Question about Neff U1421 Double circotherm Electric Oven
Do i ned instructions to fit new door seals i have the parts
The doors are the round corner type
  • Neff Master
  • 3,463 Answers
See if you can lift the corner of the seal and see if there is a hook of some kind, if there is then all you do is unhook each corner, and remove seal, if no hooks, then it may be one of these tjhat is held in place by the the oven liner, and this is more of a tricky job to do.
Plz rate my solution.
Thanks.
Posted on Jan 10, 2009
Smeg large oven, takes a lifetime to pre heat, I have changed the seal on the door but it hasn't made a difference, any suggestions?
Don't know 'bout yours but have you tried the old tea towel in the corners trick to see if its the hinge alignment and not the seal? Put two tea towels in the lower corners sticking out of the oven part way and push the oven door closed a few times. Saved me from trying to replace the seal on my Miele.
Oct 26, 2013 | Ovens
How to replace the seal on Electrolux oven between oven and door
This might not be helpful to you, but have you tried the old tea towel in the corners trick to see if its the hinge alignment and not the seal? Put two tea towels in the lower corners sticking out of the oven part way and push the oven door closed a few times. Saved me from trying to replace the seal on my Miele.
Oct 23, 2013 | Ovens
Hi I have a Bosch Double Oven/convection Oven I
Don't know but have you tried the old tea towel in the corners trick to see if its the hinge alignment and not the seal? Put two tea towels in the lower corners sticking out of the oven part way and push the oven door closed a few times. Saved me from trying to replace the seal.
Oct 04, 2013 | Ovens
B1432 door gasket wanted with rounded corners
I believe this is the oven door seal. You can purchase this online from Ransomespares.co.uk product code RS46105 cost £29.25. Easy to fit, each rounded corner has little metal hooks which fit into the pre-drilled hole on the oven itself, simply unhook the old one and replace with the new, simple.
Jun 20, 2011 | Neff B1432 Single circotherm plus Electric...
Locked oven door to clean. Need instructions to
These might help you get the door off
These Videos will help with your cooker problem.
If you need more video help on appliance repairs visit our Video Tutorial Library at our website
1 how to remove your oven door for cleaning or repairs and how to reseat the door when finished.
2 How to change and fit oven door hinges.
We can not allways cover Every model but hope this helps. Remember to send us an email if you can’t find the part you need.
We also supply all the Parts you need for Repairing your cooker oven Door.
Oven Door Hinge Spare Parts
Oven Door Glass panels
Cooker Door Handels ETC
Cooker Door Catches ETC
Cooker & Oven Door Seal / Gaskets
Remember to Leave feed Back and pass our site on to your Friends:
Our Shop http://www.apart4u.co.uk
Our Video Help Section http://www.apart4u.co.uk/video-tutorials.html
Mar 04, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Can I get replacement door for my top oven, and new door seals for Creda Cachet Solarplus Model 48182, serial 60.1.00082
we should be able to help if you contact the office
Mar 04, 2010 | Ovens
Inner glass on bosch HBC84k550b microwave shattered following arcing - have ordered replacement but need instructions on fitting it correctly
Strangely enough I had exactly the same problem but today managed to fit the new inner glass and door panels without any problems, here is how.
YOU NEED 2 PEOPLE FOR THIS STEP. Open the door, at the top are 2 large plastics flat head screws, undo these making sure your helper is holding the door securely or itll fall on the floor, te door will unhook once the screws are fully undone
Once off you can close the microwave back up.
Now there are two screws, one in each top corner holding a funny looking plastic wing shape that slides into the inner door. They have a star screw head. Undo both of these and remove the plastic wings. When you remove these the panel underneath will try to fall off so be prepared to catch it, along with the plastic screws undone in step 1. This now unhooks like the main door did.
From here you'll be able to see the back of the inner glass. This is held in by a mesh at the back and about 15 screws, star headed again. you can simply remove all of these, that will release the front panel over the inner glass, again, you might want someone to hold the door open so the panel does not drop when you remove the last screws.
Thats it as far as taking the microwave apart. put your new glass in, remembering to make sure the rubber seal is put back between the glass and inner door.
Simply reverse the process.
It took me approximately 1 hour and I am by no means a DIY person.
Good Luck
Mike
Dec 15, 2009 | Bosch Ovens
Oven door does not close fully
You need to replace the oven door hinges.
Please rate my solutrion.
Thanks.
May 15, 2009 | Neff B1421 Electric Single Oven
How do i fit new door seals for an neff u1421 double oven i have the seals
If the seals have what appears to be hooks at the corners, then unhook the old seals and re hook the new seals into the holes in the front of oven .
If no hooks, then the front of the oven needs to be unfastened.to replace the seals.
Thanks.
Jan 14, 2009 | Neff U1421 Double circotherm Electric Oven
New World G90M
Normally they are held on with metal clips at each corner, just pull the seal back and unhook the clips to remove the seal..
Re fit by hooking the clips into the holes in the front of the oven, you will probably have to stretch the seal to get it to fit with it being new.
Plz rate this solution.
Thanks.
Dec 19, 2008 | New World G90m Gas Double Oven
Neff U1421 Double circotherm Electric Oven Logo
163 people viewed this question
Top Neff Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
Are you a Neff Oven Expert? Answer questions, earn points and help others
