Question about Honeywell CT87B ROUND HEATING&COOLING MECHANICAL THERMOSTAT - WHITE Heater
Cold air will not turn on
I installed the white round honeywell thermostat this last winter, and the heat immediately turned on. Now it's summer, and I tried turning on the cold air for the first time and nothing is happening. Any ideas?? thanks, ultra
  • 2 more comments
  • Anonymous May 06, 2008
    Im having the same problem I installed a therostat ct87n4450 heat works but no air. I have 4 wires YGWR. Any help?
  • nicknamedog May 19, 2008
    honeywell non programable stat air does not work heat works but not air
    wires coming through the wall are g,r,w,b model # CT87N4450
  • woody11 Jun 23, 2008
    honeywell non programable stat air does not work heat works but not air wires coming through the wall are g,r,w,b model # CT87N4450
  • merie Nov 21, 2008
    Has anyone answered this. My fan will come on if set at about 80.
  • 23 Answers
Check your wireing make sure that you dont have the red wire touching the white
Posted on Jan 08, 2010
I have the 5 day. 2 day programmable thermostat. Installed in the winter but now that it is summer air conditioner won't come on. Can you please advise?
You should always include model number in requests. More info is better. In general, there is a setting for Heat and cold on cheaper thermostats. Mine is like that. It works for heating in winter and you must switch it to "cool" for summer. I assume you do have an AC unit for summer. Who wired it up? was it ever working? Did it get installed during winter? The wiring may be wrong, there are a lot of possible ways to wire. If you are not good at that (and why would you be here if you were?) better get a tech to check it out. In the old days, Edison might send out a tech for free to advise (not fix) if there is a possibility of short (dangerous).
May 20, 2017 | Heating & Cooling
Honeywell thermostat blank screen on cool
I wonder if they shorted a wire a during install. That is where I would begin.
May 14, 2013 | Honeywell Rth2310b 5-2 Day Programmable...
We have just had a Honeywell H46C humidity controller installed. The technician told us to set both the humidistat and digital thermostat at 65 degrees when we leave the FL condo for the summer. Is this...
If you are leaving for SUMMER, definitely do not need to set at 65, that would be tremendous waste of energy. Humidistat in summer should be off. I wonder if he thought you would be gone during winter.
Feb 04, 2011 | Honeywell Heating & Cooling
Honeywell RTH2310B Programmable Thermostat
i would check to see if thier is a jumper between RC and RH on the stat if no and the red wire is hooked to RH then you need to add a jumper to RC
Sep 19, 2009 | Honeywell Focus 6300B 5-2 Days...
Honeywell humidistat stuck
what i would do is make sure tha the hole for the wires that go to the humidistat is completely closed and that you are sensing the true humidity for the space also have the tech wire the so that the heat comes on instead of the ac for the de-hiumidification process.
Feb 10, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
My heat wont turn off
Whan your room is up to temp or room is set at 70 and your stat is at 70 do you hear the stat click off .if not its a bad stat. you will have a little flam on your stat that should go off also
Dec 28, 2008 | Honeywell CT87B ROUND HEATING&COOLING...
if you have an emergency heat position we will assume you've got a heat pump. If you do not have a heat pump you have the wrong thermostat for your application. Need model of this thermostat, wire colors, termiation points (what terminal designator they are connected to), and if you have it where they were and the model of the last thermostat that worked correctly
Nov 17, 2008 | Honeywell CT87B ROUND HEATING&COOLING...
What you can do is you can go to any store for special like bottles that you put inside the AC unit to get cold air.
Thank You!!!!!!!!!!
Jun 23, 2008 | Honeywell CT87B ROUND HEATING&COOLING...
RTH6300B Honeywell Thermostat
my air conditioning does not turn on at the time i want it on. previous owners had set timers for it to turn on, how do i re-set the timer as we do not want the timer on. we want to be able to turn it on and off as we please.
May 29, 2008 | Honeywell CT87B ROUND HEATING&COOLING...
WIRING DIAGRAM LOST FOR NON-PROGRAMMABLE CT87
Red is power return to turn on heat
White is common power to both heat and cold
Blue is power return to turn on AC
You can get specific guidance on wiring at the Honeywell Website.
http://customer.honeywell.com/techlit/pdf/69-0000s/69-0274.pdf
Apr 12, 2008 | Honeywell CT87B ROUND HEATING&COOLING...
Heating & Cooling Logo
503 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
