Question about Inova MICROLIGHT
Light worked fine for a while, then became intermittent
I bought a Nite Ize LED wand which comes with the chip controled (squeeze for different modes and switch on and off) Inova Microlight. (Blue in my case) I use it while hiking and camping. I tested it out at home before the last trip out and it seemed to work fine. When I got out into the woods, and tried to turn it on, it would only stay on while I was squeezing it, and then only very dimmly. I tried replacing the batteries, but it had no effect. Any suggestions?
Try holding it for 15~20 seconds or until the light goes out then try it again and that should give u 3 mode
Posted on Feb 11, 2009
My high beam light will not come on 1997 grand prix pontiac
Check your fuses if OK then check wiring at both ends at the light and the switch connections.
Sep 08, 2017 | Pontiac Cars & Trucks
How do you deactivate demo mode on the buglit?
Demo(factory) mode is deactivated by holding the switch on for approximately 20 seconds, until light flashes and goes out.
Normal function is press once for high, a second quick press for low, a third press for strobe.
Sep 03, 2014 | Nite Ize BugLit LED Micro Flashlight Red
DONNOT HAVE APPS NOW INSTALLER IN NOKIA 501 FROM THEN WHEN I BOUGHT IT
if u have bill with you then take the bill and go to the nokia service center and ask your mobile from there..
Nov 27, 2013 | Nite Ize Belt Holster Rugged Cargo Clip...
I have had my Inova collection for over a year. Till now they have worked good. But lately they have been shutting off by themselves. I tried resetting them but they would not reset. I am hoping there is...
Just getting old like me. the coating on the place is flaking off, nothing new here, well all get flaky.and getting old. Possibly they could have been saved by turn them on ever week or so. But who knows this thing. I' m sorry that I couldn't be more help to you. stewbison
What type of batteries are in thes Inova MicroLights, cadium, lithium etc
May 08, 2011 | Inova MICROLIGHT
I bought a new Blue Max Gasoline pressure washer and when I started it up I have very little water pressure. Are there any comprehensive instructions manuals then what were supplied with unit? Thanks Ron
You can download the manual here: http://www.farmprotractors.com/hdcmanuals/PW2200-03435.pdf
It is probably the same manual that came with the unit.
As far as pressure... hook up the water supply hose and turn on the water supply. Let the supply hose purge all of the air out. Then turn off the water and connect the high pressure hose. After that turn the water supply on again with the engine off and squeeze the wand trigger. Make sure all of the air is out of the high pressure hose. Then start the unit...
Once the engine has stabilized rapidly squeeze and let go of the wand trigger several times. Your exersizing the bypass / unloader valve spring. By this time you should have good pressure. If you have owned the unit less than 90 days and your sure you have a warranty issue use this link to contact the company:
http://www.homier.com/contacts
Contact Information:
Homier Distributing Company, Inc.
84 Commercial Road
Huntington, Indiana 46750
Hours of Operation:
M-F 8:00am - 5:00pm EST
I note they do NOT include a phone number on their contact page but do state empatically that warranty contact should be made via email feedback@homier.com
You will also need a warranty form here:
http://www.homier.com/return-authorization-form.pdf
Some of these units have a sliding assy on the wand that slides toward the ouput nozzle for adding soap / chemicals. If the slide is not pulled back toward trhe wand and locked into place you will not have any pressure either.
It appears from reading the manual that this particular unhit had 2 different nozzles. One for chemicals and one for high pressure. Plese make sure you have the high pressure nozzle installed. The BLACK nozzle is for chemical use. (page 5 of manual link above)
The red, yellow or white nozzles are all for high pressure with different spray patterns.
This is about the best I can do for you Ron. Hope it was helpful.
Kelly
May 20, 2010 | Psi Blue Max 2200 High Pressure Gas Power...
Battery not making good contact
use the eraser on a # 2 pencil to clean the contacts that touch the battery
Mar 25, 2010 | Inova MICROLIGHT
Microlight doesn't operate as described
I KNOW HOW TO SOLVE IT. HOLD IT DOWN FOR LIKE 17~20 seconds
and after that u turn it off so everytime u press it, it will change as it suppose to work. i just solved the problem i had too :D
Oct 04, 2008 | Inova MICROLIGHT
Inova MICROLIGHT Logo
281 people viewed this question
Top Inova Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Inova Optic Expert? Answer questions, earn points and help others
