Question about Gateway FPD1530 15" Flat Panel LCD Monitor
I am trying to connect a Gateway FPD1530 15" LCD flat screen monitor to a Dell PC. Do I need to install software for the PC to recognize the monitor? I don't have any.
  • 27 Answers
You shouldn't have to install any software. Windows usually recognizes the monitor without a problem.
Dman
Posted on Jan 08, 2009
Usb ports do not work
I have a 24" Dell monitor with built-in USB and SD sockets. Sometimes I have had problems with these not being responsive. This usually comes down to electrical connection.
You should do these in order, also testing for USB port availability at each step .
#1 is the monitor powered up? (USB is active only when monitor is switched on with power button on front of bezel)
#2 check that the USB cable at both ends is plugged in! (you need electrical connectivity)
#3 check that the USB port on the PC can see another device like a memory stick
#4 check your PC's software (drivers must be loaded and the USB port recognized)
Sep 25, 2012 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Attempting to install tft lcd monitor on new processer, have intall disc, but monitor will not come on ????
Hello.
Be certain that the install disc software works with your operating system. What specific monitor and your operating system (Windows 7, etc.).
Also, be certain that the monitor cable is connected to a USB port. Try another port.
When you said "not come on" do you mean no power or a dark screen ?
Try your monitor on another PC to see if monitor problem.
Hope this helps.
Jul 20, 2010 | Gateway Computers & Internet
Hooking up the monitor
She should not have a prioblem. The PC should recognize new devise and look for the driver. If it says that driver not found, Go to DriverGuide, this is a great website and you can download any driver for FREE. Install it then she should have noprobs.
Jun 15, 2009 | Sylvania CL772B 17" Flat Panel LCD Monitor
Washed out monitor when viewing most web pages
exchange your dell monitor to gateway monitor.If the monitor from dell showed the same problem when you connect it to gateway. you must install video card driver. and if the monitor from gateway showed the same problem when you connect it to dell adjust your contrast to full and the brightness to 50% and adjust the colors to 100%
May 13, 2009 | Gateway Profile 5 PC Desktop
Frequency out of range
You need to install the video drivers for your monitor. Go into SAFE mode to install them.
Mar 29, 2009 | Gateway FPD1960 19" Flat Panel LCD Monitor
Installing monitor problem
The Gateway FPD1530 is plug and play and should be automatically detected by the Operating System. In your display properties it will say plug and play monitor as Monitor type.
Jan 08, 2009 | Gateway FPD1530 15" Flat Panel LCD Monitor
I have a new Dell Studio 540 computer and I'd like to hook it up to my Gateway EV910 monitor. I connected everything correctly. The monitor has power, turns on to the monitor self test screen where it...
You dont need to install a driver for the monitor. The power save mode message appears when the monitor is not able to get a signal from the computer. Make sure the the vga/blue cable is securely plugged to the back of the pc.
note: Inspect the back of your studio. You may have two blue ports where you can connect the monitor, if you do, connect the monitor to the one at the bottom half of the computer.
Jan 02, 2009 | Gateway EV 910 19" CRT Monitor
LG lcd computer monitor
try to connect your old monitor and adjust your screen properties down to 800x600 with medium color setting..or go to xp safe mode, adjust screen properties to the lowest setting, xp has not yet installed the monitor driver of your lg lcd monitor.
May 21, 2008 | Gateway FPD2275W LCD Monitor
Monitor Message = "No Signal"
see i use Compaq too
they don't generally except other modes
did u try that monitor with other pc where it worked
u should install proper monitor software ... u will found it from the cd given wit Ur monitor
Apr 24, 2008 | Mag Innovision lt456s 14" Flat Panel LCD...
Gateway FPD1530 15" Flat Panel LCD Monitor Logo
99 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
