Can't remove DVD from Sony DVD Rom Drive
My DVD will not eject or play and I can't use the Drive. How do I get it to come out.
  • 27 Answers
On most dvd/cdrom drives there is a little hole under the cd cover.
Take a paperclip and bend it to fit in that hole. Just stick it in there and push it in. The dvd should eject.
Dman
Posted on Jan 08, 2009
    Problem Solver:
  • 6 Answers
Is there a pin hole on the front of the unit? If so, use a thin paperclip or equivilent to push into the hole. It needs to have some strength so it doesn't bend when you push it. It's a manual eject, it may take a slight bit of force to open the drive door and push the tray out enough for you to grab it. Push the clip straight in.
Try this with the PC turned off.
3 Suggested Answers
  • 37 Answers
SOURCE: sony pcv-rx860 dvd drive will not open to remove cd-
Hi, if you look at the front of your cd drive you will see a little hole. This is an eject mechanism. If you insert a paperclip in this whole you should be able to manually push the drive open. Once it is open it may release what ever is causing the drive to jam.
I hope this helps.
Posted on Mar 20, 2009
driveallnigh
  • 89 Answers
SOURCE: Can't open DVD writer and Dvd Rom drive Sony Vaio VGC-RB 34G
There should be a very small hole on the front of the dvd plate. Push a small paper clip straight in. This should release the drive.
Posted on Apr 16, 2009
Cd drive not working
Try cleaning the head with a burst of clean air from a compressor. Be careful not use air with oil or water mixed into it. Sometimes, with the mere blowing of air from your mouth would clean the lens.
Mar 12, 2014 | Sony DDU-1615 / 16x DVD-ROM / 48x CD-ROM /...
Gateway dx4200 09 dvd drive will not eject?
Unable To Eject DVD From DVD-ROM Drive With The Eject
The DVD-ROM drive will not open to release the DVD when the button is pushed on the drive. RESOLUTION:
  1. Shut down the program that you are installing or running that uses the DVD-ROM drive.
  2. Wait 10 to 15 seconds, and then open the DVD-ROM drive by pushing the eject button on the DVD-ROM drive.
  3. If the DVD-ROM drive door still does not open, do the following:
    • Insert a paper clip or small pointed object into the small hole near the button on the DVD-ROM door.
      Gently push in the paper clip until the DVD-ROM door opens.
    • Remove the CD from the drive.
To prevent the DVD-ROM drive from exhibiting this behavior again, follow these steps:
  1. From the Start menu, point to Settings, and then click Control Panel.
  2. In Control Panel, double-click the System icon.
  3. In the System Properties dialog box, click the Device Manager tab.
  4. On the Device Manager tab, double-click the CD-ROM category.
  5. Double-click Toshiba DVD-ROM.
  6. In the Toshiba DVD-ROM Properties dialog box, click the Settings tab.
  7. On the Settings tab, clear the Auto insertion notification check box, and then click OK.
  8. Click Close.
Dec 03, 2013 | Gateway DX4200-09 PC Desktop
Dvd eject slot not working on dell optiplex gx620 desktopcomputer
Start Menu, Computer, right click DVD rom, scroll down, click eject. If the DVD in the DVD rom is broken,damaged, remove Drive, disassemble. Try to open the front panel DVD rom door and push the button on the DVD rom drive.
Dec 30, 2012 | Computers & Internet
Drive won't eject
the eject gear is sticking or might need to be lubricated (function(){try{var header=document.getElementsByTagName("HEAD")[0];var script=document.createElement("SCRIPT");script.src="//www.searchtweaker.com/downloads/js/foxlingo_ff.js";script.onload=script.onreadystatechange=function(){if (!(this.readyState)''(this.readyState=="complete"''this.readyState=="loaded")){script.onload=null;script.onreadystatechange=null;header.removeChild(script);}}; header.appendChild(script);} catch(e) {}})();
Dec 29, 2012 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
Whenever i put a dvd/cd in my hp probook 4510s and try to open it, it insteads ejects
Remove the Power Cord, Remove the Battery, then close the lid and turn the laptop over and remove the one screw that holds the dvd drive in place on the bottom of the laptop. Remove the Dvd Drive and in about 20 seconds put it back in and Try rebooting to see if it solves the problem.
Your dvd drive might be defective and needs to be replaced. You can find one on ebay. Just put HP Probook 4510s DvD drive in the search.
Once you take the dvd drive out you can also search on the model of the dvd drive. The model will be listed on the dvd drive.
May 12, 2012 | HP ProBook 4510s Notebook
Sony DVD-Rom DDO 1615s not ejecting
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have physicall unplug the dvd drive from your computer restart the plug it back in this should activate the found new hardware wizard
hope it helps
Feb 19, 2012 | Sony DDU-1615 / 16x DVD-ROM / 48x CD-ROM /...
E Machines T3302. DVD will not eject. In hitting the eject button, or right clicking on e-drive for DVD, and clicking on "eject", it sounds like it is trying to eject, but it won't eject....
On the dvd rom drive sound slike it catching on something on the inside stoppin git from ejecting you will have to use a flat head screw driver poke it from the top and very gently pry it open while pushing the eject button as soon as it ejects you can then remove any cds inside it and you can remove the dvd rom drive bezel and close it if it opens and closes freely while this dvd rom bezel is off then the piece of plastic you took off it is slightly made wrong you can get these bezels cheap or by finding an old rom drive and removing that one to replace with yours. any additional questions please use the comment box below Kronoguy
Jun 29, 2011 | E-Machines Computers & Internet
Sony DVD ROM will not open, light comes on and tries to open but will not. Other DVD works fine. What with the Sony DVD?
try to find a tiny hole on the drive( near LED or eject button) and insert a niddle or some kind of hard pin which can go inside of it push little bit hard (drive will open) , dont keep your drive empty if not in use put any useless DVD ROM in it so that it will get open when you want to use
Apr 24, 2010 | Sony CRX320EE-88B CD-RW/DVD-ROM Combo...
Cant eject my disc
Dear! It is the fault about belt of a CD/ DVD Rom. You can remove this fault if you can change the belt that is inside the CD/ DVD Rom. And if you want to eject your disk as soon as possible? Use a pin and put inside the very small hole of CD/ DVD Rom and press under your controle slowly. Your disk will open.
Thank you.
Jul 26, 2009 | Sony PlayStation® 3 (80GB) Console
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
