Question about Xerox WorkCentre M20i All-In-One Laser Printer
L4 code on workcentre xd 155 df
What is L4 code mean?
    Scholar:
  • 35 Answers
TABLE 1
Summary: 'L4' Product: * Copiers & Multi-Function Copiers
  • XD Series
  • Description: XD100 Family
    - Main motor problem.
    - The main PWB sensed a main drive motor problem. Solution: document.write(ParseIncidentLinks("01 - Switch off the power and wait for 5 seconds.\n 02 - Switch on the power. If the status code persists, Please .", 'Hold down Shift while clicking to open this link in a new window', '(Click here)', 0)); 01 - Switch off the power and wait for 5 seconds.
    If the status code persists, Please see Table 2, below.
    TABLE 2
    Summary: Service Call Product: - Communication Technologies
  • Telecommunications
  • Description: A service call is required when the solution requires a Xerox engineer to rectify.
    Service will be provided in the form of an onsite engineer, repair or replacement of the machine depending on the warranty held for your specific product. Solution: document.write(ParseIncidentLinks("Please contact your local Xerox Help Line arrange a service or further assistance over the phone. You can also e-mail us a question.\r\n\r\nTo find your Xerox Support line locate the contact button at the bottom right of the Screen.", 'Hold down Shift while clicking to open this link in a new window', '(Click here)', 0)); Please contact your local Xerox Help Line arrange a service or further assistance over the phone. You can also e-mail us a question.
    Posted on Jan 08, 2009
    • Sheldon Scott
      Sheldon Scott Jan 08, 2009
      Sorry about my solution - the copy and paste function seemed to confuse things. Let's try that again:
      TABLE 1
      L4 error code: Main motor problem.
      Summary: The main PWB sensed a main drive motor problem. Solution:
      TABLE 2
      Solution: Please contact your local Xerox Help Line arrange a service or further assistance over the phone. You can also e-mail us a question.
      (source: http://www.xerox-support.com/incview.cfm...)
    What does df on interior display of pioneer split heat pump system mean?
    In defrosting mode, The LED displays “dF” or alternative displays between running frequency and “dF” (each displays 0.5s)
    This means the outdoor unit is in defrost mode, heat pumps will initiate defrost upon demand. Its a normal operation code
    Mar 01, 2017 | Heating & Cooling
    How do I remove Error code L4-02
    L4 errors relate to motors. L4-02 specifically means Paper feed motor locking trouble.
    You will need to take it in for repairs.
    Nov 05, 2015 | Sharp MX-2700N Color Copier
    CODE L4-01 AR M351U
    PRES: CLEAR, INTERUPT, 0, INTERUPT, 14,1, START BUTTON TO RESET THE COPIER. L4-01 MEANS A MOTOR ISN'T ROTATING PROPERLY. POSSIBLY BECAUSE OF A PAPER JAM.
    Apr 15, 2014 | Sharp MX-M350 All-In-One Printer
    Our Oki 8300 printer has an errror code L4-02. What does this mean?
    I have an error code L4-02 with Oki B8300. what is the solution?
    Oct 28, 2010 | OKI B8300 Laser Printer
    I have a Xerox XD 100 work centre showing a H-4 code what is the problem?.
    The H4 code on these machines is almost always a false code. Especially if you have had any power fluctuations or failures.
    Here is the text from my tip to solving this problem here on Fixya:
    To reset the H3 or H4 condition on just about any Xerox XC or XD series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
    Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
    So in other words C, far left, C, far left
    If done correctly the display should go blank.
    Now key in 14 as if you were going to make 14 copies.
    Now press the print button.
    The machine should reset and the code should be gone.
    9 times out of 10 this is a false code that pops up due to power surges or noise.
    If the code comes back this means you have a heater lamp or thermal fuse (more common) failure in the fusing area and will need service.
    This procedure will work on all Xerox XD and XC models.
    Sep 03, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
    I have a number 4 and a letter H flashing
    Good Luck and Thank You for using Fixya
    Jul 16, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
    CODE:L4-30??????
    Hello.
    From FixYa Support: L4 error code means a copier motor fail problem.
    Please press # Interrupt C interrupt. Press 16 press start key or print key. If still a problem, please check the motor fuse or see if any kind of gear was broken.
    Hope this helps
    Apr 08, 2010 | Sharp AR-M550N Copier
    L4 error code
    L4 means that there is an overload in the drive system. Check the developer unit if its running smoothly or the drum. Make sure the exit unit is not jamming. This can be done by openning the cover on the right side and you will see a small motor. Clean its sensor.
    Jan 19, 2010 | Sharp AR-5320 Black and White Copier
    Error code L4 30
    L4 error code mean your copier motor fail problem.
    Please press # Interrupt C interrupt press 16 press start key or print key.If are not fix this problem please check motor fuse or any kind of gear was broken.
    Dec 16, 2009 | Sharp AR-M455N Copier
    CODE ERREUR L4 DANS UNE PHOTOCOPIEUR SHARP 5316
    L4 mean this copier main motor is not move or run.
    First time, Open your copier back cover and check any gear is broken,solve it .Or clean all mechanical which one jam.If you are not a technician so you call a service Engineer who are qualified this Brand.
    Dec 02, 2009 | Sharp AR-5320 Black and White Copier
    Xerox WorkCentre M20i All-In-One Laser Printer Logo
    375 people viewed this question
    Top Xerox Office Equipment & Supplies Experts
    Michel
    Xeroxrep
    Level 1 Expert
    Philip Hughes
    Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
