Question about Jenn-Air JER8850 Electric Kitchen Range
My oven door came off and I can't get it back on
I need to get the oven door back on. It came off by mistake, and I've tried to get it back on, but it doesn't seem to work. What's the trick.
I have spilt milk flowing down the side fo oven/counter top and needed to pull out the stove to quickly get it wiped up..I pulled the stove out by the oven door handle. The hinge sprang on the right side and the oven door is now off on one side how to get it back on?? My husband lifted the door up and the whole door is now off.
It is very difficult to replace, what are we doing wrong???!!! Please help. I belive it is a whirlpool electronic model. thankyou.
Posted on Jul 27, 2009
How to unlock a Maytag double oven
Hi Mary,If the door locked after you started the oven!
Press Cancel/Off key to start a latch reset, wait 20-30 seconds and open door, or turn the power off at the circuit breaker or fuse box for one minute, then turn the power back on.
If the oven has a manual latch handle!
Allow the oven to cool, approximately 30-90 minutes, move the latch arm to the left to unlock the door.
If the latch arm will not move after cooling to room temperature, or is stuck in between full right and full left positions, schedule service.
Is the oven door locked due to power failure during Self-Clean? If the oven door locked due to a power failure during a self cleaning cycle!
Select the "Self Clean" option, then select "Cancel". Wait a couple of minutes then try to start the cycle again.
If you started the oven clean cycle by mistake!
Press Cancel/Off key. The oven will need to cool to approximately 200F(95C) before the oven door will open.
Was there an error message!
Follow directions in the display, and refer to the Error Code Symptom, or:
Reset power to the oven!
  • Power the oven down by turning off the circuit breaker(s) or fuse(s) or if you can, unplug the oven for one (1) minute.
  • Turn the power back on turning on the circuit breaker(s) or fuse(s) or plugging it back in.
  • Monitor the oven for one (1) minute to ensure the error code does not display again.
  • Verify the ovens operation.
Kind regards
David
Dec 04, 2017 | Maytag Kitchen Ranges
Good evening, I need your help. My gas stove stopped to work when I tried to change time. As for me, I touched by mistake the oven cleaning bottom. Currently door is blocked, and inside of oven there...
try plugging back in now, it shouldnt remember the last cycle it was in and should even try to test the lock/latch upon power up as part of a self diagnosis. fan would remain on only as long as unit emained hot(in order to keep the electronics cool)
Mar 14, 2008 | Kitchen Ranges
My GE wall oven is stuck on lock mode. I cancelled a self clean (I know, big mistake) and after cooling down it still won't unlock. I've cut the power and still nothing. It's been 3 days! Trying to avoid...
Try putting it back in self clean. Listen to see if it locks. then cancel the self clean. It could be the self clean lock motor has gone bad. The lock hook can be moved to unlock the door by inserting a stiff wire like a coat hanger between the door and the oven and moving the latch over to unlock the door.
Nov 07, 2014 | Ovens
Frigidaire Gas Self Cleaning Oven door open in lock position
Hello ericndiana6b - Was the unit in self-clean mode? Try pressing and holding the "Clear/Off" button to stop any operation of the EOC. Do this at the same time while pushing and hold the light switch to the left of the door lock. Usually this will trick the oven into unlocking the door. If it is ineffective, try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and redo the steps. If door continues to maintain locked while open, the unit may possibly have a faulty door latch or a communication problem with the EOC. Contact a professional to move forward accurately.
Nov 27, 2012 | Frigidaire GLGF376DQ Free-Standing Gas...
Rookie mistake... Resetting Dacor? Or replacing fuse?
when you turned the light cover you turned the whole socket and the power connection shorted and blew relay board
you need relay board and light socket
Jun 24, 2017 | Dacor Preference RSE30 Electric Kitchen...
Why should i pay you for your mistake
If you've payed some one and they've made a mistake and left, then later you've realised.. Hand on a second they need to come back and fix this right now.
The person responsible should come back and fix the problem totally free, thus giving the reason to pay some one for a mistake.
Jul 01, 2011 | Computers & Internet
Oven door won't unlock
kenmore selfcleaning oven door will not unlock code f9 appears in window
Jan 03, 2010 | Ovens
Using the self cleaning for the oven
look for the door/ light switch (the door would normally have this pushed in),and press and hold it in, tricking the unit into thinking the door is actually closed. press the clean button then, see what happens. it should try to close itself entirely and then press the cancel button, it should return to normal resting position
Mar 10, 2008 | Ovens
Jenn-Air JER8850 Electric Kitchen Range Logo
352 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
