anf i am not able to scroll up or down on the right hand side of the touch pad, i would like to know if there is simply a button to press to rectify this or if it is possibly...
So you need to update driver for this touchpad scrolling error.
Please click on the below link
ftp://download.sony.com/US/pc/ALDOTH-00199336-US.EXE
This will download the driver for your touch pad then you need to run the driver that you downloaded.
Then restart the notebook
Check whether it is working.
you can find other drivers for Sony Vaio VGN-A790 on the below link.
http://www.notebook-driver.com/sony-vaio/sony-vaio-vgn-a790-notebook-windows-xp-drivers/
Hope this resolve your query.
Kindly provide your valuable feedback for this answer
Thanks.
Nov 11, 2010 | Sony VAIO VGN-A790 Notebook
The left button of Mousepad(one on laptop, but not touch pad) is often not working and sometimes need to press hard. Model VGN-NR38M, Sony Vaio. please help
Jun 26, 2010 | Sony VAIO VGN-NR385E Laptop
Left mouse button of Sony VGN-NR38M (nt touch pad) is not working often, and some times need to press hard, please help
mcdevito75 here, Bring laptop to Staples, Best buy for testing, sounds like that key could be hanging up. maybe some sort of oil needed.
Jun 25, 2010 | Sony VAIO VGN-NR385E Laptop
Touch Pad and mouse buttons
try it with toggle keys it may be work
May 03, 2017 | Sony VAIO VGN-N130G/W Notebook
Driver av mode sony vaio VGN-CS215J
im from malaysia and bought it from malaysia, my laptop is vaio VGN CS36GJ.. im having the same problem as stated up there.. my touch pad of sound, av and capture button is not function.. can u please tell me where should i go or what should i do?
Dec 13, 2009 | Sony VAIO VGN-CS215J/W Notebook
Repair/replace touchpad on Sony VAIO VGN-FS660/W
dear kenkasza, i am afraid that you will lose the warranty if you open ya laptop all by yourself.
Jan 04, 2009 | Sony VAIO FX150K Notebook
Sony Vaio Laptop Recall Sept 2008
The recalled notebook computer models are the VAIO VGN-TZ100 series, VGN-TZ200 series, VGN-TZ300 series and VGN-TZ2000 series. The computers’ screen size is about 11.1” measured diagonally. Not all units are affected; consumers should contact Sony to determine if their unit is included in the recall.
Sold by: The SonyStyle stores and Web site, authorized electronics retailers, and authorized business-to-business dealers nationwide from July 2007 through August 2008 for between $1,700 and $4,000.
Remedy: Consumers should stop using the recalled notebook computers immediately and contact Sony to determine if their notebook is affected. The firm will arrange for an inspection and repair, if needed.
Consumer Contact: For additional information, contact Sony toll-free at (888) 526-6219 anytime, or visit the firm’s Web site at www.sony.com/support
Sep 05, 2008 | Sony VAIO VGN-T350 Notebook
Sony VAIO VGN-SZ330P/B Notebook Logo
328 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
