Question about Amana ACD2232HR Side by Side Refrigerator
Freezer works but not the fridge
The freezer works fine just the Fridge doesn't cool at all
  • miesh7248524 Jan 08, 2009
    ok the fan works and there was ice build up so I removed all the ice and now running normal again but its probably going to do it all over again right?
    Sergeant:
    Champion:
  • 262 Answers
Check and see if there is ice build up on the rear of the freezer if so push in your door switch/s and see if the fan runs if not replace fan if so you have a defrost problem located behind the cover in the freezer let me know what you find and get back to me and i can help you more
bill
Posted on Jan 08, 2009
  • Bill Dozier Jan 10, 2009
    yes in several days you need to replace the heater and the thermostat and tht should take care of the issue.......bill
  • 17 Answers
SOURCE: fan not working on fridge section of Hotpoint Fridge Freezer Model FFA90
the problem is there is a build up of ice insid of the freezer .
What you need to do is take out all your draws in the freezer and you will see a plastic backing held on with about 8 screws . undo all the screws and the back should come aay and you will see all the ice built up . just use a hair drier to melt the ice and that should cure your problem.
Posted on Dec 10, 2007
philbran
  • 242 Answers
SOURCE: Fridge on Fridge freezer not working
Ok there is a drain pan under the evap. coil under the fan that may be clogged and full of ice there is a 3/4" hole the water drains out of that needs cleared if there is a puddle of ice over it , the ice will also effect the airflow traveling down the duct to the fresh food section of the unit.
If there is no ice puddle at the bottom of the refrigerator then make sure the unit is cooling well by making sure it has been running for 10 min. or so and checking the coil in the freezer , it should have a small layer of frost on it showing its getting cold the whole way through it. Let me know how this works.
Phil
Posted on Jan 02, 2009
SOURCE: My Whirlpool cb18m Fridge Freezer works fine but
check to see if the evaporator fan is working in the back of the freezer panel
Posted on Jul 20, 2009
woodchuck789
  • 4070 Answers
SOURCE: zanussi fridge compartment has stopped cooling but freezer is ok
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
OR.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Posted on Aug 24, 2009
  • 93 Answers
SOURCE: my refrigerator won't stay cool but my freezer works fine
You have something wrong with the vent going from the freezer to the fridge. You probably have a defrost problem and ice is blocking the vent that goes from the freezer and comes out in the roof of the rerigerator compartment. Replace your defrost timer and bimetal.
Posted on Sep 11, 2009
Fridge won't cool but freezer working fine
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Oct 31, 2011 | Refrigerators
The fridge (kenmore) doesn't seem to be cooling but the freezer (on the bottom) seems to be working fine. Help! :((( Single mom
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 01, 2011 | Refrigerators
Freezer works fine but fridge doesn't get to cold any more
heatman101
Jul 31, 2011 | GE Refrigerators
EL7ATRR Refrigerator: Freezer working fine but fridge not cooling...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 17, 2010 | Whirlpool EL7ATRR Refrigerator
The fridge is cold but the freezer won't freeze
It has seperate cooling circuits as you describe the problem can be a leak of refrigerant in the freezer circuit.if there is no heating up in the freezer condensing coil.It has to be check for the leakage.
Jul 01, 2009 | Freezers
My freezer works fine, but the fridge doesn't
The air channel from the freezer to the fridge is probably blocked. Give it a full defrost to melt the ice from the cooling fins inside the freezer walls.
Mar 20, 2009 | Refrigerators
Amana ACD2232HR Side by Side Refrigerator Logo
81 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
