Question about Euro-Pro Shark GI490 Iron
My shark Iron spits water. Why - Euro-Pro Shark GI490 Iron
  • 7 more comments
  • mscanel Jan 22, 2009
    What a dissapointment! My Iron does too. Do you have a solution yet?
  • Anonymous Feb 01, 2009
    It is very frustrating...what a waste of money!!
  • Anonymous Feb 04, 2009
    this iron is horrible. We have had 2 of them and they both have done this!!! Ruined many military uniforms dont get it!!!
  • Anonymous Feb 22, 2009
    my shark rapido spits brown water and shuts down while I am using it
  • Anonymous Mar 12, 2009
    My iron pours water out of the bottom.I do not recommen this iron to anyone.
  • Anonymous Mar 18, 2009
    spits water everywhere
  • Anonymous Apr 21, 2009
    Iron spits brown water and shuts off in the middle of ironing. It's only 2 years old.
  • Anonymous May 09, 2009
    do not buy this iron. all the money is spent on this piece of ****. work well for the first month, after that...drip drip drop!
  • sando8888 May 13, 2009
    Spitting most of the time and brown spots of water, too. I've stopped using the steam function, but will toss the iron asap. (I just bought it last week at Walmart on sale because it was the display. No instructions so I thought I was doing something wrong.) Help is appreciated.
    Genius:
  • 1,605 Answers
Water is coming out of where?
if it coming out of the filler, then you have too much water in the iron, if not then the iron is defective, it should only create steam not water droplets.
Posted on Jan 08, 2009
Shark troubleshooting
Pour all the water out of the iron, and fill it with white vinegar. Heat it and let it spit vinegar for a while.
Chances are there is simply a bunch of crud in the iron from the water, most likely calcium carbonate. The vinegar is the cheap and easy fix, but if that does not do it you;ll have to bring out the "Big Gun" and use some "CLR" cleaner, available at most grocery or hardware stores.
"CLR" stands for "Calcium, Lime and Rust", and a small jug of it is about $6 USD, It will clean the crud out for sure.
Ironing seems to be a "lost art". Congratulations on being a smart desser!
Jul 26, 2014 | Euro-Pro Shark GI490 Iron
My shark iron get hot but it will not put out any steam none
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Sep 26, 2009 | Euro-Pro Shark GI490 Iron
My Shark Iron leaks....
fill with water turn iron on max keep turning steam dial all the way to the right until you get to self clean hold iron horizontal and make sure you have a towel or something to catch water drips and debris coming out of iron let iron steam and spit water out until it stops on its own turn dial back to regular steam settings wipe residue off of the plate with a towel adjust temp settings back to normal
Aug 14, 2009 | Euro-Pro Shark GI490 Iron
Euro Pro Shark Iron
Thank you for taking the time to warn us and others about the euro pro shark iron. I will help spread the word.
Aug 10, 2009 | Irons
Shark Iron
The brown residue is probably caused by iron in the water. I would suggest you put a solution of half vinegar and half water into the water chamber and leave in the iron overnight.
Then switch it on to steam and holding the iron over the sink or over an old towel, the dirt (residue) comes out of the holes on the soleplate. Sometimes if the iron is badly scaled you might need to repeat the descaling.
Once complete fill with water and steam away, to flush any of the remaining vinegar out of the iron.
Depending on how often you use your iron and how much iron is in your water, you might consider performing this flush process every 2 or 3 months. It will help extend the life of your iron.
Good Luck
Aug 11, 2008 | Euro-Pro Shark GI490 Iron
Shark euro pro x
We fixed ours today. Take the iron plate off (bottom of the iron shaped like a triangle). You are looking for a thermal fuse (or thermal-protector fuse) pictured here for less than $2 at Radio Shack(http://www.radioshack.com/product/index.jsp?productId=2102788&CAWELAID=107599331). You will need needlenose pliers to gently remove the old fuse and the wire cutters to trim the long wires to the same length as the old fuse (less than 1/2"). Also, since the old fuse was 240 C and we only could find a 228 C replacement - we cannot use the iron at the same high temp. So we limited the dial by marking out a portion of the dial. The iron stopped working after I kept the iron on high for an extended period of time. My electrician husband explained that I over heated the iron - breaking the fuse. Not time I'll turn the iron off or down when I'm not using it. This was so easy, I'm going to check out our other broken irons.
Jul 05, 2008 | Euro-Pro Shark GI490 Iron
Shark Euro Pro Iron turns of while ironing
what makes the water spit out of the iron and make my clothes wet
May 05, 2008 | Euro-Pro Shark GI490 Iron
Euro-Pro Shark GI490 Iron Logo
811 people viewed this question
Top Euro-Pro Irons Experts
Henry  Thomas
Henry Thomas
Are you an Euro-Pro Iron Expert? Answer questions, earn points and help others
