Question about Dell InspironTM 1501 Notebook
LCD screen Hi, Thanks for your reply.I checked in BIOS by pressing F2.Then also i am seeing only half of the screen.So its hardware problm n i need to replace my LCD screen. Could you tell me how can i replace my LCD screen with new one.How much it costs for new lcd screen.My laptop is dell inspiron 640m 14.1". Thanks, Shajjj
    Problem Solver:
  • 8 Answers
If you Dell 640m is still under warranty you can call up DELL technical support they will replace it for free. You will need to provide the laptops service tag it is a 7 alpha numeric code with number 1 as the ending from here they will know if the system is under warranty, If your system is not anymore qulified for a warranty they will suggest that you get in touch with their OWR (Out of Warranty) service from this department they will be the one to quote how much the LCD will cost also the labor charge if you opt to get their service with an OnSite technician to install the LCD.
By the way have you tried to attach a good working CRT or external monitor and then check if the same thing happens if it does then it is not the LCD that is broken it's the video/graphics card, regarding your issue there are two points of failure the LCD and the Video/Graphics card. So it is better to make sure we do this necessary steps to better isolate the issue.
Posted on Jan 12, 2009
Cha cha ask online
The computer works fine with external/ alternate screen so there is a possibility that the LCD screen has failed. However, I would suggest you to try running an LCD BIST using the below link:
http://dell.to/1irqbYp
Do reply with the results. Also check if the same issue happens in BIOS screen (F2 at startup).
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
Jun 21, 2014 | Dell Latitude D820 Notebook
Packard Bell Laptop: Hi every time I switch on my laptop it goes onto the PB screen mode & it takes about 2 to 3 minutes to boot up. Also at the bottom of the screen it says press F2. Can you...
Hi there.
What do you mean by pb screen?
When you see the f2 screen, is that upon boot up? If it is, pressing F2 will take you to BIOS settings.
Ill be waiting for your reply.
Thanks.
Aug 18, 2011 | Computers & Internet
My startup Screen Says Media Failure Check Cables
Go into your BIOS when computer is first turning on press F2 or DEL to enter your computers BIOS look through the settings to find your HDD see it one shows up in your BIOS, then on the same page look to see if there is a cd/dvd drive listed as well, next if you have any flash drives or external HDD hooked to it remove them. After you have done these if your BIOS shows your hardware anyway. Power on you computer and see what happens. If you need more help, or come up with more information about your problem please reply. I will try to assist you further.
Jul 29, 2011 | Toshiba Satellite M35X-S111 Notebook
Asus Ee pc screen is half white. how can i fix it?
Try to boot to the BIOS screen/ system setup screen. Tap on F2 on the splash Asus splash screen. If the BIOS still shows this problem, it is a hardware failure. You will either need to replace the LCD screen of the video card of your laptop. To further isolate the issue, you need to connect an external monitor on the portable system while you are on the BIOS screen and press on Fn+F8. If the issue is seen on the monitor, then it is the video card, if the external monitor is clear, then it is the LCD screen.
However, if the issue does not occur in the BIOS, it must be the video card. Hopefully it is just a corrupted video card driver. Try to uninstall and reinstall the video card driver. If it does not resolve your issue, then it is the video memory of your computer. You still need to spend some money to have it serviced.
Jul 02, 2011 | ASUS Eee PC 900HD Netbook
Server not going in bois
Welcome to Fixya
Press F2 button as soon as you see the initial screen . This will take you to the bios section.
If you find same problem please update the server BIOS firmware which is available from the ibm site After update check , it should work
http://www-947.ibm.com/support/entry/portal/sdd/Hardware/Systems/System_x/System_x3550_M2/7946?brand=5000008&key=5312474&osKey=0#5050383
Thanks
Vote me if it is helpful
May 06, 2011 | IBM x3400 Server
I am getting lines on my laptop screen. the colored lines appeared all of a sudden and hiding half of my screen. pls help
Hi azmiug,
I see that you are getting colore lines on the screen hiding half of your LCD screen, Please see steps below.
