Question about HP Officejet Pro L7680 All-In-One Printer
Only prints duplex
The printer will only print in duplex despite duplex/double-sided printing being unchecked. No matter what I tell it to do it will always print in duplex.
  • HP Master
  • 419 Answers
There's a firmware update and driver update available on the HP.com website...
I'd recommend updating both and then seeing if the problem remains...
Posted on Jan 24, 2009
Duplex printing in HP 2420dn on Mac OS X Lion 10.7.4
According to the specs, this printer does not have a duplex unit and therefore cannot print double sided prints.
DOUBLE SIDED PRINTING USING A SINGLE SIDED PRINTER
If your printer does not have a duplex unit then the printercannot print double sided pages automatically.
You can print double sided pages but you have to do it one page at a time.
First print Page 1 then place the page back into the paper tray, but turn thepage upside down and the print Page 2.
Then print page 3 on one side then page 4 on the other side and repeat for therest of the document.
I suggest you try a test page first, to get the printing the right way up onboth sides of the page so it reads correctly.
Jul 17, 2012 | HP LaserJet 2420 Printer
How to duplex print with 895cxi
This model printer does not have a duplex unit and cannot print double sided documents automatically.
Jul 08, 2012 | HP DeskJet 895cxi InkJet Printer
HP D7260 will not print two sided
This model printer does not have a duplex unit and therefore cannot print double sided printing automatically.
Jun 13, 2012 | HP Photosmart D7260 Printer
How to set a MG5220 printer to do 2-sided copies?
The Canon MG5220 has a built-in auto duplexer and can print 2-sided documents. On a Mac, click print, and in the print dialog box select Duplex Printing & Margins (drop down options below Printer and Presets). Check the Duplex Priting box, and selected the Stapling side. Then click Print. That's it!!
Feb 05, 2011 | Canon PIXMA iP90v Printer
I used the print on both sides of paper. Now when I try to uncheck the print both sides it shows it unchecked but the next time I print something the arrow prints and tells me to turn paper over. How do...
folow these steps : start / control panel / printers and faxes / right click on your printer / proprieties / now here some ware u got to uncek the duplex printing , after that clik aply an ok.
Feb 02, 2011 | Lexmark Office Equipment & Supplies
Can you please tell me how to print double sided? Thanks
Xerox Phaser 8400 does not support double sided prints. You have to have a Duplex Unit for Phaser 8400 part number 097S03177 to be able to print double sided. If you have the duplex unit, on the Print dialog box just click Preferences and under 2-Sided Printing select 2-Sided Print then Apply.
Nov 16, 2010 | Xerox Phaser 8400 Laser Printer
How do I print double sided? The "Print Type = Double Sided" check box isn't doing it.
the duplexer may not be installed on the driver to chack this:
go to the properties of the driver on your computer
click start
then control panel
then double click printers and faxes
then right click on the konica bizhub driverand click on properties
click the options tab on the driver and under duplex unit make sure the drop down menu says installed
if it shows the duplex unit is installed then check the application you are using to see if it has duplex settings some applications have there own settings for document properties that you can change to duplex and the application settings will take over no matter what you tell the driver to do and some applitions will not allow you to make changes so duplexing may not be allowed
Dec 02, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Do pixma Mp610 support duplex printing
The MP610 does support duplex printing.
Duplex Printing
The duplex printing function allows you to print data on both sides of a sheet of paper.
The procedure for performing duplex printing is as follows:
Performing automatic duplex printing
You can perform the duplex printing without having to turn over the paper.
1. Open the printer driver setup window, check the Duplex Printing check box, and confirm that Automatic is checked.
2. Select Normal-size Printing (or Fit-to-Page Printing, Scaled Printing or Page Layout Printing) from the Page Layout list.
3. When printing a document that has small margins, click Print Area Setup... and set the print area.
When you perform duplex printing, the print area of the document becomes slightly narrower than usual and the document may not fit on one page.
sub.gifTo print without reducing the page:
Select Use normal-size printing.
sub.gifTo reduce the page slightly during printing:
Select Use reduced printing.
4. Specify Staple Side.
The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position. Check the Staple Side setting. If you want to change the setting, select another value from the list.
5. If necessary, click Specify Margin... and set the Margin width.
6. Click OK.
Duplex printing will be started.
Performing duplex printing manually
You can perform the duplex printing manually.
1. Check the Duplex Printing check box and uncheck the Automatic check box on the Page Setup tab.
3. Specify Staple Side.
4. If necessary, click Specify Margin... and set the Margin width.
5. Click OK.
sub.gifIf a media type other than Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed on one side of a sheet of paper. When printing is complete, reload paper according to the displayed message and then click OK. The document will be printed on the opposite side.
sub.gifIf Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed front and back alternately for one sheet at a time. Load the paper according to the displayed messages.
caution.gif Note sub.gifDuplex Printing is unavailable when:
- A media type other than Plain Paper, Photo Paper Plus Double Sided or Hagaki is selected from the Media Type list.
- Poster Printing is selected from the Page Layout list.
sub.gifWhen Booklet Printing is selected from the Page Layout list, Duplex Printing and Staple Side appear grayed out and are unavailable.
sub.gifAfter printing the front page, there is an ink drying wait time before starting to print the back page (Operation stops temporarily). Do not touch the paper during the time. You can change the Ink Drying Wait Time at Custom Settings on the Maintenance tab of the printer driver.
sub.gifWhen you perform the automatic duplex printing for Hagaki, print an address first and then print your message.
refer.gif Tip sub.gifIf you select Photo Paper Plus Double Sided for Media Type on the Main tab, the Duplex Printing check box on the Page Setup tab is not checked automatically. To perform duplex printing, check the Duplex Printing check box.
sub.gifIf the Media Type dialog box appears when performing borderless printing during duplex printing, select Plain Paper or Photo Paper Plus Double Sided.
sub.gifWhen performing the automatic duplex printing, do not use any plain paper smaller than A5. Also, do not select any type of paper other than Plain Paper, Photo Paper Plus Double Sided or Hagaki at Media Type.
sub.gifPhoto Paper Plus Double Sided is highly recommended for printing photographs on both sides of a page.
sub.gifIf the back side of the paper becomes smudged during duplex printing, perform Bottom Plate Cleaning in the Maintenance tab.
Aug 17, 2009 | Canon PIXMA MP610 InkJet Printer
Double sided printing
In this printer u dont have duplex print mode,u can use only manully.
Oct 10, 2008 | Canon PIXMA iP3500 Printer
Two-sided printing
On a PC...
- Ctrl + p to print
- Choose the Canon MP530 if it's not already selected
- Click Properties button
- Page Setup tab
- Select Duplex Printing
My paper always gets jammed, so I always uncheck the Automatic checkbox. Hopefully you won't have to do that.
Good luck.
Nov 13, 2007 | Canon PIXMA MP530 All-In-One InkJet...
HP Officejet Pro L7680 All-In-One Printer Logo
217 people viewed this question
Seeker5211
Seeker5211
