Question about Evercool Intel P4 Socket 478 up to 3.4GHz Copper Fold Fin CPU Cooler CPU Cooling Kit
I need to find a replacement plastic cpu cooler mounting sockett.
It is either in an older Dell or HP computer. I am looking for a Model 478 sockett. Made out of plastic; about 4" square in configuration. One of the arms of the mounting sockett is broken so the power supply cannot attach (lock down) to the mounting properly. This in turn is causing the computer to overheat and shut down automatically.
I would appreciate any help you can give me as to where I could find this part either used or new. Thank you VERY much. Mike Ostanik
  • tazwegion
    tazwegion May 11, 2010
    Sounds like you're describing the socket 478 heatsink retention bracket, is that what you mean?
  • John Bolton May 11, 2010
    What are you looking for the 478 socket?
  • 50 Answers
I can tell you that the Socket 478 has been out for production for quite sometime now. Finding a new anything will be rather difficult. My suggestion is to either look on E-Bay for a similar PC that you can get the part(s) from, or check Radio Shack or other electronics outlet store. Good Luck!
Posted on Mar 11, 2009
What kind of CPU coolers are compatible with HP Pavilion a1710n?
That's a hard question to answer, you need to fine out what CPU you have inside and then look up CPU coolers for that CPU style. Since your using a pre assembled machine you may have a specialized hole pattern making an aftermarket cooler hard to find. and use.
Jul 29, 2010 | HP Pavilion a1710n (RK573AA#ABA) PC...
I have had my dell for about 6yrs, I need to replace both cooling fans and don`t know what to order!
Can't point you towards a specific model of fan or fans without knowing your specific Dell model.. BUT luckily there are standard sizes for cooling fans - quite a few sizes - but since we're talking about a 6 yr old Dell, well that narrows it down a little bit. Here's what you should do first: take a plain old ruler that measures in millimeters/centimeters and take a measurement of one of the sides on each existing fan (don't measure corner-to-corner). Your ruler will be easiest to read in centimeters but most fans are sized in millimeters until they start to hit 120mm and above. Most cooling fans are the same but there are two main jobs they've got to perform: cooling the case, or tower... and cooling the CPU, or processor. Case fans are straightforward and typically measure either 80mm or 120mm, and as I'm sure you're aware, are responsible for exhausting warm air. Let me guess -- is there a dusty green shroud that covers the processor and its cooling fan? Maybe not -- but most of the time these guys were present in 2004-era Dells (as well as today) - and the case fan would sit at the very back and pull air through. (Is the case fan attached using rubber cone fasteners? Yeah if thats the deal then those are toast, unless you're a surgeon for your day job). The rubber plugs are for noise isolation (and cost cutting) but not to worry -- your new case fan will be the strong silent type. Dell probably has a smaller Foxconn or JMC fan sitting on top of a heat sink, which is contacting the CPU (Pentium 4?). That size will probably be 50mm but my recommendation would be to determine what socket type you're using -- and with this information, you can just purchase a new modern CPU cooler (heat sink and integrated fan, maybe copper heat spreaders, yada yada). ---If you're comfortable enough to switch out fans then you can handle a Pentium cooler switcheroo.--- (An instruction manual would be supplied, btw). But you'd just pop the bracket or clips securing the heat sink to the CPU, pull it up and outta there, wipe off the exposed CPU surface with a dry microfiber -- or use wadding polish like Eagle Nevr-Dull and THEN use the microfiber, apply PEA-SIZED drop of thermal paste to surface of processor (paste comes with the cooler), clip on said cooler, and open beer. Here are some links to go look at... (there are literally trillions of online merchants selling compustuff) -- newegg.com is always a good one of course due to great cust svc and practically next-day "ground" shipping; for in-person purchasing, you can't beat Micro Center (microcenter.com), but they may not have a store nearby. Check these guys out - I've used them for Dell-specific parts before and I like how you can search for components based on socket type, processor model, etc... http://www.directron.com/cpu---coolers-cpu-coolers.html This page will list a bunch of socket types from which to choose -- and if you're using a Pentium 4 on a 2004 or 2005 Dimension, for example, you'd probably want to click the Socket 478. If you're unsure, go to support.dell.com and plug in your service tag and pull your orig specs.
