Question about Tomtom ONE 3rd Edition GPS
It does not turn on is it repairable
I turned it on when it was cold -30c the screen lite up and then shut down does not come on again even when pluged in to power
  • 89 Answers
Probably not you should never start an electronic like that whene it is that cold out because it goes from being really cold to warm to fast always warm them up before starting them
Posted on Jan 08, 2009
IMac G5 17" won't shut down
I have minor shutdown problem with mail, won't close or shut down. My ans top left APPLE drop down, force closure, turn of each programme listed. For me works a treat.
Jan 19, 2013 | Apple Computers & Internet
My son took game out of console without powering off now screen is frozen and I cannot even power off have tried other games screen stays the same
Hi.
You will need to remove the battery to get the DS Lite to turn off.
Get yourself a Philips screwdriver and a small flat headed screwdriver, then close the lid on the DS. Next turn the DS upside down with card slot facing towards you.
On the right hand side of the DS you will see a Philips screw head near the bottom, unscrew that screw and remove the battery cover. This will expose the battery itself. Use the flat headed screwdriver to gently pry the battery out from the right hand side.
Once the battery is out the DS will shut down. Reinsert the battey again and screw the cover back on.
Switch the DS on and it should work properly again. If it freezes again just repeat these steps.
Regards.
Jun 14, 2011 | Nintendo DS Lite Console
DS LITE TURNS ON AND SCREENS LIGHT UP BUT CAN SEE NO IMAGE IN IETHER
Usually one of the screens "pulling" the other down -or maybee even both have failed, get it repaired at DS DOCTOR
May 07, 2010 | Nintendo DS Lite Console
My ds will not turn on
It sounds like one of you're screens has broken. What you have discribed is generally what happens one either the top or bottom LCD screen has broken.
If it is the top screen the bottom screen will flash for 1/2 a second and the DS turns off.
If it is the bottom screen the DS should still turn on but with no reaction from the screens. (the Ds will shut down immediatley after turning on)
Sep 17, 2009 | Nintendo DS Lite Console
Ds lite flashes on but fuses are ok
One or both your screens have blown.
Try removing the motherboard from the screens and attach the battery the green light should turn on and stay on.
Now attach the lower screen and turn on. If the screen is ok the screen and green light will flash and then turn off. (if the screen doesn't flash the bottom screen is you're problem and will have to be replaced)
If this happens the problem is then you're top screen which you will have to replace.
Jul 26, 2009 | Nintendo DS Lite Console
My ds just crashes--shuts down--when playing. Is
The same thing happened to my DS that was 3 years old. But at a point it didn't even turn on. The top screen made a quick blink then it turned back off automatically. I suggest you just get a new DS (I got a DSi) because a new battery is VERY expensive.
Answer:It is definitely the battery, though.
Jul 07, 2009 | Nintendo DS Lite Console
Nintendo DS lite; changed touch screen and it won't start
Hi. this issue is normaly caused by bad screen (normaly top screen) or bad assembly in one of two screens, re insert carefully the flex cable again, if your screens are fine this must fix the issue
Mar 14, 2009 | Nintendo DS Lite
Akai lct 2701td comes on then shuts down
Hi
You have power supply problem. Please go to ebay and buy cheaper price:
AKAI LCT2701AD POWER SUUPLY MLT166A
Thanks
GEORGE
Mar 11, 2009 | Akai LCT2715 27 in. LCD Television
DS Lite Turns off when moving top screen.
ITS AN INTERMITTENT CONTACT with the ribbon belt that connects from the main unit to the upper screen , I believe you need to take the DS for an authorized repair shop, but before doing anything , give a call to a tech support at NINTENDO , THEY would gladly help you out and inform you whats the next step , hope this helps , AJ , in case you dont have the LINK, let me give it to you : http://www.nintendo.com/consumer/ ,
hope this helps AJ
May 10, 2008 | Nintendo DS Lite Console
Nintendo DS Lite shuts off randomly.
I'm a certified electronic technician and I must say NDS internal screen ribbon connectors are junk! Basically The ribbon connectors are so sketchy that it is not recommended to ever unclip them, if you do there's a good chance it will ever work again once reconnected due to how the connector pins slightly crimp into the ribbon pads.
When a NDS boots up the the onboard firmware constantly tests the LCD screen connections, if there is a break in the connection the NDS will shut down. If your NDS randomly turns off, fails to boot, or powers of when you move the hinge it is most likely the ribbon (flex film) or ribbon connector has failed. The only option to to replace the affected LCD screen.
Jan 08, 2008 | Nintendo DS Lite Console
Tomtom ONE 3rd Edition GPS Logo
37 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
