Question about Sirius Starmate ST2 Satellite Radio Receiver
Starmate 2 power jack
The female jack in the receiver has come loose and I'm simply wondering if it can be repaired and where that would be done in Salt Lake City, Utah.
  • 43 Answers
If you go to anyplace that sell's Sirius radios. Like best buy they should be able to fix it for you.
Posted on Jan 08, 2009
Broken audio jack
replace the jack or the circuit card with parts off ebay. see the two cards pictured in my solution at this link.
My ST2 just died Still picks up all the channels fine but just doesn...
Mar 22, 2014 | Sirius Starmate ST2 Satellite Radio...
Audio jack needs to be replaced
usually the male jack is bad before female on audio plugs but here may be just broken joint from jar or jerk but you could try fresh male first
tuners eat power and are tuned warm if its being intermittent may try fresh power happened to my first xm unit the unit will last for a decade on all the time the power adapter will last a few seasons at best
will come apart .....back of quality exacto blade snap the two halves apart slowly desolder the copper wire fm antenna lead on black side frees the mobo its just wedged in there on the PCB with a little solder now you can see
the joints on the female jack could of cracked from pad just touch em up with some solder but remember itl be your pad next time he ha lovely surface mount solderpaste can break at times not necessarily design flaw
don\'t get surface mount pads to hot know how to solder get the iron fully up before hitting it 1 1000 2 1000 done
put it this way if you can see the unit has been too disturbed youll need more diasecting and a parts to repair you can find parts of similar size but unlikely to find correct orientation for mobo without Mouser or parts manufacturer you have to nichrome wire it and get to more of PCB to handle the traces not hardly room without desolder more parts to see whats up
if your undecided send it in
.... hell the whole industry is there in the palm of your hand he ha
Oct 08, 2013 | Sirius Starmate ST2 Satellite Radio...
No volume
Audio jack probably needs to be repaired.Not sure where to get it done I have one that needs to be fixed
Feb 19, 2013 | Sirius Starmate ST2 Satellite Radio...
I have a sirius starmate st2 and it goes on but won't stay on and just turns itself off. Is there any way to repair this?
Your power jack needs to be replaced. You can buy a repair service on eBay. You'll need a new power jack if you'd like to repair it yourself, which you'd need to take from another radio.
Aug 02, 2011 | Sirius Starmate ST2 Satellite Radio...
Radio shows antenna not deteted or acquiring signal but does not work . antenna and all connections are good, ??
The problem is likely the actual connection inside the Starmate. It sounds like you have tried alternate antennas, which can only mean the unit itself has an issue. What has likely happened is the antenna jack inside the radio has come loose and is no longer making a connection, in which case it could be repairable. Otherwise there are plenty of other 12v Sirius receivers compatible with the same connections if you are looking to replace the head unit.
Jun 08, 2011 | Sirius Satellite Radio Sirius Starmate ST1...
When you turn or touch the radio or hit a bump it turns itself off and back on.
Your power jack needs to be repaired or replaced. Check out eBay for repair services.
Nov 05, 2010 | Rio SIRIUS Starmate Replay Receiver
Battery does not charge, but remains on with power supply connected. Female to male connection "touchy." Can turn off if cord is barely touched. Main concern being how to fix female part of power supply.
DC Jack diagnosis:
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop.
Oct 09, 2010 | Computers & Internet
Problems with the power cord. Loses power.
You have to open it up, break it down carefully to 4 pieces. There are 4 solder points on the female part of power socket. With the radio on the table, have the power socket on your right bottom corner. Apply rosin core solder to the 3 points 0 1
2 3 Use a 15 watt iron from Radio Shack. Solder .032 dia. Carefully put it back together.
Feb 26, 2010 | Sirius Starmate ST2 Satellite Radio...
Its not turning on even in the boom box
Hello jimmytopps,
Unless the unit itself is defective, there's either a problem in the wiring or you have a burned out fuse. Check both the "always on" power lead and the 12V switched leads, usually yellow and red. Use a voltmeter and test each one to ground. The yellow one should read 12V with the ignition either on or off. The red one with ignition on or in accessory. If they don't, check the wiring and fuse. If they do, the unit is defective.
Hope this helps.
Jul 14, 2009 | Rio SIRIUS Starmate Replay Receiver
Sirius Starmate ST2 Satellite Radio Receiver Logo
400 people viewed this question
Top Sirius Audio Players & Recorders Experts
Scott Thompson
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
