I have a Crate - BT50 - Bass Combo Amp. It powers on and all the lights light up and everything, but I get no sound out of it. I know the woffer is good and the fuses are good, so what may be the problem???
Question edited for clarity (with a guess at model).
Question moved from Television and Video.
If you want to check inside it, look for damaged components or blown or bulging capacitors. The best solution is to take it to a local electronics or audio store for repair.
Do you happen to have another speaker that you could hook up to speaker output? This would bypass the amps internal speaker and lf you get sound from that setup, it would mean either a jack failure or possible internal speaker problems. Please let me know.
the amp is going into protect mode due to something wrong in the amp or some thing in the wiring to it ooh yea if you are getting 18v power to the amp that is way to high it should not be higher then 15v if the amp is in protect mode it will not play at all.
Sometimes an amplifier's preamp can't handle certain signals/frequencies at a high gain, so they cut out. Bass guitars are especially prone to giving such a strong signal. I bought an older, nonworking bass amp recently and fixed it just to find it had the same problem. Best solution is to put a low ohm resistor at the amps input, but if you turn your guitar down to half volume it'll have the same effect: should prevent it from cutting out.
