Question about Vizio L32 32 in. LCD HDTV
Sound Problems with 32" Vizio HDTV
My Vizio 32" HDTV makes a popping noise that is very annoying. This is not the LCD warming up noise but a cracking and popping noise. Sometimes the picture jumps when it is occurring.
I have found that if I remove the leads from the cable box from the Component 1 input on the TV for 30 minutes or so, then put them back on, it will be better for a couple of days.
Any suggestions on a permanent fix.
Fed Up in TN
Our brand new Vizio 32 HDTV has poor sound quality, so irritating in it's flat muffled character that I can't watch it. My electrical engineer husband as attempted to change it (he does not hear the difference between the Vizio and our two Sony...there is a BIG difference) by turning off the surround sound. But to me nothing has changed. What do you think? it sounds a little bit like an old radio or a broadcast from inside a closet. Hmmm
Posted on Jan 27, 2011
Why is my Vizio VA320M HDTV making cracking and popping sounds?
Check the speaker first. If it is found OK, Check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Apr 03, 2015 | Vizio VA320M 32 in. LCD HDTV
Last night our TV made a loud popping noise then the picture went out. We still have sound but have trouble turning the TV off. What could this be and is it fixable? Thanks, Anne Marie Orcutt
Question shows it is Vizio L32 lcd tv and symptom shows back light inverter board for defective for some reason and loud noise would be popping of any chip on inverter board.
Shopjimmy..com has replacement boards of that model on reasonable price and local tv repairman will replace defective board after checking/ testing the tv.
Hope these info will help.
Thanks.
May 11, 2011 | Vizio L32 32 in. LCD HDTV
I was watching t.v. Heard a loud pop and the t.v.
Sounds like the lamp popped. If you can find a tech pub on how to take it apart, or are gullable enough to tear into it, the lamp should be found for around $150. Maybe less. But you can also get a new 32" for under $400 too.
Jun 30, 2010 | Vizio L32 32 in. LCD HDTV
Buzzing noise coming from Vizio HD TV speakers
It ur Vizio tv,The power supply board is the problems.The transformers in the power supply board have gaps in the transformers.The high voltage curents flow that make that buzzing noise.
Apr 07, 2010 | Vizio VW32L 32 in. LCD HDTV
32'' Vizio LCD no picture or sound
Your filter capacitors have popped due to diodes shorting, P-channel FETs shorting from gate-to-drain. Pull-up resistors have changed value and as a result your capacitors have peaked (popped)....so now the tv is in protection mode to prevent further damage to your tv. Take it to your local shop for servicing, or take it back if its under warranty......
Nov 05, 2009 | Vizio L32 32 in. LCD HDTV
There is a popping sound about once a minute on our Vizio 32 inch
It sounds like a ground wire or something bad in the Audio board. Send it in for repair
Mar 16, 2009 | Vizio VW32L 32 in. LCD HDTV
Tv making popping noise
does vizio have tv codes listed anywhere?
Jan 09, 2009 | Vizio L32 32 in. LCD HDTV
Vizio Speaker Making a Buzzing Noise
My 32" vizio I bought a week ago does the same things.
Buy an external sound system for the tv. Turn the speakers off in the TV menu. Hook the sound system up to the out speaker hookups on the tv.
You will not only have better found, you will fix the speaker buzz problem.
Feb 19, 2008 | Vizio L32 32 in. LCD HDTV
Vizio 42" 1080p HDTV LCD.
This is likely due to heat expansion (turned on) and contraction (turned off).
Nov 19, 2007 | Vizio L32 32 in. LCD HDTV
Vizio L32 32 in. LCD HDTV Logo
964 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