*Turn your Laptop OFF.
*Once Turned OFF, Turned the Laptop back ON then keep on tapping F2 on your keyboard.
*By Tapping F2 on the keyboard this will bring you to the BIOS screen, once in the BIOS of your Laptop and the Colored Lines are still present then the problem is the LCD of your laptop and may reuire replacing.
*If the Colored Lines are not present then the Problem would possibly be the connection of the Video Card to the LCD or the Video Card itself.
*Reformatting Windows can be one of the steps to be done to find out if the issue Colored Lines will be fixed or not.
I hope that this will help you with your concern.
Have a nice day,
mvincentc
Apr 24, 2011 | Computers & Internet
Screen won't work
There may be various reasons for this issue. We have a lot to try. I will suggest some troubleshooting steps, please try to out. Restart the computer and press and hold the F2 key and check if the computer boots to BIOS. If it boots, the issue is not with the screen. You can restart again and press and hold the F10 key, this will access the Recovery partition, from there either you can run a System Restore or a System Recovery to resolve the issue.
If the computer is not able to access the BIOS, then the issue is most probably with the hardware. But, I will suggest that you reset the RAM modules and try again, if the RAM modules or not properly seated, this may happen. If the issue persist even after this, hold a torch light towards the LCD screen after starting the computer, if you are able to view the screen in that light, the LCD back light is gone and a replacement will be required.
For service you may contact any hardware vendor or Sony service center.
Hope this helps and don't forget to rate me.
Thanks!!!!
Dec 20, 2010 | Sony VAIO VGN-NS240E/W Notebook
I HAVE AN ACER ASPIRE LAPTOP 5715 - 4713 AND THE SOUND HAS BEEN PLAYING VERY LOW SUDDENLY AND WHEN I POWER IT ON AND IT BOOTS FROM THE HARD DRIVE IT MAKES A SCREECHING NOISE. THANK YOU AND AWAITING YOUR...
My name is vinod. Prince829 you said screeching noise when booting up. so try doing the bios default. i.e. shutdown your computer. turnit on immediately keep tapping f2 it would go into bios screen. or if not try tapping delete. For some computer it goes into bios using delete.
So once your into bios screen. press f9 once. it would two options yes or no. say yes. now press f10 save and exit. it restarts the computer. so check if you hear the screeching noise or not. if yes it can a hardware issue. contact acer for support.
Apr 21, 2010 | Acer Aspire 5720 Notebook
LCD comes on during boot then goes off . I formatted the hard drive then tried it again and still same problem. When I press F2 during boot, to get into bios, same thing happens. I put in a bootable XP...
Hi there it's not a software problem. It is Hardware problem, Your screen can't afford the loadisit Acer service center you need to test your screen connectivity from Motherboard. May be its damaged. So don't go for format every time becouse, its not good for HDD life.
Thanks.
Feb 09, 2010 | Acer TravelMate 290 Notebook
Hi, I have dell inspiron 640m laptop.It worked properly.By mistake it was broken.From there i am able to see properly only half of the screen and half of the screen is blue.Is this only screen problem or...
If you only have half of the screen first thing you need to do is go to BIOS page by pressing F2 during start-up once you see the BIG Dell logo. F2 let's you enter the BIOS if you can still see only half of the screen then that is indeed a hardware failure meaning you need to replace the LCD only otherwise go to safe mode if you can see everything here normally except for everything here is BIG then that means you just have a software issue and you need to uninstall the driver for the video card and then restart the system. After restart reinstall the driver for the video card and then restart again by this time you should have a normal screen and issue is fix. Reply if everything goes as plan aiyt.
i still got a lot on my sleeves to fix your issue.
Jan 08, 2009 | Dell InspironTM 1501 Notebook
Dell InspironTM 1501 Notebook Logo
76 people viewed this question
Alun Cox
