Question about Audiovox LCM5620PKG 5.6 in. Car Monitor
Wire schematic for AUDIOVOX LCM5600
My video screen was put in improperly and grounded out the wires connecting to it. After taking the wire harness out it appears to have been custom installed as the harness is practically hard wired. The 6 wire plug doesn't quite seem to have been wired correctly as it had these wires: 1) + 12VDC 2) - GRD 3) - VID 4) + VID 5) - LEFT AUDIO 6) + LEFT AUDIO My concern is what about the -/+ RIGHT AUDIO? Shouldn't it be included somewhere? I am unable to locate the any wiring schematics to confirm the correct wires. Any help is greatly appreciated. Thx, copterdr
Inferno77
  • 6 Answers
SOURCE: Wire kit for a Audiovox BA200 200 Watt base tube
There are 5 wires to connect to the BA-200 for proper operation. 1. Red Wire with Fuse: Connect this wire to a source of + 12 volts which does not turn off with the ignition key. It may also be connected directly to the po~itive (+) terminal of the battery. 2. Black Wire: Secure this wire using a screw or bolt on a grounded metal surface of the vehicle. Clean-away any rust, dirt, or paint from the surface to make sure a good connection is made. 3. Blue Wire: This wire activates the BA-200 when the stereo system is turned on. Connect it to the "Power .Antenna" lead from your car stereo. If your car stereo does not have or you cannot locate the Power Antenna lead, the blue wire can be connected to a source of + 12 volts which is turned on and off with the ignition switch. In this case, the BA-200 will be activated whenever the ignition switch is turned on, whether the car stereo is on or off. 4. Green Wire: Splice this wire to the wire going to the positive (+) terminal (sometimes indicated bya red dot) of the left speaker of your stereo system. 5. G ray Wire: Splice this wire to the wire going to the positive ( + ) terminal (sometimes indicated bya red dot) of the right speaker of your stereo system. You Need to order this piece trough the manufacturer, with out this piece the sub is useless, i am guessing around $20-$30 for it
Posted on Jul 27, 2007
godspeed808
  • 125 Answers
SOURCE: 6 disc rampage audiovox modulator
You can go to this address and obtain wiring and product info:
http://audio.manualsonline.com/manuals/mfg/audiovox/audiovox_stereo_amplifier_product_list.html
enter in product info model number etc.
Posted on Feb 04, 2009
godspeed808
  • 125 Answers
SOURCE: audiovox modulator
enter in product model number and info
  • 7 Answers
SOURCE: i went to install an audiovox as-9076 in a 2003
Ya have to trace them out with a test light...! Pin the wires with the light and hit the lock un lock control untill you get the wires you need ZI seriously dought you need 3 where did you come up with 3 wires did you lose sa door in an accident???? Usualy if you hit the un lock once it opens the drivers door and twice opens ALL DOORS.. your power will be 12v battery probaly the first wire ya hooked up
t
h
e
n
a
l
l
a
h
h
h
Posted on Jul 16, 2010
SOURCE: I have a Audiovox car alarm model AS-9499 I need
Do you know where i can buy a audiovox model 9499 remote
Posted on Feb 01, 2012
I have a 2010 Vulcan 900 lt cruser and want to no how many wires to hook up a harness to haul a tiny trailer is it 4 or 5 wire and can I help me to install with a video thanks don
5 wires needed to wire a trailer of any size
1 wire for stop lights
1 wire for tail lights
2 wires for indicators==1 for each direction
i wire for ground return wire
the trailer connections have the wiring schematics or numbers for each wire on the packet
Jun 26, 2016 | 2010 kawasaki VN900 Custom
My 1998 pontiac grand prix gt has A code po1676
DTC P1676 Evaporative Emission (EVAP) Purge Solenoid Control Circuit
DTC P1676 set indicates an improper voltage level has been detected on the output circuit which controls the EVAP purge solenoid.
Circuit Description
Output Driver Modules (ODMs) are used by the PCM to turn on many of the current-driven devices that are needed to control various engine and Transaxle functions. Each ODM is capable of controlling up to 7 separate outputs by applying ground to the device which the PCM is commanding ON. Unlike the Quad Driver Modules (QDMs) used in prior model years, ODMs have the capability of diagnosing each output circuit individually.
Diagnostic Aids
Check for the following conditions:
Poor connection at the PCM.
Inspect harness connectors for backed out terminals, improper mating, broken locks, improperly formed or damaged terminals, and poor terminal to wire connection.
Damaged harness.
Inspect the wiring harness for damage. If the harness appears to be OK, disconnect the PCM, turn the ignition ON and observe a voltmeter connected between the EVAP purge solenoid control circuit and ground at the PCM harness connector while moving connectors and wiring harnesses related to the EVAP purge solenoid. A change in voltage will indicate the location of the malfunction.
May 01, 2015 | Pontiac Grand Prix Cars & Trucks
Vehicle wiring diagram
here is a wire diagram of Dodge Ram electrical system it seems your wiring may be either loose or attached incorrectly, check for improper connections and follow the wiring charts it's the best way to find the faulty connection.
https://w05.dealerconnect.chrysler.com/service/mds2002/serviceInfo/en_US/br808154.gif
Dec 07, 2013 | 1996 Dodge Ram Van Performance Exhaust...
I have a "12 kicker
If it is the amplifier that is shutting on and off:
Check to make sure the power and ground wires for the amp are secure, with no fraying, knicks or exposed wire. Check your fuses and connections to make sure everything is correct. Also look at the grounding location. be sure there is exposed metal around the grounding point (paint may cause intermittent power problems). Lastly, the amplifier's remote wire may be improperly secured to the wiring harness. Check the harness for exposed wire grounding out connections.
If the amplifier is continuously on, the subwoofer may be to blame. Check and double check wiring schematics to ensure correct ohms rating.
Feb 28, 2011 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
I need to order a wiring harness the yellow and black ground got pulled out during installing
try going to audiovox.com. audiovox now owns jensen. you should be able to email them or get a phone number on the website.
Sep 14, 2010 | Jensen's VM9312 Car DVD Player
Where do i connect da pink wire
connect da pink wire to the ground wire on the stereo units wiring harness. This will tell it you are in park.
May 13, 2010 | Audiovox VM9312 Car DVD Player
DUAL XDVD9101
the 9101 is built so you cant bypass
May 08, 2009 | Audiovox VM9512 Car DVD Player
Bypassing the emergency brake on the xdvd9101 with a toggle switc
ground wire to a normal 2 position toggle switch. put dvd in. turn switch on then off then on. there ya go.
May 03, 2009 | Audiovox Jensen In-Dash DVD/CD Receiver w/...
Audiovox LCM5620PKG 5.6 in. Car Monitor Logo
125 people viewed this question
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Marvin
Marvin
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
