Question about Sharp LC-26D6U 26 in. LCD Television
Hitachi lcd red flashing light.
Hi Ive been looking for the fault diagnosis on a hitachi 32LD8D20 LCD. When its plugged in its flashing a red led on and off constantly and wont turn on. I havent even had chance to look inside it yet but I was wondering what it meant. I know it means something and I have found a few lcd's on here with the same problem but couldnt find any solutions as of yet.
Thanks in advance to any help, Its most appreciated!!!
  • Steve Penman Jan 08, 2009
    just got it to work for around 5 mins. it now comes on with green light for around 5 seconds then flashes red for around .5 - 1 second then back to green for another 5 seconds and keeps going like that!?! it was working for a while so I was wondering if anyone knew of any loose connections it might have on any of the pcb's that might cause this problem?
    Cheers Steve
  • Steve Penman Mar 05, 2009
    I fixed it. I stripped it down and found a dry soldered joint. touched it up and it works now.
Power sapli problam
Posted on Mar 23, 2009
The menu keeps flashing on and off. I have turn the tv off 4 or 5 times but it still keeps flashing the light on the bottom of tv goes blue then red really fast
How old is your TV? This normally indicates a power problem. It could be any of the following: power supply on the TV, faulty power strip, faulty wall outlet, faulty circuit board inside the TV, faulty power cord/plug, bad airflow/clogged vents restricting air movement into the TV (can cause intermittent power faults),bad sensor inside TV. This is not completely inclusive by any means. It does mean that you should have it looked at. Someone knowledgeable/skilled should be able to determine the cause fairly quickly using a multimeter.
Apr 25, 2017 | Televison & Video
Large red spots growing in the middle of my 50v500 hitachi projection LCD screen
Hi, you have an Optical Engine fault. Complete assembly needs to be replaced. This page shows the most common Hitachi Optical Engine Faults.
Hitachi LCD TV Light Engine Optical Block Info
Nov 27, 2015 | Hitachi Televison & Video
I have an Hitachi (L22DG07U) 22 Inch LED LCD DVD Combi TV that will not turn on, the lights flash between red and blue but no picture.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Nov 19, 2014 | Hitachi Televison & Video
My Hitachi 50V710 has both indicator lights blinking and does not display any image. Temp LED and Lamp LED. But I hear the fan running and the lamp is the same I've always had. Whats wrong?
With both LED's flashing sounds like a bad lamp to me. Not uncommon for Hitachis LCD projections to have that symptom. Cjeck your owners manual for the light flash code. Good luck..
Jun 20, 2009 | Hitachi 42V710 42" Rear Projection HDTV
Hitachi 32LD8700 - TV won't turn on although has power
The general problem with LCD type TV's is that the power supply fails. They are very sophisticated designs that are difficult to troubleshoot and generally best to just replace the module, but sometimes there is visible damage in some of the electrolytic capacitors (visibly bulged) and high voltage rated parts can be substituted.
Hope Ya Fix It
Feb 10, 2008 | Hitachi 32LD8700 32 in. LCD Television
Sharp LC-26D6U 26 in. LCD Television Logo
414 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
