Question about SanDisk Sansa Clip MP3 Player
Battery will not charge, can't sync
No problems before now, had mp3 for about 4 months
now battery does not recharge, my computer does not recognize device and i cannot sych music to the mp3 player
(all of this worked automatically at first)
thank you-frances
  • lgwd Mar 29, 2009
    Instead of charging, when I plug into the USB port, it drained the battery! Help.
Under SETTINGS, change the USB connection to MSC mode. That resolved the problem for ours.
Posted on Sep 02, 2009
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jan 09, 2009
I misplaced for several months but finally found! Battery says medium but I can't get the display to work
app shows battery charge on last sync. display does not work, because it is fully discharged. recharge and then resync.
Jan 21, 2016 | Fitbit Zip Wireless Fitness Tracker
Computer won't recognize zen when it's connected
hello,
please tell the model it could help solving the problems.
for us to download the specific drivers of the model.
melnavz
May 22, 2008 | Creative Labs ZEN Vision:M Digital Media...
Hi, I have a problem with ti-nspire cx cas, it doesn't charge via a usb cable.
Are you really talking about a TINspire CX or a TI NSpire. The TINspire CX (CAS or Not) comes with a rechargeable battery and an adapter/Charger. You plug the charger in an electric outlet and let it party charge. If the calculator battery fails to recharge then it must be defective. Any third party mini USB charger will recharge the battery.
The TINspire with touchpad (CAS or not) can use regular batteries or the optional rechargeable battery.
It is not necessary to connect the calculator to a computer to have it recharged.
As far as the calculator being recognized by the computer, you must install the communication software (TI computer Link Software for the older TINspire) or the TI Nspire teacher or student software for the CX. When you run the TINspire teacher or student software and then connect the calculator, you will have the opportunity to select it.
Aug 16, 2012 | Texas Instruments TI-Nspire Graphic...
Mix max won't play music, turnoff or charge
If it is not recognizing by the computer, not turning off, or recharging, then you have a problem with the battery in itself (or battery related components).
You probably won't be able to get a battery replacement for that unit.
With anything, when a computer system, router, MP3 player, IPOD, etc. has problems functioning correctly, there is more than likely a power issue with the unit.
Aug 06, 2009 | Disney Mix Max Digital Media Player
Ipod not recognized by computer
I have the same problem. My ipod nano is not reconized by my computer or any other and the Ipod's screen is locked. The screen doesn't light up and only apears the time and a battery half way full.It doesn't turn on or play and it doesn't turn off either, but some times it begins to work again but nor for long. I am runnig windows xp and the latest itunes version.
Jul 29, 2008 | Apple iPod nano 3rd Generation
Samsung SGH-A701 Wont charge when on the charger
Similar problem, battery ran out but cant get recharge it, sometimes the screen flashes if it take the battery out and put it back in, but then black?
Should I try an new battery or a new phone?
Jul 15, 2008 | Samsung SYNC SGH-A707 Cellular Phone
New battery not charging
It is normal for a battery to degrade after a year since its a consumable part. It's just like any ordinary rechargeable battery. We have 2 points of failure that might be causing the problem. First the battery itself. Second the Charge board that charges and detects the battery. Given that the NON-DELL battery is working on other dell Computer, it simply tells us that it is the charge board that needs to be replaced wich is integrated to the motherboard. If your warranty is still active, call dell and tell them that you've tried a Known good battery and its still not charging. However, you might also consider that dell computers are designed for dell batteries. the charge board might have problems charging the third party battery since its not configured to do so.
hope this helps.
Demmy
Dec 10, 2007 | Dell Inspiron 6400 Notebook
My charging port seems to not work
My advise to you is if you have Sandisk Sansa m240 it does not come with a chargeable battery so you cannot charge it,replace it and your problem will go away. I replaced my unit with a rechargeable battery and I have no more battery problems. I charge my batter in a charger when needed.
Nov 20, 2007 | SanDisk Sansa m240 MP3 Player
Battery Problem
I figured out the problem. My AA battery recharger was not making good contact, so although it said the batteries were recharged, this was not the case. After fixing this and getting full recharges, the problem went away.
Aug 31, 2005 | Canon PowerShot A70 Digital Camera
Why won’t my camera recharge my batteries?
Not all cameras can charge batteries. CAUTION: Rechargeable batteries must never be used in the HP Photosmart 210 and 215 series digital cameras. The overload protection and control circuits are not designed to handle the kind of power intensity delivered by rechargeable batteries. If the camera is a model that does charge batteries, ensure the batteries are rechargeable: The only acceptable rechargeable batteries for HP Photosmart cameras are NiMH cells. Neither lithium nor alkaline cells are rechargeable, and they will not be charged in the camera. The camera must detect the type and condition of the batteries The camera will only charge batteries when it detects the batteries are rechargeable and in good condition. New rechargeable batteries, and/or batteries than have been unused for a long time will not be recognized as good batteries. If the camera fails to charge NiMH batteries, charge them in an external charger once, then use them in the camera. If this does not correct the problem, the cells are old and/or damaged and new cells must be purchased.
Aug 30, 2005 | HP Photosmart 120 Digital Camera
SanDisk Sansa Clip MP3 Player Logo
352 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
