Question about NetGear WIRELESS-G WGR614 802.11G WIRELESS ROUTER ($20.00 M.I.RebateTill 06/30/2004) (NETWGR614)
Port forwording i m using wgr614v7 netgear with adsl router . wgr614v7 is only for making internet wireless .I face a port forwording problem in wgr614v7 .10.0.0.1 is gateway . I am unable to download from utorrent due to port forwording while configuring it asks sever address .Pls help me out
  • 33 Answers
Follow the steps in this simple tutorial:
http://portforward.com/english/routers/port_forwarding/Netgear/WGR614v7/Flatout_2.htm
Posted on Jan 08, 2009
  • Sean Osborne
    Sean Osborne Jan 08, 2009
    If you get stuck, feel free to ask for more help. And don't forget to seed.
I have NetGear (WGR614v7) Wireless Router. 1st thing i couldn't access internet...while making the connection mistakenly i put different WAN IP now i got huge problem. setup wizard in not opening so what...
Using a CAT5 cable, connect your computer to the router, disconnect the power supply from the router, and hold the reset button for 10 seconds. Then reconnect the power cord, and open the browser on your computer. Type in the address www.routerlogin.net and press the enter key. This will take to the main setup menu. Set up the router as you wish. To secure your router connection, vist these websites: http://www.labnol.org/internet/secure-your-wireless-wifi-network/10549/ and http://www.practicallynetworked.com/support/wireless_secure.htm. Hope this helps! For more info on your router, go to http://support.netgear.com/product/WGR614v7
Oct 26, 2013 | NetGear WGR614 Wireless Router
What is the code for netgear WGR614v7 to enter to a laptop for wireless wifi?
Connect a LAN cable from the Netgear to the LAN port on your computer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = password You can now change the default admin password and configure the wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption to protect your wireless network and Internet from unauthorized access.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security b>
Jan 28, 2013 | NetGear WGR614 Wireless Router
Our netgear wgr614v7 54 mbps wireless router has gone bad acording to our net work service.They tested there modem,that had astrong signal.now here is whats happnen,there is no signal frm modem to wireless...
This guide gives you the directions for setting up wireless on the Netgear WGR614v7.
Basically enter the routers ip address (192.168.1.1) in your browser. If you router has default configurations, then enter the username as "admin" and the password as "password." Navigate to "wireless settings" and then on that page you configure your network.
Jun 13, 2011 | NetGear WGR614 54 Mbps Wireless Router -...
Netgear WGR614v7 Wireless Router what do i need to use google,com
Search for wireless networks from ur laptop. u will find ur wireless router gets listed. Select it and click on connect. Your router assigns an ip to ur laptop by means of dhcp. Thats it u get connected to internet. ensure whether ur phone line is connected to rj-11 port of ur wireless router
Jul 21, 2010 | NetGear WGR614 Wireless Router
Does anyone know if my netgear WGR614v9 can handle an ADSL+2 connection?
Please note that the router WGR614v7 is a cable dsl router and will never handle ADSL connection. For ADSL connnection you need to purchase router model number DG834Gv5.
Hope that clarifies the doubt!
Jan 29, 2010 | NetGear WGR614 Wireless Router
Variable wireless performance
what this looks like is a case of intermittent signal
call ur ISP have them run a line test
if you have purchesed a service that is better than the basic
what could be happening is that the line capacity is to high
(trying to push 100 gal. of H2O in a 1 IN. pipe in 1 sec. cant happen
i work for att. tech. support and sometimes incrising ur speed package will make ur internet sluggish
most routers dont go bad i belive its a line issue
good luck , July
rate me please
Apr 11, 2009 | NetGear WGR614 Wireless Router
Cannot access the internet after installing new NetGear router.
you need to change the IP address of the router. Plug just the router into the computer. Open Internet Explorer and go to 192.168.1.1. user: admin password:password. On the main page it allows you to change the LAN IP. Make it 192.168.2.1. Now unplug everything and rewire it correctly. This should fix the issue. Verizon uses 192.168.1.1 for the modem well so does Netgear and this causes the network to not function. So changing the IP of the router should fix this issue and has worked for me many times that I have done that set up.
May 26, 2008 | NetGear DG834G 54 Mbps 802.11g Wireless...
NetGear DG834G Router
First use the Netgear setup wizard:-
Enter http://routeraddress e.g http://192.168.0.1
Click Setup Wizard (top left)
Then for With AOL make sure you have set these values in the Netgear
ADSL settings as PPPOa
VC 0,38
MTU setting to 1400
If you still have problems
Start -> Control Panel -> Add/Remove Programs -> select AOL Connectivity
click Add/Remove -> use the repair option
Follow instructions to repair.
Once complete make sure modem is configured and switched on and
try restarting AOL.
It should search for your connection, find it and allow you to log on.
Feb 06, 2008 | NetGear DG834G 54 Mbps 802.11g Wireless...
Internet connection
Different internet providers have different requirements for connecting routers to their equipment. Can you provide the name of your internet service provider?
Dec 18, 2007 | NetGear DG834G 54 Mbps 802.11g Wireless...
Netgear DG834G router
Are you getting any internet?
Are you using Windows Vista?
Oct 19, 2007 | NetGear DG834G 54 Mbps 802.11g Wireless...
NetGear WIRELESS-G WGR614 802.11G WIRELESS ROUTER ($20.00 M.I.RebateTill 06/30/2004) (NETWGR614) Logo
249 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
