Question about Proscan 19LA25Q 19 in. LCD Television
Hi my name is lily i have a ploblem with my tv is proscan 19inchla25q i try to turn it on but it wont go on the red ligt flashes gree then it turn back on in red
    New Friend:
  • 42 Answers
The power supply is bad. It supplies enough power to light the red LED when the tv is powered off, but not enough to power up the tv. You can find one on ebay.
Posted on Jan 15, 2009
Red power light flashes and set wont come on
Hi
Turn off the tv for five minutes and then turn on..
Can u tell me model no and company name so that i can help u clearly
thank you
Oct 12, 2008 | Hitachi 46F510 46" Projection HDTV
How do i fix a proscan tv to turn, only a red and blue light are on
Well without actually opening it up and determining where the problem is, it's unlikely you will get it to come back on. I suspect something wrong with the power supply but it could be something else also.
Mar 02, 2015 | Proscan 32LA30Q Television
I tried to program a universal remote to my Led Proscan tv and now it just flashes different colors. How do I get it to stop?
hi,
I think some how you have gone into service mode on the tv.
you may need to take it into a repair shop so the can re-set it back.
sounds like it to me.
hope this helps
May 21, 2014 | Proscan PLED5529A 55" LED TV 1920x1080,...
I need to program a proscan univ remote to a phillips tv
Codes to check with Proscan TVs are: 0031 0107 0015 0000 0162 0163
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1200 posts to different brand TVs now. Pull up older posts there.
Nov 17, 2012 | Televison & Video
Tv wont trurn on
Re-check the lamp door alignment. If the door is not installed properly, the interlock switch will open causing a no start condition. Also observe the red LED on the front panel. When you turn on the TV, a gree LED will blink on and off until the image appears. If the image fails to appear the green LED will give way to a red LED that will flash a specific number of times in between pauses. 3 blinks means the door is not installed correctly. 4 blinks means that a fan has stopped working, etc.
michtech
Feb 17, 2009 | Sony KDS-50A2000 50" HDTV
Cant find the part
Try shopjimmy.com ,Good Luck
Jan 31, 2009 | Proscan 42LA45H 42 in. LCD TV
I cant get the tv to come on it has power
You have a bad power supply (AC adapter). Watch closely at the red light while turning tv on to see if red light momentarily flashes green, then back to red.
Dec 15, 2008 | Proscan 19LA25Q 19 in. LCD Television
Remote not working
If this TV came with an universal remote, try pressing the TV key. Sometimes it works.
If that did not work any other RCA, GE, Proscan universal should work.
Feb 07, 2008 | Proscan 26LA30Q 26 in. LCD Television
Proscan 19LA25Q 19 in. LCD Television Logo
320 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
