Question about Nintendo GameCube Console
What is Input Select and how do I find this on my TV?
I have fiddled with my TV and now all I'm getting is snow
trying to find Input Select
  • Anonymous Feb 03, 2009
    cant get my Gamecube to be found on my Vizio tv, and the Tv is NEW!
    Scholar:
  • 35 Answers
Typically, 'Input' is an option found on your television's remote control, not on the TV.
If you have your remote, look for a button labeled 'Input' - pressing this allows you to change the input that the television is using at the current time (ie. you can have multiple devices [GameCube, a DVD player, and an XBOX (for example)] connected to your TV through the various inputs on the back (where all the cables go) and select (or jump) between the various devices. This means that you don't have to unplug and plug in each different device everytime you want to use it)
Posted on Jan 08, 2009
I have a Toshiba tv and I need to hook it up to my direct tv box and all I get is snow. Please help
snow is an indication that the antenna is not properly connected
try connecting the antenna cable to the input of the box then from the box to the input of the tv
follow the user manual directions
Feb 08, 2016 | Toshiba Televison & Video
When plugging antenna in 37: protron tv do I use analog input or digital input?
An antenna is analog. Try using the setup menu for the tv to choose analog input.
Jan 18, 2015 | Protron PLTV-3750 Television
How do i get a movie to play from computer to the tv with hdmi
If your TV has an HDMI input - connect up the computer to the TV with an HDMI cable.
Select HDMI on the TV inputs.
Play the DVD on the computer, should appear on TV is Input is set. Sound may be a fiddle ~ check you PC sound settings if there is none.
The computer will usually show a blank screen when the HDMI is going elsewhere,
Good luck
Apr 20, 2014 | Vizio E421vl 42 Inch Class Lcd Hdtv
No signal + snow on screen
If you have a "non-High-Definition" Shaw Digital Terminal, tune your TV to Channel 3.
If you are using "component-input/output" or "composite-input/output", use the "Source" (or "Input") button on your TV's remote control to select the correct "input".
Feb 08, 2014 | shaw.ca
Watched DVD cannot return to regular TV just snow what channel should it be on
if you have an external box for the signal (like a sattelite receiver or cable box) then you need to see what input it's plugged into.
If it's plugged into something marked AV1 or something like that, that's the input you need to select to get the TV back. The TV input selection is only for when you have analogue cable or antenna plugged directly into the TV itself.
Jul 30, 2011 | Hitachi 57F500 57" Rear Projection...
I have a 32" RCA 32V432T TV that only shows snow now. I've checked everything externally but still no picture. Any solutions?
There could be several things that can cause this: 1. There are no analog channels in your area. 2. Check the menu setup and verify that you select the proper input (antenna, cable, etc). 3. The TV tuner is defective Try using the composite input on the TV (there are normally 3 jacks per input). Yellow for video and red and black for audio. If you dont have the proper cable, pick one up in you local 99 cent store or an electronic store.
Connect the "output" of your device (VCR, cable box, Tivo, dvd player, etc) to the "input" on the TV. Then use your TV remote to select the proper input.
Hopefully this helps. Good luck.
Sep 27, 2010 | RCA 32V420T 32" TV
Trying to set up my xbox to my orion tv but cant get it to work. the screen shows nothing but snow
You have to switch the TV to the proper input. If you are getting snow, the tv is on the cable input. Xbox only works on the composite or component inputs on the set. The inputs are labeled at the jacks that you have connected too. Find the input button on the tv remote and switch the tv input to the input number you are connected to. Thanks for using fixya.
Dec 13, 2009 | Televison & Video
Snow no connection to cable box
the fact that you are seeing snow tells me that your tv in in the tuner mode .. your cable box is more likely hooked up to the AV input (composit video + 2 sound channels ..3 wires total) .. or it could be hooked up to component inputs (5 wires total) ... you will have to go to the menu of the TV and choose the proper input ... if your cable box is actually connected thru the tuner (coax cable to RF input .. one cable) then you have to select the same channel on the tv as what the cable box is set to .. that is usually chan 2 or 3 ... there is also an svideo input on your tv .. that can take the place of the composit input ..
here is a diagram of the back of your set so you can determine how its hooked up ..
http://www.fixya.com/support/p169436-zenith_p42w46x_42_in_edtv_plasma/manual-6443/page-8
lots of other good information there as well
Oct 03, 2009 | Zenith P42W46X 42 in. Plasma EDTV
P50 VIZIO WHEN ON HDTV I GET SNOW
it's probably the Time Warner cable box that have issue and not the TV. Try using a DVD player and test the same input, it should work fine.
Nov 15, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Panasonic older big screen tv
pls. check your cable box, if you have a cable box and it contain input- output audio video select video to your tv set maybe you scan from video 1-3. then check your RCA jack
Apr 10, 2008 | Televison & Video
Nintendo GameCube Console Logo
137 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
