Question about Bosch Dishwashers
Dishwasher is "tripping" the breaker & not draining.
In the middle of a wash cycle, the dishwasher quit & there was a "burnt" smell in the air. I checked the circuit panel & saw that it had tripped the breaker. I flipped the breaker back on & tried a "quick wash" to see if it would finish the job, but it tripped again. There is still water in the bottom of the dishwasher that won't drain & the dishes are not clean.
What should I do.
I had the same problem with a Hobart AM8 passthru dishwasher. The electrician determined that some of the wires had become exposed and were wet, thus shorting things out and tripping the breaker.
Posted on Jan 09, 2009
LG dishwasher LD1419W2 which would not fill -error code IE. I replaced the inlet hose complete. Now it has the error code FE and the water overflows onto the floor when in wash cycle. Peter
Try resetting by:
turn off dishwasher
trip circuit breaker to remove all power to unit
wait 30 seconds
restore power
start dishwasher
the drain pump should start and drain all water then start a cycle. Good luck
Nov 14, 2017 | LG Dishwashers
Unit quit in the middle of a cycle and won't power up, totally dead. Is there a suspect noise filter or fuse I should begin looking for?
Make sure your circuit breaker in the main breaker box has not tripped, or "poped". It will be one a little out of place and a bit loose if it has tripped. Turn it off and back on to reset. If it tripps immediately, you have a short somewhere, possibly in the dishwasher, so you will need an electrician and or Appliance tec. to find and fix.
Apr 10, 2015 | Samsung DMT400RHS Builtin Dishwasher
Maytag Quiet Series 300 Dishwasher will only run part of wash cycle before tripping breaker?
I'm thinking dishwashers is installed in correctly. Too low causing an issue. Have a tech look at it.
Nov 17, 2013 | KitchenAid 24 in. KUDI02IRBS Stainless...
My dishwasher was in the middle of a cycle and it just quit. The buttons dont light up. It doesn't turn on at all. What could be wrong with it?
Sonya, have you checked the circuit breaker in your home's circuit breaker panel to see it has been tripped? Also, is the dishwasher door tightly shut? If the breaker is tripped, reset it to see if the dishwasher trips it again. If it does, either breaker is faulty or the dishwasher has a short circuit in the electrical circuitry. You'll need an authorized service person for that.
Mar 21, 2011 | Heating & Cooling
No power, tripping circuit breaker, loud pop inside when wash cycle starts.
Sounds like the main wash pump has burnt out are there any leaks under unit.It could also be the heater.but the loud pop sounds more like the wash pump.
Hope this helped.
May 11, 2010 | Tricity Bendix 24 in. DH104 Free-Standing...
Burning plastic smell, big flash & now its dead - Bosch SHU8805UC
remove the water and, the burnt plastic that probanly melted on the dish drying heater coil
close and, lock the door turn the dishwasher back on and, reset the circuit breaker to see if the motor will run or, is damaged
Jul 01, 2009 | Bosch 23 in. SHU 8805 Built-in Dishwasher
Drum full of water. stopped during cycle will not start-up again.
It sound's like you need a new drain pump and maybe a main motor controller module if it still doesn't go. cheers
Mar 20, 2009 | Fisher and Paykel GWL11 Top Load Washer
NO Agitator, draining or spin
Since the breaker did not trip i am going to assume that the washer stopped because the motor overload switch tripped or contacts burnt. Was there any smell of any burning (electrical burning)?. It could have stopped because a contact on the timer got burnt too. Have a look also at the water level swirch
Regards
Oct 04, 2008 | Whirlpool LSB6200KQ Top Load Washer
Jenn_air model #JD8910AWS won't drain
I was having the following symptoms: If I hit the drain button, it would stay at 2 minutes and just click on and off. If I hit the rinse button, it would rinse all 9 minutes OK. It would always stick in the middle of a full cycle and just start clicking.
I just fixed it. I shut off the circuit breaker, opened the door up (all torx screws from inside of door) to get the the upper controls. One lead (of two) of a capacitor (square blue component) had actually worked itself out of the control board. I cleaned it up and resoldered it in. All better now - for now.
Aug 15, 2007 | Jenn-Air 24 in. JDB8910 Built-in...
Dishwasher tripping the circuit breaker
Andy, leave the breaker off and remove the toe panel (bottom panel) from the dishwasher. Remove the cover of the junction box where the cord connection or wiring is made. Look at the wire caps and see if they are not burnt. Sometimes these connections become loose and arch, tripping the breaker. If so, cut the wires, strip a new end and reconnect. Catriver...post back.
Aug 21, 2006 | Hotpoint 23 in. BF50 Built-in Dishwasher
Dishwashers Logo
1,708 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