(Complete alternative: Dell Outlet Store... refurbished Core2Duo or Core2Quad with 4GB dual-channel memory, or hey I'll build you a 10-year future proof system - you pick the case design - for less $$ and will make Dell's cookie cutter systems look like.. well, cookie cutter systems.) Bestoluck!
Jul 21, 2010 | Dell (6F858) Cooling Fan
Fastening Bracket for HP PC m270n PC CPU are broken and cannot fasten heat sink to CPU
Uses Intel processors, that fit in a Socket 478 processor socket. You need a mounting bracket like this, http://www.suntekstore.com/Socket-478-Intel-CPU-Mounting-Bracket.html
You're welcome.
Sometimes those brackets are hard to find
Jan 25, 2010 | HP Media Center PC M270n (DM161A#ABA) PC...
Pcu problems color not consistent
it will clip down so it is tight. You can get any cooler you like as long as it is for that chip. So find a cpu cooler that is for your socket type of pentium 4
So you need to find a cooler which is 478 compatible (478 is the socket type)
Jan 05, 2010 | Ricoh Aficio CL3500N Laser Printer
Motherboard ID Motherboard Name Compaq Evo
as long as it is a socket 478 processor which narrows it down to P4 or celeron ( P4 being better and faster ) it should be fine.
Obviously it will state what processors it can handle in the computer manual so if you find the manual it should state in there.
I dont think it will handle more then a 3ghz P4
Apr 18, 2009 | HP Compaq dc7100 PC Desktop
How to change
Hi
Replacing the heatsink fan on a PC is not a difficult job, but it pays to be thorough, especially with cleaning the top of the CPU die before replacing the fan.
Don't be mean with money when choosing a new cooler either. With CPU coolers you get what you pay for. I personally always use coolers from a company called Zalman.
Ok ..with that out of the way ..the basics are ...remove old cooler..
They are either held on by a sprung clip that fits across the cooler and locates in lugs on the cpu socket surround, or they are held by screws that go through the motherboard.
Clean the top face of the cpu die carefully making sure to use a blunt implement ..... scratches on the machined face will lead to premature failure due to overheating.
If the cooler you buy has a "thermal pad" stuck to the face of the heatsink, then remove this too and clean up the heatsink face. Use good quality thermal paste on the top face of the CPU die, then fit the new cooler. Getting the right amount of thermal paste is a bit of an art .... too much is a bad as too little. The paste is NOT a glue. The paste simply fills in any imperfections on the machined surfaces of the cpu die and the heatsink to aid heat transfer.
Does this sound complicated? It isn't really. The key is not to rush it and make sure the surfaces are completley clean and the thermal paste applied correctly.
Here is a link to one tutorial on fitting cpu coolers that you might find useful:
http://www.jsyte.com/tutorials/replacehsf
Oct 31, 2008 | Intel Socket 478 CPU COLLING FAN & HEAT...
Audio driver
I think you might be picking up the wrong model, RTL (Realtek) 8100 series is a network device. Can you make sure of the model number please.
If you still need the drivers for RTL (Realtek) they can be found at: http://www.realtek.com.tw/downloads/
If not please supply the full details of the device your are looking for.
May 11, 2008 | Intel Foxconn: Foxconn CPU Cooler For P4...
Suitable CPU air cooler
I suppose you have done your homework as to if u really *need* to buy a new cooler. Is ur CPU getting HOT? what temperatures does it run at? Your choice of cooler depends on what you plan to do with it. Do you plan to overclock your system? I would suggest a Coolermaster stock copper cooling system. Zalman is also good but expensive. But as i said depends on what u wanna do with the system and if u really need that extra cooling if you dont plan to overclock your system.
Dec 24, 2007 | EliteGroup ECS P4M800-M Socket...
Evercool Intel P4 Socket 478 up to 3.4GHz Copper Fold Fin CPU Cooler CPU Cooling Kit Logo
260 people viewed this question
Top Evercool Computers & Internet Experts
David Payne
David Payne
Are you an Evercool Computer and Internet Expert? Answer questions, earn points and help others
