Question about Ricoh Aficio CL2000N Laser Printer
Ricoh CL2000N Error SC441
Does anyone know how to correct this error?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 86 Answers
It means the PCU (CMY) motor error.
Try removing and reinserting properly the CMY PCU drum or replace it with a new one.
Posted on Jan 11, 2009
Ricoh CL3000 error sc441
sc441 is a drum motor error. It could be caused by anything from a faulty circuit board to a bad motor, but the most likely fix (and the easiest) is to replace the color PCUs (photoconductor units) which I believe all come as one set.
Turn the machine off and unplug it from the wall, then install the new PCUs, plug it back in and turn it on. There's a good chance your printer will work fine. If the sc441 error comes back, you should contact your local service company and have them take a look at it, because the problem is either electrical or mechanical.
Hope that helps!
Nov 09, 2010 | Ricoh Aficio CL3000 Laser Printer
Error Code ''SC441'' on Ricoh MP4000 Copier
The machine have problem with the transfer roller or the motor which drives the transfer is overloaded,
see do the right door is closed good if this not help it will need to be checked by a technician
Jan 21, 2010 | Office Equipment & Supplies
Error message on a Ricoh 2000 SC441. What does
SC441 mean scanner or laser unite problem.Open it and clean laser mirror,or clean scanner door sensor.
Dec 09, 2009 | Ricoh Aficio CL2000N Laser Printer
Error code sc440
Black drum motor error. These machines are bad about the waste toner building up in the drum unit. You could try and take the auger out of the drum unit(very messy) and clean it out or try replacing the black pcu.
Mar 17, 2009 | Ricoh Aficio CL2000N Laser Printer
Won't turn on....
Have you recently replaced the colour PCU? It may not be seated properly, otherwise there is likely a problem with it, and it's not turning (ie: a broken gear). It could also be the PCU drive motor, or control board. Sounds like you may need a tech to get to the root cause unless you have a spare PCU to try?? This also explains the colour registration problem.
Feb 23, 2009 | Ricoh Aficio CL2000N Laser Printer
Error message on Ricoh Aficio BP 20 PCL 6 printer
Flashing orange means low toner.....solid red should be a paper jam
Feb 20, 2009 | Ricoh Aficio CL2000N Laser Printer
Ricoh CL2000N Error Code SC230
The manual says this code means " BCU Received no Feedback from LD" I have no idea what that means, but maybe it will help a tech on hear tell you more.
Jan 24, 2008 | Ricoh Aficio CL2000N Laser Printer
Ricoh CL2000N Error
should have a menu option for clearing errors. or just restarting the printer.. to find out what the error is call ricoh support.. typically if you have a printer like this, you have a service contract with company that handles the repairs and maintainace.
Jan 22, 2008 | Ricoh Aficio CL2000N Laser Printer
Error message says reset PCU correctly
You get this message because the PCU isn't seated properly. This is a link for the user manual for this printer: http://www.ricoh-usa.com/downloads/manuals/printers/cl2000.pdf On page 13 shows a diagram that indicates the photoconductor unit on the printer. Page 60 shows you different error messages, what they mean and how to fix it. It means you have to take out the pcu and reseat it into the printer, it is not in correctly. Page 29 shows you how to do this. It has pictures of how to take out the pcu and put it in correctly. I hope you get it fixed.
May 12, 2007 | Ricoh Aficio CL2000N Laser Printer
Error Code
HAD SAME PROB I WORK FOR RICOH DIRECT SERVICE 670 IS ENGINE CONTROL BOARD OK....
Feb 16, 2007 | Ricoh Aficio CL2000N Laser Printer
Ricoh Aficio CL2000N Laser Printer Logo
446 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
