Question about HP Photosmart C7280 Laser Printer
I have a paper jam I cannot fix
I have tried everything I can but I cannot seem to locate the jam
    President:
  • 8,637 Answers
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 23, 2009
We have a canon MP490 printer, and it says that there is a paper jam, but there is not. We have tried everything we can think of to fix it, including unplugging it, but it hasn't worked.
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Jan 31, 2011 | Canon MP490 InkJet Printer
Cannon imageclass mf3240 laser printer paper jam
Hello there,
Hope I could still share with you this fix because this is where you need to look at when you think you have done everything to remove the paper jam.
1. Turn off the printer and pull out all plugs and power cord that is attached to your printer.
2. Remove the paper tray at the bottom and let the printer lie at its back so that you can see underneath.
3. Get a flashlight and look closely for the sensor located underneath the printer. The sensor is located in a small square hole, just above the small black plastic "lever" (looks like a small hockey paddle) on the left side of the gray rubber roller. Move the lever so that you can freely look closer on the hole.
4. Notice because there could be a tiny paper shred stuck inside and this causes the sensor to detect a paper jam.
5. Get a small tweezer to remove that paper out.
6. Next, let the printer stand normally and return the tray back.
7. Re-plug all cables and start your printer. That's it!
You can also click on this link for this trick.
http://www.fixya.com/support/r3827902-canon_imageclass_mf3240_paper_jam_fix
Sep 08, 2009 | Canon imageCLASS MF3240 All-In-One Laser...
What is media jam fuser error
It means there is a paper jam in the fuser (the hot part that fixes the toner to the paper).
Check if there is any sheet jammed inside your printer or if any sensor is in the wrong position.
If everything seems to be ok, you may need to replace the fuser.
Nov 27, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Brother 5250
I had the same problem on 4 Brother HL-5250's, I checked the whole printer, and couldn't find a paper jam, yet the red printer light wouldn't shut off. I finally followed the instructions on Brother's website for removing a paper jam, and the solution for all 4 printers was paper stuck in the fuser cover. See below on how to open the fuser cover.
Pull the tabs at the left and right hand sides toward you to open the fuser cover (1).
  2. Hint
  3. There are 2 kinds of covers at the rear of the printer. Please make sure to open both the back cover (step 7) and the fuser cover (step8).
  • May 27, 2008 | Brother HL 5250DN Laser Printer
    Paper Jam
    Don't know if it's the same problem i had but its maybe worth a try. My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print.
    Someone replied to my problem, i tried it and it fixed 1st time. Also seems to of worked for others, it seems to reset the sensors or something.
    Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving push it through!! and hey presto it worked for me, everything printing fine now.
    hope it works, let me know, Garty
    Apr 07, 2008 | Canon PIXMA MP160 All-In-One InkJet...
    Paper jam
    don't know if it's the same problem i had but its maybe worth a try. My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print. showing 3e as the fault
    someone replied to my problem, i tried it and its fixed 1st time, also seems to have worked for lots of others.
    Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving PUSH it through! and hey presto it worked for me, everything printing fine now. Let me know how you get on, from Garty
    Apr 04, 2008 | Canon PIXMA MP160 All-In-One InkJet...
    Paper jam
    hi,
    try this....
    > unplug power chord
    > open the rear access door
    > remove the paper jammed
    > close the rear access door
    > plug the power chord
    > try to copy
    thanks and regards
    agnel
    Mar 17, 2008 | Office Equipment & Supplies
    Lexmark P6250 paper Jam
    Don't know if it's the same problem i had but its maybe worth a try. Canon MP160
    Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving push it through! and hey presto it worked for me, everything printing fine now
    Jan 27, 2008 | Lexmark P6250 All-In-One InkJet Photo...
    Paper jam, when there's not a paper jam?
    there is a small micro switch , when paper is loaded that switch
    is activated, bent switch, paper shreds jamed in switch, will cause paper feed problem.
    Jan 13, 2008 | Lexmark P4350 All-In-One InkJet Printer
    HP Photosmart C7280 Laser Printer Logo
    106 people viewed this question
    Ben Johnson
