Question about Maytag Atlantis MAV6451 Top Load Washer
Wash cycle dose not work
Maytag washer will not go into the wash cycle, but will work in the spin cycle. I put on new belts and looked under the agitior
  • Maytag Master
  • 8,220 Answers
There is a small white micro switch mounted near the lid switch. This is a called a check switch. Replace it.Wash cycle dose not work - d023fa4.jpg
Posted on Jan 08, 2009
The belt fell off, looked worn so purchased a new one and put it on (very tight!) Started machine, and belt new belt fell off. Pls help.
Can you confirm your model number? FAV6800A or FAV9800A?
If it's one of those models with 120VAC power cord removed from the service outlet and the front cover removed. See if you can rotate the Clutch Pulley CW the wash agitate direction and then CCW the Spin direction. The Clutch Pulley is the large pulley in the center of the washer. We are looking to see if the drive system is seized.
After the drive belt replacement was there any belt screech when you powered up the machine and selected a Wash or Spin Only Cycle?
Feb 09, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Atlantis 6451 noise when on and agitator doesn't work.
it does sound like a bad motor.
they are rather expensive on that machine,
you would be looking at 300 or so
May 28, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Does not wash
not sure about the model maybe the belt or motor coupling .look under the bottom and check it out
Apr 07, 2009 | Maytag MAV2755A Top Load Washer
PAVT920AWW Noise in wash cycle no agitation
Your Belt still needs replacing or to be scuffed up with sand paper. If thes fails you need either new tub bearings or a transmission. either a 250-300.00 repair so tr the belt and rotate drain pump rotation while the belt is off
Mar 29, 2009 | Maytag PAV2300 Top Load Washer
WASHER WON'T WASH
Check the pully Cam if thats good. You have a bad tranmission. This warr. for ten years
Jan 31, 2009 | Maytag PAV2300 Top Load Washer
Agitater does not spin
the transmission needs to be replaced
Jan 02, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag top loader won't do the wash cycle
hate to be bearer of bad news, but the transmission is the culprit this time.
Jul 10, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Loud squeal during wash and spin cycles, maytag atlantis washer
Squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
If part of a belt gets torn and it is long enough, it will hit any part of the washing machine within range and make a clicking noise at every revolution of the motor.
I am pretty sure you need new belts. You should be able to remove a few screws and open the back cover. Between the pulleys there is a tensioner...loosen that so you can remove the belt easily. replace it with a new belt and adjust the tension.
hope this helps
Feb 23, 2008 | Washing Machines
MAYTAG WASHER SAV205DAWW
i can step you through it in a live chat session
Sep 27, 2007 | Washing Machines
Maytag Atlantis MAV6451 Top Load Washer Logo
55 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
